Zscaler Digital Experience (ZDX) - Search records action
The Search records action searches Zscaler Digital Experience (ZDX) for records that match the filters you specify. Results use cursor pagination.
Input
Input fields dynamically generate based on the object you select. The following input field is common to all objects.
| Object | Select the object type to search. Options include Applications, Users, Devices, Software, Departments, and Locations. |
Output
Output fields dynamically generate based on the object you select.
