Transformation techniques ​
Effective data transformation is crucial for preparing your data to meet specific business requirements. Workato provides various methods to transform data efficiently and accurately. This section introduces you to the different transformation techniques available, ensuring you can choose the approach for your needs.
Built-in formulas for simple transformations ​
Workato offers a wide range of built-in formulas suitable for performing simple data transformations. These formulas simplify common data manipulation tasks, allowing you to quickly prepare your data for further processing or analysis.
The following data types are supported:
Custom code transformations ​
For more complex transformation needs, Workato supports custom code transformations. This feature allows you to write custom scripts to handle specific data manipulation tasks that are not covered by built-in formulas. You can use the following languages:
SQL-based transformation ​
Workato enables you to perform SQL-based transformations on your data. This method is powerful for integrating with database connectors and leveraging the full capabilities of SQL. For more information, refer to our SQL-based transformations section.
