Workato EDI - Search records action (batch)
Use the Search records action (batch) to search for transactions or relationships in Orderful.
Input
The input fields are dynamic and depend on the object you select.
Transaction object input fields
| Object | Use the Object drop-down to select the type of record to search for. Available options include Transaction and Relationship. The remaining input fields change based on your selection. |
| Business number | Enter the business number associated with a transaction. Filters the results to transactions with a matching business number. |
| Transaction type | Enter the transaction type, such as RAW_ORDER or 850_PURCHASE_ORDER. Filters the results to transactions of the matching type.Refer to Orderful's documentation for the list of available transaction types. |
| Created from | Enter the earliest creation timestamp to include. Filters the results to transactions created on or after this timestamp. |
| Created to | Enter the latest creation timestamp to include. Filters the results to transactions created on or before this timestamp. Use together with Created from to filter by date range. |
| Validation status | Enter a validation status, such as VALID or INVALID. Filters the results to transactions with a matching validation status.Refer to Orderful's documentation for more information about transaction statuses. |
| Delivery status | Enter a delivery status, such as SENT or DELIVERED. Filters the results to transactions with a matching delivery status.Refer to Orderful's documentation for more information about transaction statuses. |
| Acknowledgment status | Enter an acknowledgment status, such as ACCEPTED or REJECTED. Filters the results to transactions with a matching acknowledgment status.Refer to Orderful's documentation for more information about transaction statuses. |
| Sender interchange control header (ISA) ID | Enter the sender's ISA ID. Filters the results to transactions from a matching sender. |
| Receiver interchange control header (ISA) ID | Enter the receiver's ISA ID. Filters the results to transactions to a matching receiver. |
| Reference identifier | Enter a reference identifier for filtering or lookup. |
| Previous cursor | Provide the pagination token returned as Previous cursor in a previous response. Use to retrieve the previous page of results. |
| Next cursor | Provide the pagination token returned as Next cursor in a previous response. Use to retrieve the next page of results. |
| Stream | Enter a stream to filter by, such as TEST or LIVE. Filters the results to transactions in the matching stream. |
| Sender interchange reference identifier | Enter the sender's interchange reference identifier. |
| Sender group reference identifier | Enter the sender's group reference identifier. |
| Sender transaction reference identifier | Enter the sender's transaction reference identifier. |
| Receiver interchange reference identifier | Enter the receiver's interchange reference identifier. |
| Receiver group reference identifier | Enter the receiver's group reference identifier. |
| Receiver transaction reference identifier | Enter the receiver's transaction reference identifier. |
Relationship object input
| Limit | Enter the maximum number of relationships to return in one response. |
| Auto send | Filter the results by whether automatic sending is enabled for the relationship. Available options are Enabled and Disabled. |
Output
Transaction object output
| Transactions | List of transactions that meet your search criteria. |
| Transaction ID | Unique identifier of the transaction. |
| URL | API endpoint URL for the transaction resource. |
| Version | API version used. For example, v3. |
| Sender | Object containing details about the sender trading partner. |
| Interchange control header (ISA) ID (Sender) | Sender’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Sender) | Qualifier for the sender’s interchange control header ID. |
| Test Interchange control header (ISA) ID (Sender) | Test sender interchange control header ID. |
| Test Interchange control header (ISA) ID qualifier (Sender) | Qualifier for the test sender’s interchange control header ID. |
| Name (Sender) | Name of the sender trading partner. |
| Receiver | Object containing details about the receiver trading partner. |
| Interchange control header (ISA) ID (Receiver) | Receiver’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the receiver’s interchange control header ID. |
| Test Interchange control header (ISA) ID (Receiver) | Test receiver interchange control header ID. |
| Test Interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the test receiver’s interchange control header ID. |
| Name (Receiver) | Name of the receiver trading partner. |
| Type | Object describing the transaction type. |
| Name (Type) | Transaction type, such as 850_PURCHASE_ORDER or RAW_ORDER. Refer to Orderful's documentation for more information about available transaction types. |
| Stream | Indicates whether the transaction was sent to a production or test communication channel. Returns TEST for test communication channels and LIVE for production communication channels. |
| Business number | Business number associated with the transaction. |
| Reference identifiers | List of reference identifiers tied to the transaction. |
| Value (Reference identifiers) | The control number value captured from the EDI envelope. |
| Type (Reference identifiers) | The EDI envelope header the control number came from. Returns INTERCHANGE, GROUP, or TRANSACTION. |
| Owner (Reference identifiers) | The party that owns the reference identifier. Returns SENDER or RECEIVER. |
| Validation status | Status of EDI validation, such as VALID or INVALID. Refer to Orderful's documentation for more information about transaction statuses. |
| Delivery status | Status of delivery to the trading partner, such as SENT, DELIVERED, or FAILED. Refer to Orderful's documentation for more information about transaction statuses. |
| Acknowledgment status | Status of acknowledgment, such as ACCEPTED, REJECTED, or NOT_ACKNOWLEDGED. Refer to Orderful's documentation for more information about transaction statuses. |
| Acknowledgment | Object containing a link to the acknowledgment. |
| URL (Acknowledgment) | API endpoint URL for the transaction acknowledgment. |
| Created at | Timestamp when the transaction was created. |
| Last updated at | Timestamp when the transaction was last updated. |
| Message | Object containing a link to the transaction message. Also contains a nested Download object for Any File transactions. |
| URL (Message) | API endpoint URL for the transaction message. |
| Download (Message) | Object containing download details for the transaction file. Populated for Any File transactions. |
| Download URL (Download) | The download URL of the transaction file. Map the Download URL datapill into the Download transaction file action to retrieve the file contents. The URL expires 24 hours after retrieval. |
| Pagination | Object containing the cursors that page through the full result set. |
| Previous cursor (Pagination) | Cursor token for the previous page of results. Pass this value into the Previous cursor input field on a subsequent run to retrieve the previous page. Returns null when there is no previous page. |
| Next cursor (Pagination) | Cursor token for the next page of results. Pass this value into the Next cursor input field on a subsequent run to retrieve the next page. |
Relationship object output
| Relationships | List of relationships that match your search criteria. |
| Relationship ID | Unique identifier of the relationship. |
| Created at | Timestamp when the relationship was created. |
| Updated at | Timestamp when the relationship was last updated. |
| EDI account ID (Sender) | The sender’s EDI account ID. |
| Live Interchange control header (ISA) ID (Sender) | The live ISA ID for the sender. |
| Test Interchange control header (ISA) ID (Sender) | The test ISA ID for the sender. |
| EDI account ID (Receiver) | The receiver’s EDI account ID. |
| Live Interchange control header (ISA) ID (Receiver) | The live ISA ID for the receiver. |
| Test Interchange control header (ISA) ID (Receiver) | The test ISA ID for the receiver. |
| Transaction type | Object describing the transaction type. |
| Name (Transaction type) | The transaction type, such as 850_PURCHASE_ORDER or RAW_WAREHOUSE_TRANSFER. |
| Status | The current status of the relationship, such as READY. |
| Auto send | Indicates whether automatic sending is enabled for transactions. Returns ENABLED or DISABLED. |
