| Anaplan | - Run data import: Run a data import process in Anaplan.
- Run data export: Run a data export process in Anaplan.
- Run deletion: Run a delete action in Anaplan.
- Run process: Run a process in Anaplan.
| Azure OpenAI | Generate images: Generates images in Azure OpenAI. |
| Google BigQuery | - Search rows: Searches rows in Google BigQuery.
- Search rows using custom SQL: Searches rows in Google BigQuery using custom SQL.
- Run custom sql in BigQuery: Runs custom SQL in Google BigQuery.
- Load data into BigQuery: Loads data into Google BigQuery.
- Select rows: Selects rows in a table in Google BigQuery.
- Select rows using custom SQL: Selects rows in Google BigQuery using custom SQL.
- Select rows using custom SQL and insert into table: Selects rows using custom SQL and inserts rows into a table in Google BigQuery.
- Load data from Google Cloud Storage into BigQuery: Loads data from Google Cloud Storage into Google BigQuery.
| Google Sheets | Update rows in bulk: Updates rows in bulk in Google Sheets. |
| Hubspot | - Import CRM Data: Imports CRM data in Hubspot.
- Export object data: Export content from HubSpot to a file. You can use the file contents in subsequent recipe steps to upload the file into other applications.
| Marketo | - Bulk import objects from file: Bulk imports objects from a file in Marketo.
- Bulk export objects from file: Bulk exports objects from a file in Marketo.
| Netsuite | - Create standard records in bulk: Creates standard records in bulk in Netsuite.
- Update standard records in bulk: Updates standard records in bulk in Netsuite.
- Upsert standard records in bulk: Upserts standard records in bulk in Netsuite.
- Create custom records in bulk: Creates custom records in bulk in Netsuite.
- Update custom records in bulk: Updates custom records in bulk in Netsuite.
- Upsert custom records in bulk: Upserts custom records in bulk in Netsuite.
| Salesforce | - Create records in bulk from CSV file: Creates records in bulk from a CSV file in Salesforce.
- Update records in bulk from CSV file: Updates records in bulk from a CSV file in Salesforce.
- Upsert records in bulk from CSV file: Upserts records in bulk from a CSV file in Salesforce.
- Create records in bulk from CSV file (API 1.0): Creates records in bulk from a CSV file in the Salesforce API 1.0.
- Update records in bulk from CSV file (API 1.0): Updates records in bulk from a CSV file in the Salesforce API 1.0.
- Upsert records in bulk from CSV file (API 1.0): Upserts records in bulk from a CSV file in the Salesforce API 1.0.
- Retry bulk job for failed records from CSV file: Retry a bulk job for failed records from a CSV file in Salesforce.
- Search records in bulk using SOQL query (API 1.0): Searches records in bulk using a SOQL query in Salesforce API 1.0.
- Search records in bulk using SOQL query (API 2.0): Searches records in bulk using a SOQL query in the Salesforce API 2.0.
| SAP RFC | - Call remote function module: Calls a remote function module in SAP RFC.
- Call BAPI: Calls BAPI in SAP RFC.
| Shopify | - Reorder product media using GraphQL: Reorders product media using GraphQL in Shopify.
- Create file using GraphQL: Creates a file using GraphQL in Shopify.
| JSON Transformations by Workato | JSON transformation: Executes a JSON transformation in JSON Transformations by Workato. |
| RPA by Workato | Start job: Starts a job in RPA by Workato. |
| Callable recipes by Workato | Wait for async calls: Waits for specified async calls to complete before proceeding to the next step in Callable recipes by Workato. |
| SQL Transformations by Workato | Query data: Queries data in SQL Transformations by Workato. |
| Workato Data Tables | - Create record: Creates a record in Workato Data Tables.
- Create records (batch): Creates records in batches in Workato Data Tables.
- Update record: Updates a record in Workato Data Tables.
- Update records (batch): Updates records in batches in Workato Data Tables.
- Upsert record: Upserts a record in Workato Data Tables.
- Upsert records (batch): Upserts records in batches in Workato Data Tables.
These actions run as long actions only while uploading values into the data table's file-type columns. The job pauses between uploads. |
| Wrike | Create from blueprint: Creates from blueprint in Wrike. |
| Zendesk | Create/update record: Creates/updates a record in Zendesk. |
| Zoho CRM | - Bulk create standard objects: Bulk creates standard objects in Zoho CRM.
- Bulk update standard objects: Bulk updates standard objects in Zoho CRM.
- Bulk upsert standard objects: Bulk upserts standard objects in Zoho CRM.
- Bulk create custom objects: Bulk creates custom objects in Zoho CRM.
- Bulk update custom objects: Bulk updates custom objects in Zoho CRM.
- Bulk upsert custom objects: Bulk upserts custom objects in Zoho CRM.
| HTTP | Send request (offload proxy): Sends an offload proxy request in HTTP. You can designate this HTTP action as a long action by setting the Wait for response field to Yes. |
| Google Workspace | Transfer Data: Transfers data in Google Workspace. |
| Nasuni Management Console | - Create share: Creates a share in Nasuni Management Console.
- Create volume: Creates a volume in Nasuni Management Console.
- Request snapshot volume: Requests a snapshot volume in Nasuni Management Console.
- Update share: Updates a share in Nasuni Management Console.
- Global lock folders: Manages global lock folders in Nasuni Management Console.
- Create directory: Creates a directory in Nasuni Management Console.
- Bring path into cache: Brings a path into the cache in Nasuni Management Console.
- Pin data to cache: Pins data to a cache in Nasuni Management Console.
- Disable pinning mode for folder: Disables pinning mode for a folder in Nasuni Management Console.
- Auto caching for file: Enables auto caching for files in Nasuni Management Console.
- Disable auto cache mode: Disables auto cache mode in Nasuni Management Console.
- Update folder quota: Updates folder quotas in Nasuni Management Console.
- Delete folder quota: Delete the folder quota in Nasuni Management Console.
| SQL Server | - Bulk load into table from an on-prem file: Bulk loads files into a table from an on-prem file in SQL Server.
- Export Query result: Exports a query result as a CSV in SQL Server.
- Run long query using custom SQL: Run long query using custom SQL: Runs a long query using custom SQL in SQL Server.
| Databricks | - Export query result: Exports a query result as a CSV in Databricks.
- Run long query using custom SQL: Runs a long query using custom SQL in Databricks.
| IBM Db2 | - Export query result: Exports a query result as a CSV in IBM Db2.
- Run long query using custom SQL: Runs a long query using custom SQL in IBM Db2.
| JDBC | - Export query result: Exports a query result as a CSV in JDBC.
- Run long query using custom SQL: Runs a long query using custom SQL in JDBC.
| Knack | - Export query result: Exports a query result as a CSV in Knack.
- Run long query using custom SQL: Runs a long query using custom SQL in Knack.
| MongoDB | - Export query result: Exports a query result as a CSV in MongoDB.
- Run long query using custom SQL: Runs a long query using custom SQL in MongoDB.
| MSSQL | - Export query result: Exports a query result as a CSV in MSSQL.
- Run long query using custom SQL: Runs a long query using custom SQL in MSSQL.
| MySQL | - Export query result: Exports a query result as a CSV in MySQL.
- Run long query using custom SQL: Runs a long query using custom SQL in MySQL.
| Oracle | - Export query result: Exports a query result as a CSV in Oracle.
- Run long query using custom SQL: Runs a long query using custom SQL in Oracle.
| PostgreSQL | - Export query result: Exports a query result as a CSV in PostgreSQL.
- Run long query using custom SQL: Runs a long query using custom SQL in PostgreSQL.
| Amazon Redshift | - Export query result: Exports a query result as a CSV in Amazon Redshift.
- Run long query using custom SQL: Runs a long query using custom SQL in Amazon Redshift.
| Snowflake | - Export query result: Exports a query result as a CSV in Snowflake.
- Run long query using custom SQL: Runs a long query using custom SQL in Snowflake.
