# API clients
The following endpoints allow you to manage your API clients via developer APIs. This allows you to programmatically create new API clients when onboarding new teams or rotate API tokens regularly for all your API clients.
# Rate limits
API client resources have the following rate limits:
Type Resource Limit
AllAll API client endpoints60 requests per minute
# Quick reference
Type Resource Description
GET /api/developer_api_clients List Developer API Clients.
POST /api/developer_api_clients Create Developer API Client.
GET /api/developer_api_clients/:id Get Developer API Client by ID.
PUT /api/developer_api_clients/:id Update Developer API Clients.
DELETE /api/developer_api_clients/:id Delete Developer API Client.
POST /api/developer_api_clients/:id/regenerate Regenerate Developer API Client token.
GET /api/developer_api_client_roles List Developer API Client roles.
# List Developer API clients
List all Developer API clients.
# Query parameters
Name Type Description
per_page integer Number of API clients to return in a single page. Defaults to 100. Max is 100.
page integer Page number of the API clients to fetch. Defaults to 1.
# Sample Request
curl  -X GET https://www.workato.com/api/developer_api_clients \
# Response
    "result": {
        "count": 3,
        "items": [
                "id": 40947,
                "name": "Test",
                "api_privilege_group_id": 26779,
                "created_at": "2023-02-22T01:55:35.739-08:00",
                "updated_at": "2023-02-28T01:23:18.046-08:00",
                "all_folders": false,
                "folder_ids": [
                    26138,
                    26136
                "environment_name": "Development",
                "environment_id": 3218,
                "token": {
                    "updated_at": "2023-02-22T09:55:36.427Z"
# Create a Developer API client
Create a Developer API client.
# Payload
name String Name of the API client
api_privilege_group_id integer API client role ID
all_folders boolean
required
Flag indicating whether API client has access to all folders
folder_ids array Array of folder IDs. Required if all_folders is false.
environment_name string Name of the environment. Required if your workspace has environments enabled.
# Sample Request
curl  -X POST https://www.workato.com/api/developer_api_clients \
      -d '{
            "name": "Test Client",
            "all_folders": true
# Response
    "result": {
        "id": 40948,
        "created_at": "2023-02-28T02:09:07.255-08:00",
        "updated_at": "2023-02-28T02:09:07.586-08:00",
        "all_folders": true,
        "token": {
            "updated_at": "2023-02-28T10:09:07.579Z",
            "value": "wrkaus-eyJhbGciOiJSUz..."
# Get a Developer API client by ID
Get a Developer API client by ID.
# Path parameters
id integer
required
ID of the API Client.
# Sample Request
curl  -X GET https://www.workato.com/api/developer_api_clients/123 \
# Response
    "result": {
        "id": 40948,
        "token": {
        "user": {
            "id": 3218,
            "name": "Workato Customer Success test"
# Update a Developer API client
Update a Developer API client.
# Path parameters
id integer
required
# Payload
all_folders boolean
required
# Sample Request
curl  -X PUT https://www.workato.com/api/developer_api_clients/123 \
      -d '{
            "all_folders": true
# Response
    "result": {
        "id": 40948,
        "token": {
        "user": {
            "id": 3218,
# Delete a Developer API client
Delete a Developer API client.
# Path parameters
id integer
required
# Sample Request
curl  -X DELETE https://www.workato.com/api/developer_api_clients/123 \
# Response
    "result": "success"
# Regenerate a Developer API Client token
Regenerates the API token for an API client. This invalidates the previous API token.
# Path parameters
id integer
required
# Sample Request
curl  -X POST https://www.workato.com/api/developer_api_clients/123/regenerate \
# Response
    "result": {
        "id": 40890,
        "name": "Test new API client",
        "created_at": "2023-01-29T22:30:12.930-08:00",
        "updated_at": "2023-02-28T02:19:16.542-08:00",
        "token": {
            "updated_at": "2023-02-28T10:19:16.530Z",
            "value": "wrkaus-eyJhbGc..."
# List Developer API client roles
List all Developer API Client roles.
# Query parameters
# Sample Request
curl  -X GET https://www.workato.com/api/developer_api_client_roles \
# Response
    "result": {
        "items": [
                "id": 26779,
                "name": "Admin",
                "created_at": "2023-01-18T04:31:03.302-08:00",
                "updated_at": "2023-02-28T01:23:01.427-08:00"
        "count": 3,
        "page": 1,
        "per_page": 100
Last updated: 7/30/2025, 9:23:28 PM
