JWT direct linking
JSON Web Token (JWT) is an open standard that defines a compact and self-contained method for securely transmitting information between two parties as a JSON object. JWTs are signed with private/public key pairs, which verify the integrity of the token and add an additional layer of security.
JSON Web Tokens authenticate users and provide verified access to applications and resources. Generate a JWT before implementing any Workato Embedding models.
JWT direct linking consists of the following steps:
Prerequisites
The following information is required to implement JWT direct linking:
Private and public key pair
Required. The JWT token must be signed using a private key generated with the RS256 algorithm. The key must be formatted as PEM, and can follow either the PKCS#1 or PKCS#8 standard, as long as RS256 is used. PKCS#1 is used only for RSA private keys, and contains only the RSA private key material, such as the modulus, public exponent, private exponent, and more. PKCS#1 is commonly used with
openssl genrsa. PKCS#8 is for private keys of any algorithm, such as RSA, EC, DSA, and more. PKCS#8 wraps the key into a generic, standardized format with algorithm identification, and is commonly used withopenssl genpkey. Workato uses the public key to verify the generated JWT tokens. Use the Update JWT signing key API to set the public key or provide the public key to your Workato Success Representative.Embedded vendor ID
Required. The Embedded vendor ID is required to generate the JWT. Use the vendor ID returned by the Update JWT signing key API or obtain it from your Workato Success Representative after providing your public key.
Customer workspace ID
Required. The customer workspace ID uniquely identifies the Embedded customer. Obtain the customer workspace ID from the UI by navigating to the Admin console and selecting the specific customer. When selected, the customer workspace ID appears in the URL. Alternatively, fetch the customer workspace ID by calling our get customer API. If using an external ID instead of the Workato ID, the segment should start with the prefix
E.Customer user ID
Optional. The customer user ID uniquely identifies an individual workspace member in the customer workspace. Include the customer user ID when the user's specific role must apply to the Workato session being created. You can fetch the customer user ID by calling our get customer workspace member API. Ensure each user is created using the add member to customer workspace API per customer team. If using an external ID instead of the Workato ID, the segment should start with the prefix
E.Origin URL
Required. The origin URL is the default domain where you embed the Workato
iframe. Include the origin URL in the JWT payload when the Workatoiframeis fully embedded within a partner's application. Additionally, include it when using the Auth Widget with multiple origin URLs allowlisted in the OEM Config. Provide your Workato Success Representative with the origin URL.
Step 1: Generate a private and public key pair
Generate a private key
To generate the private key from scratch, use the following:
$ openssl genrsa -out private.key 2048
$ cat private.key
-----BEGIN RSA PRIVATE KEY-----
-----END RSA PRIVATE KEY-----Generate a public key
Then, extract the public key using the following:
$ openssl rsa -in private.key -pubout -out public.key
$ cat public.key
-----BEGIN PUBLIC KEY-----
-----END PUBLIC KEY-----Convert keys to PEM format
If you used a different method to generate your public/private key pair, convert your keys to PEM format before sending them to Workato.
To convert from an SSH public key:
$ ssh-keygen -f key.pkcs -e -m pem > key.pemStep 2: Install a direct link URL generation microservice
The purpose of the direct link URL microservice is to automatically generate a JWT when needed to facilitate access to secure resources. Install a direct link URL microservice to your server.
The microservice must meet the following specifications:
- The endpoint must require vendor authentication.
- The microservice must accept the path to the Workato asset.
- The microservice must generate a URL with the following structure:
https://app.workato.com/direct_link/<resource_path>?<query_params>#<fragment>Example microservice:
import nanoid from 'nanoid';
import {sign} from 'jsonwebtoken';
function getToken(WorkatoEmbeddedVendorId, customerAccountId, privateKey) {
return sign({
sub: `${WorkatoEmbeddedVendorId}:${customerAccountId}`,
jti: nanoid()
privateKey,
algorithm: 'RS256'
}Step 3: JWT direct linking
JWT structure
A JWT consists of a header, payload, and signature. In their compact form, JWT sections are separated by ..
header.payload.signature- Header
- The first part of the token is the header. The header usually consists of two parts: the type of token and the type of algorithm used to generate the signature.
- Payload
- The second part of the token is the payload, which contains the claims. Claims are statements about the user and additional data.
- Signature
- The final part of the token is the signature. Signatures verify the integrity of the claims.
Direct link URL
You must generate a JWT token on your server and construct the direct link URL. The direct link URL format differs depending on the CX option you plan to implement.
Embedded connection widget
The direct link URL format for the Embedded connection widget should match the following examples. For more information on direct link URLs for other widgets, refer to Constructing a direct link URL.
Workato accounts hosted in the US Data Center
https://app.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the Europe Data Center
https://app.eu.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the Singapore Data Center
https://app.sg.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the Japan Data Center
https://app.jp.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the Australia Data Center
https://app.au.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the Israel Data Center
https://app.il.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the China Data Center
https://app.workatoapp.cn/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Workato accounts hosted in the South Korea Data Center
https://app.kr.workato.com/direct_link/embedded/connections/<connection_id>?workato_dl_token=<jwt_token>Fully Embedded
The direct link URL format for Fully Embedded should match the following examples:
https://app.workato.com/direct_link?workato_dl_path=<workato_path>&workato_
https://app.eu.workato.com/direct_link?workato_dl_path=<workato_path>&workat
https://app.sg.workato.com/direct_link?workato_dl_path=<workato_path>&workat
https://app.jp.workato.com/direct_link?workato_dl_path=<workato_path>&workat
https://app.au.workato.com/direct_link?workato_dl_path=<workato_path>&workat
https://app.il.workato.com/direct_link?workato_dl_path=<workato_path>&workat
https://app.workatoapp.cn/direct_link?workato_dl_path=<workato_path>&workat
https://app.kr.workato.com/direct_link?workato_dl_path=<workato_path>&workat
o_dl_token=<jwt_token>Branded access SSO
The direct link URL format for Branded access SSO should match the following examples:
https://app.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the Europe Data Center
https://app.eu.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the Singapore Data Center
https://app.sg.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the Japan Data Center
https://app.jp.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the Australia Data Center
https://app.au.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the Israel Data Center
https://app.il.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the China Data Center
https://app.workatoapp.cn/direct_link/recipes?workato_dl_token=<jwt_token>Workato accounts hosted in the South Korea Data Center
https://app.kr.workato.com/direct_link/recipes?workato_dl_token=<jwt_token>Generate a JWT
Generating a JWT consists of the following steps:
Step 1: Configure the header
- alg
- Set the
algclaim to RS256, the algorithm used to generate the signature. - typ
- Set the
typclaim to JWT, the type of token used.
Example:
"alg": "RS256",
"typ": "JWT"
}Step 2: Configure the payload
- sub
- Set the
subclaim to:
<workato_embedded_vendor_id>:<customer_team_id>:<customer_user_id>PREREQUISITES
Visit the Prerequisites section for detailed instructions on obtaining the Embedded vendor ID, customer workspace ID, and customer user ID.
- iat
- Set the
iatclaim to the current time in epoch. - jti
- Set the
jticlaim to a globally unique value. Use the value only one time in a 10-minute duration. - origin
- The origin claim is required when the connection
iframeis embedded in two or more origins.
MULTIPLE ORIGINS
If you are embedding the Connection Widget in multiple domains, you must configure the origin URL in each customer workspace. To override the origin URL in an individual account, go to the Admin console > manage customers, and access the relevant customer workspace. Access the settings menu and update the origin URL.
Example:
"sub": "911672h4203fae7ffbe2eca1bbcaa79cc8c47af5377a6c6240:303363:313646",
"iat":"1624043461",
"jti": "3oay2t2kntGbxr1yhSINn",
"origin": "http://www.acme.com"
}See more JWT microservice examples.
Step 3: Sign the JWT
Sign the JWT with your private key generated with the RS256 algorithm in Step 1. The private key must match the public key previously provided to Workato.
