Configure Salesforce as a data pipeline source
Set up Salesforce as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with Salesforce as a source.
Workato uses the Salesforce Bulk API v2 to extract and sync data efficiently at scale.
Salesforce features supported
The following features are supported when using Salesforce as a data pipeline source:
- Extract data from standard and custom Salesforce objects
- Support for full and incremental sync
- Field-level selection for object extraction
- Schema drift detection and handling
- Field-level data masking
Salesforce prerequisites
You must have the following permissions to connect to and extract data from Salesforce:
- An active Salesforce user account with API access
- Read access to the objects and fields included in the pipeline
How to connect
Complete the following steps to connect to Salesforce as a data pipeline source. This connection lets the pipeline extract data from Salesforce.
Workato supports OAuth 2.0 for data pipelines, which provides a more secure and scalable authentication method compared to alternative connection types.
Connect to Salesforce
Search for Salesforce and select it as your app.
Salesforce connection setup
Use the Sandbox drop-down menu to specify whether the connection is a sandbox account.
Select OAuth 2.0 as the Auth type. This is the default and only supported authentication method for data pipelines.
Optional. Expand Advanced settings to configure advanced connection options.
Optional. Select a Custom OAuth profile to restrict the connection to specific scopes. This ensures the authentication flow uses the client app linked to the custom profile.
Select Connect and enter your Salesforce account credentials when prompted.
Log in to your Salesforce account
Select Log In to verify the connection.
Configure the pipeline
Complete the following steps to configure Salesforce as your data pipeline source:
Data pipeline setup
Click Start building.
Use the Your Connected Source Apps drop-down menu to select Salesforce.
Choose the Salesforce connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose a Salesforce connection
Click Add object to open the object wizard.
Add object
Search or browse the list of available Salesforce objects. Select the objects you plan to sync and click Add.
Add object
Expand object
You can expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
Workato recommends hashing personally identifiable information (PII) and other sensitive fields.
Optional. Click the gear icon next to an object to open its settings, then complete the following steps:
Use the Sync mode drop-down menu to select Full sync or Incremental. Workato defaults to Full sync if it doesn't detect a timestamp for the object.
Optional. Enter a SOQL condition in the SOQL WHERE clause field, without the WHERE keyword, to filter which records sync for the object. For example, enter StageName = 'Closed Lost' for the Opportunity object to sync only closed-lost opportunities.
Click Save.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Salesforce objects in your pipeline.
Optional. Use the Relax Numeric Fields drop-down menu to select Yes to convert Salesforce numeric fields to double-precision floating point values in the destination. This lets the destination safely handle values with higher precision and scale.
Optional. Enter a value in the Concurrency limit field to cap the number of concurrent operations. Leave the field blank to use the default quota set by Workato. The maximum value is 100.
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Salesforce to the destination.
Supported Salesforce objects
The pipeline supports most Salesforce standard and custom objects with read permissions. Workato uses the Salesforce Bulk API v2 to fetch object records.
