On-prem runtime and performance issues ​
This guide covers issues that can occur during the on-prem agent (OPA) runtime. These include heap space errors, logging errors, long query errors, and jobs stuck due to dropped database connections.
Java heap space errors ​
The following error log indicates the agent has reached its memory quota:
java.lang.OutOfMemoryError: Java heap space
This error indicates that OPA doesn't have enough memory to process large jobs or payloads. By default, the heap size is set to a fraction of available system memory.
Resolve gateway names on servers with OPA installed ​
You may encounter the following errors when resolving Workato gateway names on servers with OPA installed:
  • sg3.workato.com
  • sg4.workato.com
Complete the following troubleshooting steps to resolve gateway names:
Connect to the server where your OPA instance runs.
Open your server's console.
Run the following commands to verify if the gateway names can be resolved from your Windows, Linux, and Mac server:
nslookup sg3.workato.com
Run the following command on Linux and Mac servers to verify if the gateway names can be resolved:
dig sg3.workato.com
Your output is similar to the following:
bash
sg3.workato.com	canonical name = public-v10-awsprod-opg3-nlb-d6da47859547995a.elb.us-east-1.amazonaws.com.
Address: 54.224.75.148
Address: 52.206.161.203
Address: 52.204.114.159
This successful output indicates that it is possible to resolve the domain name.
Check gateway connectivity ​
You may encounter issues with establishing gateway connectivity on servers with OPA installed.
Complete the following troubleshooting steps to check gateway connectivity:
bash
curl -k -vvv -GET --no-alpn --key conf/cert.key --cert conf/cert.pem https://sg3.workato.com/gateway/ping
bash
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
(LINES SKIPPED)
< HTTP/1.1 200 OK
< Content-Type: application/json
< Date: Mon, 25 Jul 2022 21:33:42 GMT
< Content-Length: 81
{"gateway_version":"1.0.1","os_platform":"linux","os_release":"4.19.0-10-amd64"}
Verify the server certificate chain ​
You may encounter issues verifying the server certificate chain on servers with OPA installed.
Complete the following troubleshooting steps to verify the server certificate chain:
Go to your OPA installation folder. Refer to the Accessing on-prem documentation for more information about installation.
Download the Workato root certificate and save it in your OPA installation folder. Refer to the HTTP SSL documentation for instructions.
Run the following command for Linux and Mac:
bash
curl -vvv -GET --no-alpn --cacert root_ca_cert.pem --key conf/cert.key --cert conf/cert.pem https://sg3.workato.com/gateway/ping
The expected output contains the following:
SSL certificate verify ok
This indicates that the server certificate chain was successfully verified.
OPA stopped creating logs ​
You may encounter an issue where OPA stops generating logs when running on Linux. This issue occurs when there is either no free space remaining on the disk or when the logging level settings are incorrect. Complete the following troubleshooting procedure to resolve this issue:
Run the following command to determine if there is free space left on the disk:
bash
df -h
cat /etc/fstab
parted -l
This determines if the issue is related to disk space.
Verify that the logging permissions are correct.
Run ls -lah /var/log/workato-agent to view log permissions.
Run the following command if a user or group does not have permissions set to workato:
bash
chown -R workato:workato /var/log/workato-agent
Check that the logging level is set to debug in the config file. For example:
logger: debug
Jobs stuck indefinitely due to dropped TCP connections ​
Jobs that hang without producing an error or timeout are often caused by a firewall or NAT device silently dropping an idle TCP connection between OPA and the database. The JVM thread holding the socket receives no notification and waits indefinitely for a response.
You can configure TCP keepalive at the OS level to periodically probe idle connections and detect when they drop, allowing the stuck thread to fail and recover.
GLOBAL SETTINGS
Keepalive settings typically affect all applications on the host, not just the Workato OPA.
Long query error ​
You may encounter the following error when using the On-prem files connector with a database connector, such as MySQL:
Long query error: java.lang.IllegalArgumentException: Missing files profile laws rds cx
This error occurs when the On-prem files connector and a database connector use different on-prem groups. Set both connections to use agents in the same on-prem group to resolve this error.
