Configure Google Drive as your data pipeline source
Set up Google Drive as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with .csv and .parquet files stored in Google Drive folders.
Google Drive features supported
The following features are supported when using Google Drive as a data pipeline source:
- Extract and sync data from
.csvand.parquetfiles in Drive folders - Support for full and incremental sync through file detection
- Field-level selection for data extraction
- Field-level data masking
Google Drive prerequisites
- A Google account with access to the required Drive folders
- OAuth or service account credentials for authentication
- Folder paths and file patterns for the files to sync
Connect to Google Drive
Complete the following steps to connect to Google Drive as a data pipeline source. This connection enables the pipeline to extract and sync records from files in your Drive.
Search for Google Drive and select it as your app.
Google Drive
Select an Authentication type:
- OAuth 2.0: Use this method to authenticate with a Google user account.
- Service account: Use this method to authenticate using a service account JSON key from your Google Cloud Project.
Configure the following additional fields based on your Authentication type:
Optional. Expand Advanced settings and select Requested permissions.
Optional. Use a Custom OAuth profile if you manage OAuth settings externally.
Click Sign in with Google and complete the OAuth consent flow.
Configure the pipeline
Complete the following steps to configure Google Drive as your data pipeline source:
Data pipeline setup
Click Start building.
Use the Your Connected Source Apps drop-down menu to select Google Drive.
Choose the Google Drive connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose a Google Drive connection
Click Add object to configure files you plan the pipeline to monitor and sync.
Add Google Drive objects
Enter the folder path to monitor in the Source Folder path field. The pipeline monitors this folder and fetches files that match your filename pattern.
Configure file settings
NESTED FOLDER LIMITATION
The Google Drive connector doesn't fetch files from nested subfolders. It only monitors and fetches files located directly within the folder specified in the Source Folder path field.
If your pipeline expects to include files in subfolders, move those files to the top-level folder. Support for nested folders in Google Drive is planned for a future update.
Use the File type drop-down menu to select the file format to extract. Workato supports the following file types:
- CSV: Extract data from
.csvfiles. Requires additional file type settings configuration. - Parquet: Extract data from
.parquetfiles. Schema and data types are inferred directly from the file.
Define which files to fetch using a pattern in the Filename pattern field. Use wildcards, such as orders_*, to include multiple files. The file extension is appended automatically based on the File type you select.
Click Fetch matching files to preview files matching the defined pattern.
Select a Reference file to define the schema for your destination table.
Configure File type settings:
Click Fetch schema to retrieve the schema from the reference file.
Review the schema to ensure it matches your expected table structure. The schema preview includes the columns from your source file along with the following system-generated columns:
_file: The name of the source file each row originated from._line: The line or row number of each record within the source file.
Review schema
Configure how rows are merged in the destination table in the Choose a merge strategy field. Workato supports the following merge strategies:
- Upsert: Inserts new rows and updates existing rows. The Merge method field appears when you choose Upsert. You can select one or more columns to use as the primary key for the destination table. The pipeline uses the system-generated
_fileand_linecolumns as a composite primary key if you leave Merge method blank. - Append only: Inserts all rows without attempting to match or update existing records. The pipeline doesn't match on a key and doesn't update existing rows when you choose Append only.
Click Review object to confirm your setup. This screen displays your file settings, file type-specific options, and merge details.
Review object
Enter an Object name. This name defines the destination table name.
Click Finish to save the object configuration.
Optional. Configure field-level data protection. After you expand an object, choose how to handle each field:
- Replicate as is (default): Data values at the source are replicated identically to the destination.
- Hash: Hash sensitive data values in the column before syncing to your destination.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Google Drive objects in your pipeline.
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Google Drive to the destination.
File schema and processing
The Google Drive connector reads .csv and .parquet files stored in specified folders. These files define the structure and data that the pipeline extracts and syncs to your destination.
Workato infers the schema and data types from the selected reference file. Workato treats date and date-time values as strings for .csv files. Transform these fields to the appropriate data type in the destination after the load completes.
All matched files must maintain the same column structure and data format to ensure accurate schema mapping.
