Configure Chargebee as a data pipeline source
Set up Chargebee as a data pipeline source to extract subscription, billing, invoicing, and payment records into your destination.
Use this guide to set up a connection, configure your pipeline, add objects, review sync behavior, and understand known limitations.
Chargebee features supported
The following features are supported when you use Chargebee as a pipeline source:
- Cloud connectivity: Connect to Chargebee over HTTPS through your site's subdomain (
https://{subdomain}.chargebee.com). On-prem agents aren't required. - Live and test site support: Connect to either your live Chargebee site or its dedicated test site by providing the corresponding subdomain. Workato treats each site as a separate connection.
- Full sync and incremental sync: Supports full sync and incremental sync modes for objects that advertise incremental support. The cursor field varies by object. Refer to Sync modes for more information.
- Object-level selection: Select Chargebee objects to sync as separate tables in your destination. Refer to Supported objects for the full list.
- Delete tracking: Detect deletions for supported objects and mark deleted records in your destination. Refer to Delete tracking for the list of objects.
- Custom field discovery: Automatically syncs Chargebee custom fields (
cf_*) for supported objects. Refer to Custom fields for more information. - Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
- Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
- Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
Chargebee prerequisites
Connecting Chargebee as a data pipeline source requires:
- A Chargebee account, either live or on a dedicated test site.
- A Read-only: All API key generated from your Chargebee site. Refer to the Chargebee API Keys documentation for setup steps.
- Your Chargebee site subdomain
- The Product Catalog version your Chargebee site uses, either PC 1.0 or PC 2.0
REQUIRED PERMISSIONS
Generate a Read-only: All key for this connection, not Read-only: Restricted, which excludes coupons, coupon sets, and coupon codes and blocks the Coupon and CouponCode objects. Each Chargebee site, including its dedicated test site, has its own independent set of API keys. Generate the key from the same site whose subdomain you plan to enter in the connection.
Supported connection types
Chargebee data pipelines support one authentication method:
- API key: Provide a Read-only: All API key generated from your Chargebee site, along with your site subdomain and Product Catalog version. Chargebee doesn't support OAuth 2.0 for API access. Refer to Prerequisites for setup requirements.
Complete the following steps to connect Chargebee as a data pipeline source:
Search for Chargebee and select it as your app.
Paste the Chargebee API key you generated into the API key field.
Enter your Chargebee site name in the Subdomain field. For example, enter acme if you sign in to Chargebee at https://acme.chargebee.com. Enter the corresponding test site subdomain, which ends in -test, to connect to test data instead of live data.
Use the Product catalog drop-down menu to select the Product Catalog version your Chargebee site uses, either PC 1.0 or PC 2.0.
Select Connect to verify and save the connection. Workato displays a success message when the connection is established.
DETERMINE YOUR PRODUCT CATALOG VERSION
Chargebee sites created before May 5, 2021 use Product Catalog 1.0. Sites created on or after that date use Product Catalog 2.0. The version you select determines which catalog objects are available to add to your pipeline: Plan and Addon on Product Catalog 1.0 sites, or ItemFamily, Item, ItemPrice, DifferentialPrice, PriceTier, SubscriptionItem, and Usage on Product Catalog 2.0 sites. Check your Chargebee site settings if you're unsure which version applies to your account.
Configure the pipeline
Complete the following steps to configure Chargebee as your data pipeline source:
Data pipeline setup
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from Chargebee.
Use the Your Connected Source Apps drop-down menu to select Chargebee.
Choose the Chargebee connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Add objects
Search or browse the list of available Chargebee objects, select the objects you plan to sync, and click Add.
CHILD OBJECTS SYNC AS FULL SYNC ONLY
Objects that sync alongside a parent record, such as SubscriptionItem, InvoiceLineItem, PriceTier, and QuotedSubscription, appear with a Full sync tag in the object list and don't have an independent sync mode. Refer to Supported objects for the full list of child objects.
Optional. Click the gear icon next to an object to open its Sync mode settings. Use the Sync mode drop-down menu to select Full sync or Incremental, then click Save.
The sync mode defaults to Full sync for objects that don't support incremental sync, including objects without a usable cursor and child objects that sync with a parent. Refer to Sync modes for more information.
Click Add object again to add more objects. Repeat this step to include additional Chargebee objects in your pipeline.
Workato recommends Auto-sync new fields for Chargebee accounts that use custom fields (cf_*), so new custom fields sync automatically. Refer to Custom fields for more information.
Optional. Enter a value in the Concurrency limit field to cap the number of concurrent operations. Leave the field blank to use the default limit set by Workato. The Chargebee implementation advertises 5 concurrent objects by default. The effective limit can't exceed the source-advertised limit.
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Chargebee to the destination.
Supported Chargebee objects
Chargebee data pipelines sync data from the Chargebee API v2. The following tables list the supported objects, grouped by category. Each object syncs as a separate table in your destination, unless noted otherwise.
Your connection's Product Catalog version determines which catalog objects are available to add to your pipeline. Subscription and Coupon include fields from both catalog versions, but only the fields for your site's version contain data.
Core account and billing objects
| Object | Sync modes | Delete tracking |
Customer | Full sync, incremental | Yes (soft) |
Subscription | Full sync, incremental | Yes (soft) |
SubscriptionItem | Full sync only (syncs with the parent Subscription object, PC 2.0 only) | No |
Invoice | Full sync, incremental | Yes (soft) |
InvoiceLineItem | Full sync only (syncs with the parent Invoice object) | No |
CreditNote | Full sync, incremental | Yes (soft) |
Transaction | Full sync, incremental | Yes (soft) |
PaymentSource | Full sync, incremental | Yes (soft) |
Subscription, Invoice, and CreditNote expose a native deleted flag used for delete tracking, as well as a status value for their primary business lifecycle. Chargebee moves these records through statuses such as cancelled for a Subscription or voided for an Invoice. Treat status as the business-lifecycle signal, not as the connector's soft-delete signal.
Discounts
Coupon | Full sync, incremental | Yes (soft) |
CouponCode | Full sync | Yes (destination-inferred) |
Product catalog: PC 1.0
Available only when your connection's Product Catalog version is PC 1.0.
Plan | Full sync, incremental | Yes (soft) |
Addon | Full sync, incremental | Yes (soft) |
Product catalog: PC 2.0
Available only when your connection's Product Catalog version is PC 2.0.
ItemFamily | Full sync, incremental | No |
Item | Full sync, incremental | No |
ItemPrice | Full sync, incremental | No |
DifferentialPrice | Full sync | Yes (destination-inferred) |
PriceTier | Full sync only (syncs with the parent ItemPrice or DifferentialPrice object, PC 2.0 only) | No |
Orders, quotes, and other billing objects
Order | Full sync, incremental | Yes (soft) |
Gift | Full sync | Yes (destination-inferred) |
UnbilledCharge | Full sync | Yes (soft) |
Quote | Full sync, incremental | Yes (soft) |
QuotedSubscription | Full sync only (syncs with the parent Quote object) | No |
VirtualBankAccount | Full sync, incremental | No |
Quote and QuotedSubscription require a Chargebee Performance or Enterprise plan. Refer to Limitations for more information.
Usage and events
Usage | Full sync only (append-only extraction, PC 2.0 only) | N/A |
Event | Full sync, incremental (append-only extraction) | N/A |
Comment | Full sync, incremental (append-only extraction) | N/A |
PromotionalCredit | Full sync, incremental (append-only extraction) | N/A |
Sync modes
Chargebee data pipelines support full sync and incremental sync. The sync mode is configured per object when you add it to your pipeline.
Full sync
A full sync reads all available records from Chargebee for the selected object on every run. Full-sync-only objects include CouponCode, Gift, DifferentialPrice, UnbilledCharge, and Usage. Some are full-sync-only because they lack a usable cursor, while others have no safe primary key for incremental upserts. Child objects that sync with a parent, including SubscriptionItem, InvoiceLineItem, PriceTier, and QuotedSubscription, also only support full sync.
Objects with a primary key merge into the existing destination table, so records deleted in Chargebee stay in the table. Objects without a primary key overwrite the destination table on every run.
Incremental sync
An incremental sync extracts only records created or updated since the last successful run, using an object-specific cursor. Most objects that support incremental sync use updated_at, Event uses occurred_at, and Comment and PromotionalCredit use created_at. Usage is full-sync-only, and its append-only endpoint filters by updated_at and sorts by usage_date. Append-only extraction inserts new rows and doesn't perform conflict resolution for existing rows.
Objects that sync alongside a parent record, such as SubscriptionItem and InvoiceLineItem, have no independent cursor. Workato extracts these rows whenever the parent object's row is extracted.
Refer to the Supported objects tables to see the sync modes available for each object.
Delete tracking
Workato reads Chargebee's deleted flag and sets the _workato_is_deleted column to true on the destination row for Customer, Subscription, Invoice, CreditNote, Transaction, PaymentSource, Coupon, Order, UnbilledCharge, and Quote. Subscription, Invoice, and CreditNote also expose status, but the connector treats it as a business-lifecycle field rather than a replacement for native delete tracking. For Plan and Addon, Workato derives _workato_is_deleted from status == "deleted".
CouponCode, Gift, and DifferentialPrice don't provide a delete signal that the connector can observe during extraction. Workato compares each full sync against the previous run and marks records that no longer appear in Chargebee as deleted in the destination, because these objects only support full sync. Although DifferentialPrice has a raw deleted field, its list extraction does not expose deleted rows for native delete tracking.
Refer to the Supported objects tables to see which objects support delete tracking.
Schema and data type handling
The following considerations apply to schema and data types when you sync data from Chargebee.
Monetary amounts
Chargebee stores monetary amounts as integers in the smallest currency unit of the relevant currency, such as cents for USD. Workato preserves these raw integer values and doesn't perform currency conversion. When Chargebee provides a decimal-form monetary field with an _in_decimal suffix, Workato preserves it as a string.
Timestamps
Chargebee returns timestamps as Unix epoch integers. Workato preserves the raw epoch values in the destination and doesn't convert them to a timestamp format.
Custom fields
Chargebee supports user-defined custom fields, which appear on objects with a cf_ prefix, such as cf_industry. Workato automatically discovers and syncs custom fields for Customer, Subscription, Invoice, CreditNote, Plan, Addon, Item, and ItemPrice. Custom fields on other objects aren't synced.
Custom fields vary by account and change over time. Select Auto-sync new fields when you configure the pipeline so new custom fields sync automatically.
Nested objects and arrays
Chargebee objects can include nested objects and arrays, such as billing_address on Customer or line_items on Invoice. Workato stores these as a JSON column in the destination, except where the nested array corresponds to its own supported object. For example, Invoice.line_items syncs as the InvoiceLineItem object instead. Workato doesn't flatten nested fields into individual columns. For very large invoices, Chargebee can return a line_items_next_offset value. The connector extracts the inline line_items array but doesn't follow that overflow offset, so additional line items beyond the inline array aren't synced.
Workato syncs JSON fields to the destination's native JSON type, such as VARIANT in Snowflake. Workato serializes JSON fields as strings if the destination doesn't support a native JSON type.
Synthetic columns
Workato adds the following synthetic column to destination tables for objects with delete tracking:
| Column | Type | Purpose |
_workato_is_deleted | Boolean | Set to true for deleted or removed records. Refer to Delete tracking for the list of objects this applies to. |
Chargebee objects can contain personally identifiable information (PII) and financial data. The following objects commonly contain sensitive fields:
| Object | Sensitive fields |
Customer | first_name, last_name, email, phone, company, billing_address, shipping_address, vat_number, custom fields (cf_*) |
PaymentSource | masked_number or last4, card_type, expiry_month, expiry_year, billing details |
Invoice, CreditNote | billing_address, shipping_address, and customer name and email snapshots |
Transaction | Gateway reference IDs and masked payment details |
VirtualBankAccount | Account and routing references |
Chargebee doesn't return full card numbers or CVV values through its API, so Workato doesn't sync raw payment card data for PaymentSource.
Chargebee limitations
The following limitations apply when you use Chargebee as a data pipeline source:
Quote and QuotedSubscription require a paid Chargebee plan
Quote and QuotedSubscription are only available on a Chargebee Performance or Enterprise plan. These two objects don't appear in the Add new objects panel if your account doesn't have this feature enabled.
Business entities are not synced as a separate object
Workato doesn't sync a dedicated object listing your Chargebee site's business entities, because Chargebee doesn't expose a corresponding list endpoint. Objects that belong to an entity still carry a business_entity_id field if your site uses the Business Entities feature, and Workato preserves it as-is so you can segment records by entity.
One connection per Chargebee site
A Chargebee API key is scoped to a single site, so create a separate connection for each Chargebee site you sync from, including a live site and its dedicated test site.
Transaction records are re-imported daily
Chargebee can update a Transaction record's settlement status after Workato first extracts it. To capture these late updates, Workato re-imports the full Transaction table once every 24 hours, in addition to incremental syncs.
Minimum sync frequency
