# Configure HubSpot as your data pipeline source
Set up HubSpot as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with HubSpot CRM objects.
# Features supported
The following features are supported when using HubSpot as a data pipeline source:
  • Extract and sync data using the HubSpot REST API
  • Support for full and incremental sync
  • Field-level selection for data extraction
  • Schema drift detection and handling
  • Field-level data masking
# Prerequisites
  • A HubSpot account with API access
  • OAuth credentials with appropriate API scopes
# Connect to HubSpot
Connect to HubSpot
Complete the following steps to connect to HubSpot as a data pipeline source. This connection enables the pipeline to extract and sync records from your HubSpot CRM.
Select Create > Connection.
Search for and select HubSpot on the New connection page.
HubSpot connection setupHubSpot connection setup
Select Cloud in the Connection type field, unless you need to connect through an on-prem group.
Optional. Expand Advanced settings to view additional configuration options.
Optional. Enter a Custom OAuth profile if you manage OAuth externally.
Select Connect to verify and store the connection.
# Configure the pipeline
Complete the following steps to configure HubSpot as your data pipeline source:
Select Create > Data pipeline.
Select Start building.
Select HubSpot from Your Connected Source Apps.
Choose the HubSpot connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose a HubSpot connectionChoose a HubSpot connection
Click Add object to open the object wizard.
Add objectsAdd objects
Search or browse the list of available HubSpot objects. Select the objects you plan to sync and click Add.
Select objectsSelect objects
Expand objectExpand object
You can expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Jira objects in your pipeline.
12
13
# Object schema behavior
The HubSpot connector extracts records from objects exposed by the HubSpot REST API. These objects define the schema that the pipeline uses.
Workato infers schema and data types from a selected reference object. The object structure must remain consistent to ensure accurate schema mapping.
Last updated: 3/19/2026, 5:30:39 PM
