Configure Google Search Console as a data pipeline source
Set up Google Search Console as a data pipeline source to extract Search Analytics performance reports and site and sitemap data from the Google Search Console API and sync it to your destination.
Use this guide to review the features and prerequisites, connect Google Search Console as a data pipeline source, configure the pipeline, and understand the supported objects, sync modes, schema handling, sensitive data handling, and known limitations.
Google Search Console features supported
The following features are supported when you use Google Search Console as a pipeline source:
- Cloud connectivity: Connects to the Google Search Console API over HTTPS. An on-prem agent isn't required.
- Automatic multi-property sync: Every Search Console property your connection can access syncs automatically, including domain properties and URL-prefix properties. There's no property picker in Workato. Refer to Every accessible property syncs automatically for more information.
- Search type coverage: Report objects sync the
web,image,video, andnewssearch types. Each report row includes asearch_typecolumn. Refer to Synthetic columns for more information. - Object-level selection: Choose from the supported Search Analytics reports and the site and sitemap tables. Refer to Supported objects for the full list.
- Incremental sync: All report objects sync incrementally by constraining the report's date range. Refer to Sync modes for more information.
- Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
- Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
- Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
Google Search Console prerequisites
Connecting Google Search Console as a data pipeline source requires:
- A Google account with access to at least one Search Console property as an owner, full user, or restricted user. Workato syncs every property this account can access. The connection fails if the account has no property at one of these levels. Refer to Every accessible property syncs automatically for more information.
- A Google Cloud project with the Google Search Console API enabled, an OAuth 2.0 client for that project, and a custom OAuth profile built from that client's ID and secret. The connection form requires a custom OAuth profile. Refer to Connect to Google Search Console for setup steps.
REQUIRED PERMISSIONS
Workato requests the https://www.googleapis.com/auth/webmasters.readonly scope. This read-only scope covers every supported object. Workato doesn't request the read and write webmasters scope.
Supported connection types
Google Search Console data pipelines support OAuth 2.0 authentication:
- OAuth 2.0: Authorize Workato using a custom OAuth profile built from a Google Cloud OAuth app that you create. Refer to Create a Google Cloud OAuth app for setup steps. Service account authentication isn't supported.
Complete the following steps to connect Google Search Console as a data pipeline source:
You must create a Google Cloud OAuth app and a Workato custom OAuth profile before you connect Google Search Console as a data pipeline source.
Go to Tools > Custom OAuth profiles in Workato and click + New custom profile.
Use the Application drop-down menu to select Google Search Console.
Enter a name in the Name field. The name can contain spaces but no special characters, and it must be unique for your account.
Click Create new app. Keep the Workato tab open.
Sign in to your Google Cloud Console in a new tab and select or create a project.
Search for the Google Search Console API in the API Library and click Enable.
Go to Google Auth platform > Clients and click Create client.
Configure the OAuth consent screen if prompted, then select Web application as the Application type.
Enter https://www.workato.com/oauth/callback in the Authorized redirect URIs field, then click Create.
Copy the Client ID and Client secret and store them securely.
Return to the Workato tab and enter the values in the Client ID and Client secret fields.
Click Save, then click Done. Refer to Custom OAuth profiles for more information.
Connect to Google Search Console with OAuth 2.0
Search for Google Search Console and select it as your app.
Use the Custom OAuth profile drop-down menu to select the custom OAuth profile you created for Google Search Console. This field is required.
Select Sign in with Google to open Google's sign-in window.
Enter your credentials in the Google sign-in window to authenticate your account.
Review the permissions that Workato requests, then approve them to complete the connection. Workato displays a success message when the connection is established.
Configure the pipeline
Complete the following steps to configure Google Search Console as your data pipeline source:
Data pipeline setup
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from Google Search Console.
Use the Your Connected Source Apps drop-down menu to select Google Search Console.
Choose the Google Search Console connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Search or browse the list of available Google Search Console objects, select the objects you plan to sync, and click Add.
FIXED OBJECT LIST
You can only select from the objects listed in Supported objects. You can't define your own combination of dimensions and metrics.
Click Add object again to add more objects. Repeat this step to include additional Google Search Console objects in your pipeline.
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Google Search Console to the destination.
Supported Google Search Console objects
Google Search Console data pipelines sync data from the Google Search Console API. The following tables list the supported objects, grouped by category. Each object syncs as a separate table in your destination:
The following reports return the clicks, impressions, ctr, and position metrics. Every report groups by date, country, and device. Page Report adds the page dimension, the keyword reports add the query dimension, and Keyword Page Report adds both. Reports with by Page in the name aggregate results by page, and reports with by Site in the name aggregate results by property. Workato syncs each report for every search type and every accessible property.
| Object | Sync mode | Delete tracking |
Site Report by Page | Incremental | No |
Site Report by Site | Incremental | No |
Page Report | Incremental | No |
Keyword Site Report by Page | Incremental | No |
Keyword Site Report by Site | Incremental | No |
Keyword Page Report | Incremental | No |
Keyword Page Report has the highest cardinality of the reports, because it groups by both page and query. It returns the most rows and consumes the most Google API quota. Refer to Search Analytics quotas for more information.
Property and sitemap data
The following tables sync configuration data about your Search Console properties and the sitemaps submitted to them. Sitemap Contents contains one row for each content type listed in a sitemap. Refer to Every accessible property syncs automatically for the properties each object includes.
Sites | Full sync | Yes (destination-inferred) |
Sitemaps | Full sync | Yes (destination-inferred) |
Sitemap Contents | Full sync | No |
Sync modes
Google Search Console data pipelines support full sync and incremental sync. Refer to the Supported objects tables to see the sync mode for each object.
Full sync
A full sync re-reads the complete record set from Google Search Console for an object on every run. Sites, Sitemaps, and Sitemap Contents use full sync, because the Google Search Console API returns these resources as complete lists and offers no way to request only changed records.
Objects with a primary key merge into the existing destination table, so records deleted in Google Search Console stay in the table. Objects without a primary key overwrite the destination table on every run.
Incremental sync
Search Analytics reports aren't row-level records with a modified-time field. Each report is a query over Google's reporting data, so incremental sync constrains the query's date range instead of filtering by a per-record cursor:
- Finalized data only: Workato syncs only finalized Search Console data, and every sync stops
3days before today. Each date syncs after it ages past that cutoff. - Rollback window: Every recurring incremental sync also re-pulls the
7days before the previous sync's cutoff date, because Google can revise recent values. Re-pulled rows update the existing rows in your destination instead of creating duplicates, so metric values for recent dates can change between runs. This window doesn't apply to the first, historical sync. - Historical sync: The first sync extracts every date from the start date you configure through the cutoff date. Refer to Historical sync is limited to two years for how the start date is applied.
Delete tracking
Report objects don't support delete tracking. They're aggregated metrics, and the Search Console API doesn't expose a deletion signal for them.
Sites and Sitemaps sync in full on every run. The destination compares each run against the previous one and marks records that no longer appear as deleted, because these are full-sync objects. The Search Console API itself exposes no deletion signal for them. Workato detects deletions on the next full sync, not at the time of deletion.
Sitemap Contents also syncs in full but doesn't support delete tracking.
Schema and data type handling
The following considerations apply to schema and data types when you sync data from Google Search Console:
Schema
Every object has a fixed schema defined by Workato. The schema doesn't vary between accounts or properties.
Data types
Workato maps the following report columns:
datesyncs as a date column.clicksandimpressionssync as whole numbers.ctrandpositionsync as decimals.country,device,page, andquerysync as strings and can be empty in a row.
Synthetic columns
Workato adds the following synthetic columns to destination tables:
| Column | Type | Purpose |
_workato_id | String | Report objects only. A primary key generated from the property URL, search type, and every dimension value in the row, because Search Console report rows don't include a natural identifier. A re-pulled row generates the same key, so it updates the existing row. |
site | String | The property URL that the row belongs to, such as sc-domain:example.com for a Domain property or https://www.example.com/ for a URL-prefix property. Added to report objects, Sitemaps, and Sitemap Contents, because a single pipeline syncs every property your connection can access. |
search_type | String | Report objects only. The search type the row belongs to: web, image, video, or news. |
Google Search Console reports are aggregated, and Workato delivers the values Google returns without masking or filtering any field.
| Object | Sensitive fields |
Keyword Site Report by Page, Keyword Site Report by Site, Keyword Page Report | query |
Page Report, Keyword Page Report | page |
Google Search Console limitations
The following limitations apply when you use Google Search Console as a data pipeline source:
Workato discovers and syncs every Search Console property that the connection's Google account can access. You can't limit a pipeline to specific properties in Workato. Remove the account's access to a property in Search Console to exclude it from syncing.
The permission level on each property determines what syncs:
- Owner and full user: All objects sync.
- Restricted user: Search Analytics reports and
Sitessync.SitemapsandSitemap Contentsdon't include the property. - Unverified user: The property is skipped, because this level has no data access.
The historical sync starts 1 year before today if you leave the start date blank. A start date more than 2 years before today is replaced with the date 2 years before today. Dates outside the range that Search Console retains return no rows, without an error.
Daily row ceiling
The Search Console API returns at most 50,000 rows per day, per search type, per property, sorted by clicks. The API drops the remaining rows without an error or other signal when a single day exceeds this limit, and Workato can't recover them. Google can also withhold additional rows when a report groups by page or query. Google doesn't offer a quota increase for this limit.
Google limits Search Analytics queries to 1,200 queries per minute for each property and each Google user. Google also applies a load-based quota that wide date ranges and reports grouped by both page and query consume faster than other query types. Workato waits and retries on quota errors. Set a more recent start date to reduce quota use.
Unsupported Search Console data
Google Search Console data pipelines don't sync the following data:
- URL Inspection data
- The
searchAppearancedimension - Hourly report data
- The
discoverandgoogleNewssearch types - Custom combinations of dimensions and metrics
Minimum sync frequency
