Zscaler Digital Experience (ZDX) - Get record action
The Get record action retrieves a single application, user, or device from Zscaler Digital Experience (ZDX) by its unique ZDX ID.
Input
Input fields dynamically generate based on the object you select. The following input field is common to all objects.
Input fieldDescription
ObjectSelect the object type to retrieve. Options include Application, User, and Device.
Output
Output fields dynamically generate based on the object you select.
