Workato EDI - Create record action
Use the Create record action to create a record in Orderful, such as a Transaction or Acknowledgment.
SUPPORTED TRANSACTION FORMATS
The Create record action supports creating transactions in both X12 and JSON formats. However, it supports creating an acknowledgment for JSON transactions only.
Acknowledgments for X12 transactions should be sent as 997 Functional Acknowledgments by the backend system that ingests the X12 file.
Orderful is configured to automatically acknowledge transactions by default, though this setting can be modified at the account and relationship level. You do not need to create an acknowledgment using the Create record action when automatic acknowledgments are enabled.
Refer to Orderful's documentation for more information about acknowledging a transaction.
Input
Input fieldDescription
ObjectUse the Object drop-down to select the record you plan to create. Available options include Transaction and Acknowledgment. You must be the recipient of a Transaction to create an Acknowledgment.
Transaction typeObject containing the transaction type details. Available when you select Transaction as the object to create.
Name (Transaction type)Select a transaction type from the list of available EDI transaction types.
Refer to Orderful's documentation for more information about available transaction types.
StreamSpecify the stream that the transaction belongs to. Select TEST for your testing environment or LIVE for your production environment.
SenderObject containing sender details. Available when you select Transaction as the object to create.
Interchange control header (ISA ID) (Sender)Select an ISA ID from your organization's EDI accounts.
ReceiverObject containing receiver details. Available when you select Transaction as the object to create.
Interchange control header (ISA ID) (Receiver)Enter the trading partner's ISA ID. This identifies the organization you're sending the EDI transaction to.
MessageProvide the transaction document using the structure defined by the transaction type. Must be provided in JSON format.
Transaction IDProvide the ID of the transaction to acknowledge.
Available when you select Acknowledgment as the object to create.
StatusSelect an acknowledgment status: Accepted or Rejected.
Refer to Orderful's documentation for more information about transaction statuses.
ErrorsObject containing error details for the acknowledgment. Available when you select Acknowledgment as the object to create.
Errors source list (Errors)Input a list datapill containing the errors to include with the acknowledgment.
Path (Errors)Input the error path, such as message.
Code (Errors)Input the error code.
Message (Errors)Input the error message.
Output
The output for this action is dynamic and depends on the object created in Orderful.
Transaction object output
Output fieldDescription
Transaction IDUnique identifier of the transaction.
Acknowledgment object output
StatusIndicates whether the acknowledgment was created successfully.
