Configure MySQL as a data pipeline source ​
Set up MySQL as a data pipeline source to extract and sync table records into your destination. Use this guide to set up a connection, configure your pipeline, add objects, and review known limitations.
MySQL features supported ​
The following features are supported when you use MySQL as a pipeline source:
  • On-prem connectivity: Connect to MySQL through an on-prem group. Cloud connections aren't supported for data pipelines.
  • Table-level object selection: Select individual MySQL tables to sync as objects in your pipeline.
  • Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
  • Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
MySQL prerequisites ​
Connecting MySQL as a data pipeline source requires:
  • A MySQL instance reachable from your on-prem agent host
  • A MySQL user account granted SELECT permission on the tables you plan to sync. Refer to Permissions required to connect for setup steps.
  • The host, port, database name, username, and password for your MySQL instance
Permissions required to connect ​
At a minimum, the database user account must have the SELECT permission on the database you plan to sync.
Create a dedicated user for Workato and grant it read-only access to the target database. The following example grants SELECT on a database named HR_PROD to a new user workato:
sql
CREATE USER 'workato' IDENTIFIED BY 'password';
GRANT SELECT ON `HR_PROD`.* TO 'workato';
Supported connection types ​
MySQL data pipelines support username and password authentication through an on-prem group. You must have a MySQL username and password to connect.
CLOUD CONNECTIONS NOT SUPPORTED
Cloud connections aren't supported as a data pipeline source for MySQL. You must select an on-prem group in the Connection type field.
Connect to MySQL ​
Complete the following steps to connect to MySQL:
Connect to MySQL
Search for MySQL and select it as your app.
Select an on-prem group in the Connection type field.
Don't select Cloud. Cloud connections aren't supported for MySQL as a data pipeline source and prevent objects from loading.
Enter the hostname of your MySQL instance in the Host field.
Enter the port number in the Port field. The default MySQL port is 3306.
Enter your MySQL username in the Username field.
Enter your MySQL password in the Password field.
Enter the name of the database to sync in the Database field.
Optional. Expand Advanced settings to configure the following:
Toggle Use improved datetime handling to enable enhanced handling of date, datetime, and timestamp data types. Defaults to true.
Set the Database timezone field to the local timezone of your database. Default is UTC.
12
Select Connect to verify and save the connection.
Configure the pipeline ​
Complete the following steps to configure MySQL as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from MySQL.
Use the Your Connected Source Apps drop-down menu to select MySQL.
Choose the MySQL connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Add objectsAdd objects
Search or browse the list of available MySQL objects, select the objects to sync, and click Add.
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before syncing to your destination.
Workato recommends hashing personally identifiable information (PII) and other sensitive fields.
12
Click Add object again to add more objects. Repeat this step to include additional MySQL objects in your pipeline.
13
14
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from MySQL to the destination.
Supported MySQL objects ​
MySQL data pipelines sync data from tables in your connected database.
MySQL limitations ​
The following limitations apply when you use MySQL as a data pipeline source:
Minimum sync frequency ​
