Configure SQL Server as a data pipeline source ​
Set up SQL Server as a data pipeline source to extract and sync records into your destination. Use this guide to set up a connection, configure your pipeline, add objects, review sync behavior, and understand known limitations.
SQL Server features supported ​
The following features are supported when you use SQL Server as a pipeline source:
FeatureDetails
On-prem connectivityConnect to SQL Server through an on-prem group. Cloud connections aren't supported for data pipelines.
Full sync and incremental syncSupports full sync and incremental sync modes. Incremental sync uses SQL Server Change Tracking or Change Data Capture (CDC). CDC is the default when both are enabled on a table. Refer to Sync modes for more information.
Table-level object selectionSelect individual SQL Server tables to sync as objects in your pipeline. Tables across multiple schemas in the connected database are supported. Refer to Configure the pipeline for more information.
Schema drift detection and handlingDetect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
Configurable sync frequencySchedule syncs on a time-based interval. The minimum supported interval is 15 minutes.
SQL Server prerequisites ​
Connecting SQL Server as a data pipeline source requires:
  • A SQL Server instance reachable from your on-prem agent host
  • An on-prem agent running version 30 or above. Refer to the on-prem agent documentation for setup steps.
  • A SQL Server user with SELECT and VIEW DEFINITION permissions on the tables you plan to sync. Incremental sync requires additional permissions, such as VIEW CHANGE TRACKING. Refer to Enable Change Tracking or Enable Change Data Capture for more information.
  • A primary key on each table you plan to sync
  • The host, port, database name, username, and password for your SQL Server instance
  • Change Tracking or CDC enabled on your SQL Server database and on each table you plan to sync incrementally. Refer to Enable Change Tracking or Enable Change Data Capture for setup steps.
Enable Change Tracking ​
Incremental sync by Change Tracking uses SQL Server Change Tracking to detect row-level inserts, updates, and deletes. Your database administrator must enable it at both the database and table level before the pipeline can run incremental syncs with this method. Refer to the Microsoft Enable and disable change tracking documentation for more information.
Enable Change Tracking at the database level:
sql
ALTER DATABASE CURRENT SET CHANGE_TRACKING = ON (CHANGE_RETENTION = 7 DAYS, AUTO_CLEANUP = ON)
Set a data retention period longer than the longest time period a pipeline can be paused, including planned maintenance. Workato recommends a minimum retention of 3 days. Seven days provides a safe buffer if pipelines are paused or delayed. Incremental sync fails if a pipeline is paused longer than the retention period. Refer to Change history retention for more information.
Enable Change Tracking at the table level for each table you plan to sync:
sql
ALTER TABLE [schema].[table_name] ENABLE CHANGE_TRACKING WITH (TRACK_COLUMNS_UPDATED = ON)
Repeat the table-level command for each table you plan to add as an object in your pipeline. TRACK_COLUMNS_UPDATED = ON is optional. It records which columns changed, which uses additional storage.
Grant the Workato user the VIEW CHANGE TRACKING permission on each table you plan to sync incrementally. Workato requires this permission to query the Change Tracking log:
sql
GRANT VIEW CHANGE TRACKING ON OBJECT::[schema].[table_name] TO [workato_user]
Use ON SCHEMA::[schema] instead of ON OBJECT::[schema].[table_name] to grant the permission on every table in a schema.
Enable Change Data Capture ​
Incremental sync by Change Data Capture (CDC) reads net changes from SQL Server CDC change tables. Refer to the Microsoft Enable and disable change data capture documentation for more information.
Ensure you meet the following requirements to use CDC:
  • CDC is enabled at the database and table level by your database administrator
  • SQL Server Agent is running
  • You have SQL Server Enterprise, Standard, or Developer edition
UNSUPPORTED EDITIONS
SQL Server Express and Web editions don't support CDC.
Enable CDC at the database level ​
Run the following command to enable CDC on your database. This command requires the sysadmin role:
sql
USE <your_database>;
EXEC sys.sp_cdc_enable_db;
Enable CDC at the table level ​
Run the following command for each table you plan to sync. This command requires the db_owner role:
sql
EXEC sys.sp_cdc_enable_table
    @source_schema = N'<schema>',
    @source_name   = N'<table_name>',
    @role_name     = NULL,
    @supports_net_changes = 1;
You must set @supports_net_changes = 1. Workato reads net changes, which collapse multiple changes to the same row into a single row with its final state. Net changes require a primary key or a unique index specified with @index_name, and Workato requires a primary key on every table you sync. Workato can't use CDC on tables enabled without net changes.
Grant access to CDC change data ​
Run the following command to let the Workato user read CDC change data:
sql
GRANT SELECT ON SCHEMA::cdc TO <workato_user>;
The table-level example sets @role_name to NULL, so no gating role restricts access to the change data. If you specify a gating role, add the Workato user to it:
sql
ALTER ROLE <gating_role> ADD MEMBER <workato_user>;
Verify that SQL Server Agent is running ​
Ensure that SQL Server Agent is running. CDC captures changes through a SQL Server Agent job, so the change tables stay empty until the agent runs. SQL Server Agent is disabled by default on Linux. Run the following commands to enable it and restart SQL Server:
shell
sudo /opt/mssql/bin/mssql-conf set sqlagent.enabled true
sudo systemctl restart mssql-server
For a new SQL Server container, set the MSSQL_AGENT_ENABLED=true environment variable when you create the container instead.
Keep SQL Server Agent running while CDC is enabled. SQL Server can't truncate the transaction log past changes the capture job hasn't read, so the log can keep growing while the capture job is stopped.
Confirm CDC is enabled ​
Run the following query to confirm CDC is enabled with net changes on a table:
sql
SELECT capture_instance, supports_net_changes
FROM cdc.change_tables
WHERE OBJECT_SCHEMA_NAME(source_object_id) = '<schema>'
  AND OBJECT_NAME(source_object_id) = '<table_name>';
Supported connection types ​
SQL Server pipelines support username and password authentication through an on-prem group. You must have a SQL Server username and password to connect.
CLOUD CONNECTIONS NOT SUPPORTED
Cloud connections aren't supported as a data pipeline source for SQL Server. You must select an on-prem group in the Connection type field.
Connect to SQL Server ​
Complete the following steps to connect SQL Server as a data pipeline source.
Search for SQL Server and select it as your app.
Configure your SQL Server connectionConfigure your SQL Server connection
Select an on-prem group in the Connection type field.
Don't select Cloud. Cloud connections aren't supported for SQL Server as a data pipeline source and prevent objects from loading.
Enter the hostname of your SQL Server instance in the Host field.
Enter the port number in the Port field. The default SQL Server port is 1433.
Enter your SQL Server username in the Username field.
Enter your SQL Server password in the Password field.
Enter the name of the database you plan to sync in the Database field.
Optional. Expand Advanced settings to configure the following:
FieldDescription
Use improved datetime handlingEnable enhanced handling of datetime, datetime2, and datetimeoffset data types. Defaults to true. Refer to the Improved datetime handling section for more information.
Database timezoneSet the local timezone of your database. When timezones are provided for datetime and datetime2 values, Workato converts them to this timezone before processing. Default is UTC.
12
Optional. Expand SSL settings to configure certificate-based security for your connection:
FieldDescription
Server certificateProvide the X.509 server certificate in .pem format.
SSL certificateProvide the X.509 client certificate in .pem format.
SSL certificate keyProvide the RSA client key in .pem format.
Trust allForces the client to trust any certificate chain. Enables support for self-signed server certificates.
13
Optional. Expand Pooling settings to configure connection pool behavior:
FieldDescription
Minimum pool sizeEnter the minimum number of connections the on-prem agent maintains in the pool, including idle and in-use connections. Default is 1.
Maximum pool sizeEnter the maximum number of connections in the pool. When the pool reaches this quota and no idle connections are available, new connection attempts block until the timeout is reached. Default is 10.
Idle timeoutEnter the maximum time, in seconds, a connection can sit idle in the pool before removal. A value of 0 means connections aren't removed. Default is 600 seconds (10 minutes).
Maximum lifetimeEnter the maximum lifetime, in seconds, of a connection in the pool. Connections that reach this quota are removed even if they were recently used. Default is 1800 seconds (30 minutes).
TimeoutEnter the maximum time, in seconds, to wait for a connection from the pool. A value of 0 means no timeout. Default is 30 seconds.
14
Optional. Expand Additional properties for SQL Server connection and select Add parameter to pass additional JDBC connection parameters.
15
Select Connect to verify and save the connection.
Configure the pipeline ​
Complete the following steps to configure SQL Server as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from SQL Server.
Use the Your Connected Source Apps drop-down menu to select SQL Server.
Choose the SQL Server connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Add objectsAdd objects
Search or browse the list of available SQL Server objects, select the objects you plan to sync, and click Add.
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before syncing to your destination.
Workato recommends hashing personally identifiable information (PII) and other sensitive fields.
12
Click Add object again to add more objects. Repeat this step to include additional SQL Server objects in your pipeline.
13
14
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from SQL Server to the destination.
Supported SQL Server objects ​
SQL Server data pipelines sync data from tables in your connected database. Workato discovers available tables across all schemas in the connected database when you select Add object during pipeline configuration. You can add one or more tables as objects in your pipeline. Views aren't supported. Tables without Change Tracking or CDC enabled are still listed and can use full sync.
Sync modes ​
SQL Server data pipelines support full sync and incremental sync. The sync mode is configured per object when you add it to your pipeline.
Full sync ​
A full sync reads all rows from the source table on every pipeline run. Use full sync for tables where you need a complete snapshot of the data on each sync.
Each table merges into the existing destination table, so rows deleted in SQL Server stay in the table.
Incremental sync ​
An incremental sync extracts only rows that changed since the last successful sync run. Workato supports the following incremental sync methods:
  • Change Data Capture (CDC): Available when CDC is enabled on the table with net changes. Workato reads net inserts, updates, and deletes from the table's CDC change tables. Refer to Enable Change Data Capture for setup steps.
  • Change Tracking: Available when Change Tracking is enabled on the database and table. Workato queries the Change Tracking log to detect row-level inserts, updates, and deletes. Refer to Enable Change Tracking for setup steps.
Workato uses CDC by default when a table has both CDC and Change Tracking enabled. You can change the incremental sync method for the object.
Delete tracking ​
Incremental sync by CDC or Change Tracking reports deleted rows through the synthetic _workato_is_deleted column. Deleted rows keep key column values, so the destination can identify which rows were deleted. Full sync doesn't track deletes. Refer to Full sync for more information.
Identifier handling ​
Workato pipelines translate source column names into valid destination identifiers by applying the following rules:
  • Column names are uppercased.
  • Special characters such as $, spaces, or dashes are replaced with underscores (_).
  • Identifiers are wrapped in square brackets to protect against reserved words.
For example, the source column $Name$ becomes [_NAME_] in the destination table.
SQL Server limitations ​
The following limitations apply when you use SQL Server as a data pipeline source:
No objects displayed ​
If the pipeline doesn't display objects when you select Add object, check that you selected an on-prem group in the Connection type field. The pipeline can't discover tables over a cloud connection.
No objects errorNo objects error
Change history retention ​
Incremental sync by Change Tracking or CDC depends on the change history SQL Server retains. If a pipeline is paused longer than the retention window, its saved cursor falls outside the retained history and the next run fails. You must re-sync the object to resume incremental sync.
CDC cleans up change data after three days by default. Run the following command to increase the CDC retention period if you expect long pauses. The @retention value is in minutes, and this example sets retention to seven days:
sql
EXEC sys.sp_cdc_change_job @job_type = N'cleanup', @retention = 10080;
The new value applies the next time the cleanup job runs. Run SELECT job_type, retention FROM msdb.dbo.cdc_jobs; to confirm the setting.
Refer to Enable Change Tracking for the Change Tracking retention setting.
Column changes after CDC is enabled ​
CDC doesn't capture columns added to a table after CDC was enabled on it, so those columns don't sync. Your database administrator must create a new capture instance for the table or disable and re-enable CDC to capture new columns. Run a full sync on the object to include the new columns. Workato uses the most recently created capture instance when a table has two capture instances.
Columns dropped after CDC is enabled appear as NULL values in later changes.
Switching incremental sync methods ​
Change Tracking and CDC store different types of cursors, and neither method can resume from the other's cursor. The next run fails if you change the incremental sync method for an existing object. Run a full sync on the object to reinitialize the cursor.
On-prem agent version requirement ​
Workato requires on-prem agent version 30 or above to support SQL Server data pipelines. Earlier versions aren't supported. Workato recommends using the latest available version.
Minimum sync frequency ​
