Developer API - Environment properties
Use the endpoints below to manage environment properties programmatically.
Rate limits
Environment property resources have the following rate limits:
| Type | Resource | Quota |
| All | All Environment properties endpoints | 60 requests per minute |
Quick reference
| GET | /api/properties | Lists environment properties that matches a prefix. |
| POST | /api/properties | Upserts environment properties. |
List properties by prefix
Returns a list of environment properties belonging to a customer that matches a prefix. For example, if the prefix provided is salesforce_sync., any environment property with a name beginning with 'salesforce_sync.' will be returned.
GET https://YOUR_DATA_CENTER/api/propertiesParameters
| Name | Type | Description |
| prefix | string required | Return properties with the given prefix. E.g: salesforce_sync.. |
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/properties?prefix=salesforce_sync.' \
-H 'Content-Type: application/json' \Response
json
"salesforce_sync.object_name": "Account",
"salesforce_sync.object_field": "Id"
}Upsert property
Upserts environment properties. Matches by the names of the properties provided in the request.
POST https://YOUR_DATA_CENTER/api/propertiesPROPERTY LIMITS
Environment properties have the following quotas:
| Description | Quota |
| Maximum number of environment properties per environment | 1,000 |
| Maximum length of an environment property name | 100 characters |
| Maximum length of an environment property value | 1,024 characters |
Payload
| properties | Hash required | Contains the names and values of the properties to upsert. |
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/properties \
-d '{ "properties": { ":property_key_1": ":property_value_1", ":property_key_2": ":property_value_2" }}'Response
json
"success": true
}Last updated:
