Developer API - Event streams
The following endpoints enable you to manage event topics.
API DOMAIN AND NAMESPACE DIFFERENCES FOR EVENT STREAMS
The Event streams APIs are divided into two categories. Each category uses a different domain and namespace.
Public API
The following endpoints use the event-streams domain:
- Consume messages
POST /api/v1/topics/:topic_id/consume - Publish a message
POST /api/v1/topics/:topic_id/publish - Publish a batch of messages
POST /api/v1/batch/topics/:topic_id/publish
Refer to the Event streams public API documentation for more information.
Developer API
The following endpoints use the standard Developer API base URL:
- List topics
GET /api/event_streams/topics - Create a topic
POST /api/event_streams/topics - Get a topic by ID
GET /api/event_streams/topics/:topic_id - Update a topic
PUT /api/event_streams/topics/:topic_id - Purge a topic
PUT /api/event_streams/topics/:topic_id/purge - Delete a topic
DELETE /api/event_streams/topics/:topic_id
Rate limits
Event streams developer API resources have the following rate limits:
| Type | Resource | Quota |
| All | All Event streams endpoints | 60 requests per minute |
Additionally, Event streams developer API resources have the following payload quota:
| All | All Event streams endpoints | Maximum payload size: 1 MB |
Quick reference
| GET | /api/event_streams/topics | Retrieve a list of topics. |
| POST | /api/event_streams/topics | Create a topic. |
| GET | /api/event_streams/topics/:topic_id | Get topic by ID. |
| PUT | /api/event_streams/topics/:topic_id | Update a topic. |
| PUT | /api/event_streams/topics/:topic_id/purge | Purge a topic. |
| DELETE | /api/event_streams/topics/:topic_id | Delete a topic. |
BEST PRACTICE
For endpoints that modify topics (create and update), we recommend that you define parameters in the request body instead of the URL.
List topics
Retrieves a list of event topics, with optional filtering, sorting, and the ability to include topic schemas in the response.
GET https://YOUR_DATA_CENTER/api/event_streams/topicsQuery parameters
| Name | Type | Description |
| name | string optional | Filters event topics by a case-sensitive title. Supports partial matching, which means you can search for fragments of the title. |
| sort | string optional | Defines how to sort the results. Options include activity (most recent activity first), name, and id. Set to id by default. |
| include_schema | boolean optional | When set to true, the schema of each event topic is included in the response payload. Set to false by default. |
Sample request
This request retrieves event topics that contain the keyword Order within the name. The results are sorted by event topic ID, and the schema for each event topic is included in the response payload.
curl -X GET "https://YOUR_DATA_CENTER/api/event_streams/topics?name=:name_value&sort=:sort_value&include_schema=:include_schema_value" \
-H 'Authorization: Bearer <api_token>'Response
"count": 2,
"data": [
"id": 334525,
"name": "Order placed",
"folder_id": 986754,
"created_at": "2024-09-25T09:47:54.089-07:00",
"updated_at": "2024-09-25T09:47:54.089-07:00",
"retention": 604800,
"schema": [
"control_type": "text",
"label": "Order ID",
"name": "OrderId",
"optional": false,
"type": "string"
"label": "Customer ID",
"name": "CustomerId",
"optional": false,
"type": "string"
"label": "Amount",
"name": "Amount",
"optional": false,
"type": "string"
"control_type": "date",
"label": "Order date",
"name": "OrderDate",
"optional": false,
"parse_output": "date_conversion",
"render_input": "date_conversion",
"type": "date_time"
"description": "Triggered when a new order is placed."
"id": 334526,
"name": "Order shipped",
"created_at": "2024-09-25T09:51:12.130-07:00",
"updated_at": "2024-09-25T09:51:12.130-07:00",
"schema": [
"name": "OrderId",
"optional": false,
"type": "string"
"label": "Shipping carrier",
"name": "ShippingCarrier",
"optional": false,
"type": "string"
"label": "Tracking number",
"name": "TrackingNumber",
"optional": false,
"type": "string"
"label": "Shipped date",
"name": "ShippedDate",
"optional": false,
"type": "date_time"
"description": "Triggered when an order is shipped."
}Create a topic
Creates a new event topic.
POST https://YOUR_DATA_CENTER/api/event_streams/topics| Name | Type | Description |
| name | string required | The name of the new topic. Topic names must be unique within a folder. |
| folder_id | number optional | The ID of the folder or project to store the topic inside. By default, Workato places the topic in your workspace's Event Streams project, creating that project if it doesn't already exist. |
| schema | array required | The schema definition for the new topic. Must adhere to a valid Workato schema format. |
| schema[control_type] | string required | The control type for a field in the topic schema. |
| schema[label] | string required | The label that appears for the field in the topic schema. |
| schema[name] | string required | The name identifier for the field in the topic schema. |
| schema[optional] | boolean required | Specifies whether the field is optional. |
| schema[type] | string required | The data type of the field in the schema. |
| retention | number optional | Retention time for the topic in seconds. Defaults to 168 hours (604,800 seconds) if not specified. |
| description | string optional | A description of the new topic. |
DEFAULT ACCESS FOR API TOPICS
Topics that you create through the Developer API are accessible only to the workspace owner by default. The workspace owner grants access to other collaborators by adding them to the project that contains the topic and assigning a project role that includes the Event streams privilege.
Sample request
This request creates a new event topic named Order delivered. The topic includes details such as the order ID, delivery date, and optional information about the person or service delivering the order.
curl -X POST "https://YOUR_DATA_CENTER/api/event_streams/topics" \
-d '{
"name": ":name",
"schema": [
"control_type": ":control_type",
"label": ":label",
"name": ":schema_name",
"optional": :true_or_false,
"type": ":type"
"retention": :retention_value,
"description": ":description"
}'Response
"data": {
"id": 334527,
"name": "Order delivered",
"created_at": "2024-09-25T09:56:32.986-07:00",
"updated_at": "2024-09-25T09:56:32.986-07:00",
"schema": [
"name": "OrderId",
"optional": false,
"type": "string"
"label": "Delivery date",
"name": "DeliveryDate",
"optional": false,
"type": "date_time"
"label": "Delivered by",
"name": "DeliveredBy",
"optional": true,
"type": "string"
"description": "Triggered when an order is delivered."
}Folder not found
The request fails and returns the following response if you supply a folder_id that doesn't exist:
"message": "Folder not found"
}Get topic by ID
Retrieves an event topic by its ID.
GET https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_idURL parameters
| topic_id | number required | The ID of the event topic to retrieve. |
Sample request
This request retrieves the Order delivered event topic by its unique :topic_id.
curl -X GET "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
"data": {
"id": 334527,
"schema": [
"name": "OrderId",
"optional": false,
"type": "string"
"optional": false,
"type": "date_time"
"optional": true,
"type": "string"
}Update a topic
Updates an event topic.
PUT https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_idURL parameters
| topic_id | number required | The ID of the event topic to update. |
| name | string optional | The name of the updated topic. |
| folder_id | number optional | The ID of the folder or project to move the topic to. By default, Workato places the topic in your workspace's Event Streams project, creating that project if it doesn't already exist. |
| schema | array optional | The schema definition for the updated topic. Must adhere to a valid Workato schema format. |
| schema[control_type] | string optional | The control type for a field in the topic schema. |
| schema[label] | string optional | The label that appears for the field in the topic schema. |
| schema[name] | string optional | The name identifier for the field in the topic schema. |
| schema[optional] | boolean optional | Specifies whether the field is optional. |
| schema[type] | string optional | The data type of the field in the schema. |
| description | string optional | A description of the updated topic. |
Sample request
This request updates the topic schema for the Order delivered event topic by adding a new field named Recipient.
curl -X PUT "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
-d '{
"name": ":name",
"schema": [
"label": ":label",
"type": ":type"
}'Response
"data": {
"id": 334527,
"schema": [
"name": "OrderId",
"optional": false,
"type": "string"
"optional": false,
"type": "date_time"
"optional": true,
"type": "string"
"label": "Recipient",
"name": "Recipient",
"optional": false,
"type": "string"
}Folder not found
}Purge a topic
Erases all messages from the event topic's history and resets topic statistics.
PUT https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id/purge| Name | Type | Description |
| topic_id | number required | The ID of the event topic to purge. |
Sample request
This request erases all messages from the Order delivered event topic's history and resets topic statistics.
curl -X PUT "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id/purge" \
"data": {
"status": "success"
}Delete a topic
Deletes an event topic.
DELETE https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_idURL parameters
| topic_id | number required | The ID of the event topic to delete. |
Sample request
This request deletes the Order delivered event topic.
curl -X DELETE "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
"data": {
"status": "success"
}Last updated:
