API platform
The API platform APIs allow users to programmatically create and manage API Platform assets like endpoints, collections, clients, and access profiles.
API platform endpoints allow up to 10 requests per second.
Rate limits
API platform resources have the following rate limits:
TypeResourceLimit
AllAll API platform endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/api_collectionsList API collections. The endpoint returns the project_id of the project to which the collections belong in the response.
POST/api/api_collectionsCreate an API collection within a project you specify.
GET/api/api_endpointsList API endpoints in a collection.
PUT/api/api_endpoints/:api_endpoint_id/enableEnable an API endpoint in a collection.
PUT/api/api_endpoints/:api_endpoint_id/disableDisable an API endpoint in a collection.
GET/api/api_clientsList all API clients. We recommend that you migrate to the List API clients (v2) endpoint to prepare for future deprecation.
GET/api/v2/api_clientsList all API clients. Workato includes the project_id of the project associated with the API client in the response.
POST/api/api_clientsCreate a new API client within a project you specify. We recommend that you migrate to the Create API client (v2) endpoint to prepare for future deprecation.
POST/api/v2/api_clientsCreate a new API client within a project you specify.
GET/api/v2/api_clients/:api_client_idRetrieve details of an API client by ID.
PUT/api/v2/api_clients/:api_client_idUpdate an existing API client within a project you specify.
DELETE/api/v2/api_clients/:api_client_idDelete an existing API client.
GET/api/api_access_profilesList access profiles for an API client. We recommend that you migrate to the List API keys endpoint to prepare for future deprecation.
GET/api/v2/api_clients/:api_client_id/api_keysList API keys for an API client.
POST/api/api_access_profilesCreate an access profile for an API client. We recommend that you migrate to the Create API key endpoint to prepare for future deprecation.
POST/api/v2/api_clients/:api_client_id/api_keysCreate an API key for an API client.
PUT/api/api_access_profiles/:api_access_profile_idUpdate an access profile for an API client. We recommend that you migrate to the Update API key endpoint to prepare for future deprecation.
PUT/api/v2/api_clients/:api_client_id/api_keys/:api_key_idUpdate an API key for an API client.
PUT/api/api_access_profiles/:api_access_profile_id/enableEnable an access profile for an API client. We recommend that you migrate to the Enable API key endpoint to prepare for future deprecation.
PUT/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/enableEnable an API key for an API client.
PUT/api/api_access_profiles/:api_access_profile_id/disableDisable an access profile for an API client. We recommend that you migrate to the Disable API key endpoint to prepare for future deprecation.
PUT/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/disableDisable an API key for an API client.
PUT/api/api_access_profiles/:access_profile_id/refresh_secretRefresh the token or secret for an access profile. We recommend that you migrate to the Refresh API key secret endpoint to prepare for future deprecation.
PUT/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/refresh_secretRefresh the authentication token or OAuth 2.0 client secret for an API key.
DELETE/api/v2/api_clients/:api_client_id/api_keys/:api_key_idDelete an existing API key.
GET/api/v2/api_portalsList all API portals associated with API clients in your workspace.
GET/api/cert_bundlesList all certificate bundles.
POST/api/cert_bundlesCreate a new certificate bundle.
PUT/api/cert_bundles/:certificate_bundle_idUpdate a certificate bundle.
DELETE/api/cert_bundles/:certificate_bundle_idDelete a certificate bundle.
GET/api/cert_bundles/:certificate_bundle_id/downloadDownload the certificate bundle PEM file.
List all API collections. The endpoint returns the project_id of the project to which the collections belong in the response.
bash
GET https://YOUR_DATA_CENTER/api/api_collections
Query parameters
NameTypeDescription
per_pageintegerNumber of API collections to return in a single page. Defaults to 100. Max is 100.
pageintegerPage number of the API collections to fetch. Defaults to 1.
Response
json
        "id": 1361,
        "name": "Quote to cash",
        "version": "1.0",
        "url": "https://api.peatql.io/quote-to-cash-v1",
        "api_spec_url": "https://www.workato.com/doc/service/quote-to-cash-v1/swagger?token=4cab5bdf2cebbe2b4ahjkc9ac175f60c",
        "created_at": "2020-06-15T22:20:15.327-07:00",
        "updated_at": "2020-06-15T22:20:15.327-07:00",
        "project_id": "523144"
bash
POST https://YOUR_DATA_CENTER/api/api_collections
Query parameters
NameTypeDescription
project_idstring
required
The ID of a specific project. Retrieve a list of project IDs using the list projects endpoint.
Payload
NameTypeDescription
namestring
required
Name of the collection
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/api_collections?project_id=:project_id \
      -d '{
            "name": ":name"
Response
json
    "id": 1391,
    "name": "Netsuite customers",
    "version": "1.0",
    "url": "https://api.na.workato.com/abstergoi/netsuite-customers-v1",
    "api_spec_url": "https://www.workato.com/doc/service/netsuite-customers-v1/swagger?token=774513f8a712djkls90s7f5a3165eb96d",
    "created_at": "2020-07-31T08:24:31.439-07:00",
    "updated_at": "2020-07-31T08:24:31.439-07:00"
List API endpoints
Lists all API endpoints. Specify the api_collection_id to obtain the list of endpoints in a specific collection.
bash
GET https://YOUR_DATA_CENTER/api/api_endpoints
Query parameters
NameTypeDescription
api_collection_idstringID of the API collection. If the parameter is not provided, all API endpoints are returned.
per_pageintegerNumber of API endpoints to return in a single page. Defaults to 100. Max is 100.
pageintegerPage number of the API endpoints to fetch. Defaults to 1.
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/api_endpoints?api_collection_id=:api_collection_id' \
Response
json
      "id": 9903,
      "api_collection_id": 1391,
      "flow_id": 39999,
      "name": "salesforce search",
      "method": "GET",
      "url": "https://api.na.workato.com/abstergoi/netsuite-customers-v1/salesforce/search",
      "legacy_url": null,
      "base_path": "/abstergoi/netsuite-customers-v1/salesforce/search",
      "path": "salesforce/search",
      "active": false,
      "legacy": false,
      "created_at": "2020-08-05T05:59:55.991-07:00",
      "updated_at": "2020-08-05T05:59:55.991-07:00"
Enables an API endpoint. You must start the associated recipe to enable the API endpoint successfully.
bash
PUT https://YOUR_DATA_CENTER/api/api_endpoints/:api_endpoint_id/enable
Path parameters
NameTypeDescription
api_endpoint_idstring
ID of the API endpoint.
Sample request
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/api_endpoints/:api_endpoint_id/enable \
Disables an active API endpoint. The endpoint can no longer be called by a client.
bash
PUT https://YOUR_DATA_CENTER/api/api_endpoints/:api_endpoint_id/disable
Path parameters
NameTypeDescription
Sample request
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/api_endpoints/:api_endpoint_id/disable \
List API clients
List all API clients. This endpoint includes the project_id to which the API client belongs in the response.
bash
GET https://YOUR_DATA_CENTER/api/api_clients
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new List API clients (v2) endpoint before this date to ensure uninterrupted service.
Response
json
      "id": 1255,
      "name": "Automation Inc.",
      "created_at": "2020-07-31T03:44:22.435-07:00",
      "updated_at": "2020-07-31T03:44:22.435-07:00",
      "project_id" : "523144"
      "id": 1890,
      "name": "Umbrella Corporation",
      "project_id": "423455"
List all API clients. This endpoint includes the project_id of the API client in the response.
bash
GET https://YOUR_DATA_CENTER/api/v2/api_clients
Query parameters
NameTypeDescription
project_idstring
optional
The ID of a specific project. Retrieve a list of project IDs with the list projects endpoint.
pageinteger
optional
Page number. Defaults to 1.
per_pageinteger
optional
Page size. Defaults to 100. The maximum page size is 100.
cert_bundle_idsarray
optional
Filter clients by certificate bundle IDs. Returns only clients associated with the specified certificate bundles.
Sample request
shell
curl -X GET https://YOUR_DATA_CENTER/api/v2/api_clients \
Response
json
  "data": [
      "id": 1,
      "name": "Test client",
      "description": "",
      "active_api_keys_count": 2,
      "total_api_keys_count": 2,
      "created_at": "2023-05-25T08:08:21.413-07:00",
      "updated_at": "2024-10-25T03:52:07.122-07:00",
      "logo": "https://s3-48296.alexv.awstf.workato.com/paperclip/api_customers/logos/000/000/001/small/psyduck.png?1729853526",
      "logo_2x": "https://s3-48296.alexv.awstf.workato.com/paperclip/api_customers/logos/000/000/001/medium/psyduck.png?1729853526",
      "is_legacy": true,
      "api_policies": [
          "id": 2,
          "name": "Internal – Admins"
      "api_collections": [
          "id": 1,
          "name": "Echo collection"
          "id": 2,
          "name": "Proxy"
          "id": 4,
          "name": "Proxy to Alex's API collection"
          "id": 6,
          "name": "San Sanych"
  "count": 1,
  "page": 1,
  "per_page": 100
Create an API client
bash
POST https://YOUR_DATA_CENTER/api/api_clients
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Create an API client (v2) endpoint before this date to ensure uninterrupted service.
Query parameters
NameTypeDescription
project_idstring
required
The ID of a specific project. Retrieve a list of project IDs by using the list projects endpoint.
Payload
NameTypeDescription
namestring
required
Name of the client.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/api_clients?project_id=:project_id \
      -d '{
            "name": ":name",
Response
json
    "id": 1255,
bash
POST https://YOUR_DATA_CENTER/api/v2/api_clients
Payload
NameTypeDescription
namestring
required
Name of the client.
descriptionstring
optional
Description of the client.
project_idinteger
optional
ID of the project to create the client in, if applicable.
api_portal_idinteger
conditional
The ID of the API portal to assign the client, if applicable. Required when the idp_user_id or email field is provided in the request payload.
idp_user_idstring
conditional
Workato Identity user ID for the client. Required when api_portal_id refers to an identity portal.
emailstring
conditional
Email address for the client. Applies only to magic link portals. New portals are identity portals and require idp_user_id instead.
api_collection_idsarray
required
IDs of API collections to assign to the client.
api_policy_idinteger
optional
ID of the API policy to apply.
auth_typestring
required
Authentication method to validate requests. Supported types include token, jwt, oauth2 and oidc.
jwt_methodstring
conditional
The JWT signing method. Required when auth_type is jwt. Supported methods include hmac (HMAC) and rsa (RSA).
jwt_secretstring
conditional
HMAC shared secret or RSA public key. Required when auth_type is jwt.
oidc_issuerstring
conditional
Discovery URL for the OIDC identity provider. Specify this or oidc_jwks_uri when auth_type is jwt or oidc.
oidc_jwks_uristring
conditional
JWKS URL for the OIDC identity provider. Specify this or oidc_issuer when auth_type is jwt or oidc.
access_profile_claimstring
conditional
JWT claim key used to identify the access profile. Applicable when auth_type is jwt or oidc. Learn more.
required_claimsarray
conditional
List of claims to enforce. Applicable when auth_type is jwt or oidc.
allowed_issuersarray
conditional
List of issuers (iss claim) to allow. If the iss claim is enforced in required_claims, leave this blank to allow any issuer. Applicable when auth_type is jwt or oidc.
mtls_enabledboolean
optional
Whether mutual TLS is enabled for this client.
validation_formulastring
optional
Formula to validate client certificates.
optional
Certificate bundle IDs used for mTLS.
Sample request
Provide the idp_user_id field when the target portal is an identity portal:
shell
curl -X POST https://YOUR_DATA_CENTER/api/v2/api_clients \
     -d '{
            "name": ":name",
            "description": ":description",
            "api_portal_id": :api_portal_id,
            "auth_type": ":auth_type",
            "idp_user_id": ":idp_user_id",
            "mtls_enabled": :true_or_false
Provide the email field when the target portal uses magic link authentication:
shell
     -d '{
            "name": ":name",
            "api_collection_ids": [:api_collection_id],
            "api_policy_id": :api_policy_id,
            "email": ":email",
            "mtls_enabled": :true_or_false,
            "validation_formula": ":validation_formula",
            "cert_bundle_ids": [:cert_bundle_id]
Response
json
    "data": {
        "id": 1204662,
        "name": "Test user Inc.",
        "description": "API client for Product Catalog",
        "active_api_keys_count": 0,
        "total_api_keys_count": 0,
        "mtls_enabled": false,
        "created_at": "2026-06-22T23:21:18.873+08:00",
        "updated_at": "2026-06-22T23:21:18.873+08:00",
        "is_legacy": false,
        "auth_type": "token",
        "idp_user_id": "eshSUgjCGb4ZnF51FjEL3b",
        "api_collections": [],
        "api_keys": []
Get API client
bash
GET https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id
Path parameters
NameTypeDescription
api_client_idstring
required
ID of the API client to retrieve.
Sample request
shell
curl -X GET https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id \
Response
json
    "data": {
        "id": 42116,
        "created_at": "2025-02-12T08:36:51.748+05:30",
        "updated_at": "2025-02-12T08:36:51.748+05:30",
        "is_legacy": false,
        "email": "[email protected]",
                "id": 6883,
                "name": "Product Catalog"
        "api_keys": []
Update API client
bash
PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id
Path parameters
NameTypeDescription
api_client_idstring
required
ID of the API client to update.
Payload
NameTypeDescription
namestring
required
Updated name of the client.
descriptionstring
optional
Updated description of the client.
project_idinteger
optional
Updated project ID associated with the client.
emailstring
optional
Updated email address for the client.
required
Updated list of API collections assigned to the client.
required
Updated API policy ID.
jwt_methodstring
conditional
Updated JWT signing method. Required when auth_type is jwt. Supported methods include hmac (HMAC) and rsa (RSA).
jwt_secretstring
conditional
Updated HMAC shared secret or RSA public key. Required when auth_type is jwt.
oidc_issuerstring
conditional
Updated discovery URL for the OIDC identity provider. Specify this or oidc_jwks_uri when auth_type is jwt or oidc.
oidc_jwks_uristring
conditional
Updated JWKS URL for the OIDC identity provider. Specify this or oidc_issuer when auth_type is jwt or oidc.
conditional
Updated JWT claim key used to identify the access profile. Applicable when auth_type is jwt or oidc. Learn more.
conditional
Updated list of claims to enforce. Applicable when auth_type is jwt or oidc.
conditional
Updated list of issuers (iss claim) to allow. If the iss claim is enforced in required_claims, leave this blank to allow any issuer. Applicable when auth_type is jwt or oidc.
mtls_enabledboolean
optional
optional
Updated formula to validate client certificates.
optional
Updated certificate bundle IDs used for mTLS.
Sample request
shell
curl -X PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id \
     -d '{
           "name": ":name",
Response
json
    "data": {
        "id": 42116,
        "name": "Mustard Inc.",
        "description": "API client for Automation workflows",
        "updated_at": "2025-02-12T08:40:27.607+05:30",
        "is_legacy": false,
        "mtls_enabled": true,
        "validation_formula": "CN=api-client",
        "cert_bundle_ids": [2],
                "id": 6883,
                "name": "1"
        "api_keys": []
Delete API client
bash
DELETE https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id' \
Response
json
    "success": true
List all access profiles for an API client. If you don't provide an API client ID, this endpoint returns access profiles for all API clients.
bash
GET https://YOUR_DATA_CENTER/api/api_access_profiles
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new List API keys endpoint before this date to ensure uninterrupted service.
Query parameters
NameTypeDescription
api_client_idstringProvide an API client ID to retrieve access profiles belonging to a specific API client.
per_pageintegerNumber of access profiles returned in a single page. Defaults to 100. Max is 100.
pageintegerChoose the page of access profiles to return. The starting page is 1. Defaults to 1.
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/api_access_profiles?api_client_id=:api_client_id' \
Response
json
    "id": 942738,
    "name": "Sales API Profile",
    "api_client_id": 933804,
      791245,
      785457,
      785404
    "active": true,
    "created_at": "2023-11-07T19:39:04.294-05:00",
    "updated_at": "2023-11-07T19:39:04.294-05:00"
    "id": 942709,
    "name": "Purchases API Profile",
      726374,
      743721,
      776384
    "active": true,
    "created_at": "2023-11-07T18:48:19.908-05:00",
    "updated_at": "2023-11-07T18:48:19.908-05:00"
List API keys
Retrieve all API keys for an API client. Provide the api_client_id parameter to filter keys for a specific client. If you don’t provide the api_client_id parameter, the endpoint returns API keys for all clients.
bash
GET https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys
Path parameters
NameTypeDescription
api_client_idstring
optional
Filter API keys for a specific API client.
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys' \
Response
json
    "data": [
            "id": 17,
            "name": "Heat",
            "ip_allow_list": [],
            "ip_deny_list": [
                "192.168.0.1"
            "active": true,
            "active_since": "2025-02-04T18:57:35-08:00",
            "auth_token": "dda2"
    "count": 1,
    "page": 1,
    "per_page": 100
Create an access profile for an API client. To use this endpoint, the workspace must contain at least one API collection to assign to the access profile.
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Create an API key endpoint before this date to ensure uninterrupted service.
The response returned depends on the auth type chosen (Auth token, JSON web token or OAuth 2.0).
  • Auth token authorization will return the auth token in the secret response
  • JWT token has 2 signing methods: HMAC and RSA. Depending on the chosen method, the respective secret or public is required in the payload
  • OAuth 2.0 authorization will return the client ID and secret in oauth_client_id and oauth_client secret
bash
POST https://YOUR_DATA_CENTER/api/api_access_profiles
Query parameters
NameTypeDescription
api_client_idstring
ID of the API client.
Payload
NameTypeDescription
namestring
required
Name of the access profile
required
IDs of collections to add to the access profile
activeboolean
required
Whether the access profile is disabled or enabled. A client with a disabled access profile cannot call any APIs.
auth_typestring
required
Authentication method to validate requests. Available types are: token, jwt, oauth2 and oidc.
jwt_methodstringThe JWT signing method. If the auth_type is jwt, this is required. Available methods are hmac and rsa for HMAC and RSA respectively.
ip_allow_listarrayList of IP addresses to be allowlisted
jwt_secretstringBased on the method, specify the HMAC shared secret or the RSA public key.
oidc_issuerstring
conditional
Discovery URL of identity provider or OIDC service. Provide only one of this or oidc_jwks_uri, not both.
Only application if auth_type is jwt or oidc.
oidc_jwks_uristring
conditional
JWKS URL of identity provider or OIDC service. Provide only one of this or oidc_issuer, not both.
conditional
If you wish to use a custom claim to identify this access profile, provide the JWT claim key here. Learn more
conditional
Provide a list of claims that you wish to enforce.Only application if auth_type is jwt or oidc.
conditional
Provide a list of issuers (iss value in JWT claims) that you wish to allow. Leave If iss claim is enforced in required_claims, leave this blank to require any iss value. Only application if auth_type is jwt or oidc.
Sample request (Auth token)
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/api_access_profiles?api_client_id=:api_client_id'\
      -d '{
  	          "name": ":name",
  	          "api_collection_ids": [:api_collection_id_1, :api_collection_id_2],
  	          "active": :true_or_false,
              "ip_allow_list": [":ip_1", ":ip_2"]
#### Sample request (JWT RSA) {: #sample-request-jwt-rsa :}
shell
      -d '{
	           "name": ":name",
	           "jwt_method": ":jwt_method",
	           "jwt_secret": ":jwt_secret",
Response (Auth token)
json
    "id": 26985,
    "name": "New test",
    "api_client_id": 1255,
        1395
    "active": true,
    "jwt_method": null,
    "jwt_secret": null,
    "oauth_client_id": null,
    "oauth_client_secret": null,
    "secret": "e3a1ce1d46c4hjk8kfj26781c6ed3073312451ee0990035bf8a4bc90c2a2",
    "created_at": "2020-08-12T08:03:05.492-07:00",
    "updated_at": "2020-08-12T08:03:05.492-07:00"
Create an API key
Create a new API key for an API client.
bash
POST https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys
Path parameters
NameTypeDescription
api_client_idstring
required
Specify the ID of the API client to create the API key for.
Payload
NameTypeDescription
namestring
required
Name of the API key.
activeboolean
required
Indicates whether the API key is enabled or disabled. Disabled keys cannot call any APIs.
ip_allow_listarray
optional
List of IP addresses to add to the allowlist.
ip_deny_listarray
optional
List of IP addresses to deny requests from.
Sample request
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys' \
      -d '{
            "name": ":name",
            "ip_allow_list": [":ip_allow_list"],
            "ip_deny_list": [":ip_deny_list"]
Response
json
    "data": {
        "id": 37326,
        "ip_allow_list": ["8.8.8.8/24"],
        "ip_deny_list": ["192.168.0.0/16"],
        "active": true,
        "active_since": "2025-02-12T08:41:44+05:30",
        "auth_token": "72b378def0c1d83e6a015e654a744c380655565a68c591cf9f3598d0d14bdb5f"
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Update an API key endpoint before this date to ensure uninterrupted service.
bash
PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:api_access_profile_id
Path parameters
NameTypeDescription
api_access_profile_idstring
required
API access profile ID.
Payload
NameTypeDescription
namestring
required
Existing/Updated name of the access profile
required
Existing/updated API collection IDs to be configured for the access profile
activeboolean
required
auth_typestring
required
oidc_issuerstring
conditional
oidc_jwks_uristring
conditional
conditional
conditional
conditional
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/api_access_profiles/:access_profile_id'\
      -d '{
  	          "name": ":name",
Update an API key
Update an existing API key for an API client.
bash
PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id
Path parameters
NameTypeDescription
api_client_idstring
required
ID of the API client associated with the API key.
api_key_idstring
required
ID of the API key to update.
Payload
NameTypeDescription
namestring
optional
Updated name of the API key.
ip_allow_listarray
optional
Updated list of IP addresses to allow requests from.
ip_deny_listarray
optional
Updated list of IP addresses to deny requests from.
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id' \
      -d '{
              "name": ":name",
Response
json
    "data": {
        "id": 37326,
        "active": false,
        "auth_token": "db5f"
Enable an access profile belonging to an API client. Enabling an access profile will allow API calls to be accepted with the enabled profile.
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Enable an API key endpoint before this date to ensure uninterrupted service.
This call returns success or error messages for Unauthorized/Bad requests.
bash
PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:api_access_profile_id/enable
Path parameters
NameTypeDescription
required
ID of the access profile.
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:access_profile_id/enable \
Enable API key
bash
PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/enable
Path parameters
NameTypeDescription
api_client_idstring
required
ID of the API client that owns the API key.
api_key_idstring
required
ID of the API key to enable.
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/enable' \
Response
json
    "success": true
Disable an access profile belonging to an API client. Disabling an access profile will stop allowing API calls to be accepted with the access profile.
bash
PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:api_access_profile_id/disable
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Disable an API key endpoint before this date to ensure uninterrupted service.
Path parameters
NameTypeDescription
required
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:access_profile_id/disable \
Disable API key
bash
PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/disable
Path parameters
NameTypeDescription
api_client_idstring
required
api_key_idstring
required
ID of the API key to disable.
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/disable' \
Response
json
    "success": true
Refresh token/secret
Refreshes the auth token or OAuth 2.0 client secret. This endpoint will fail if the authorization type on the access profile is JWT.
DEPRECATION NOTICE
This endpoint is planned for deprecation on December 1, 2025. Transition to the new Refresh API key secret endpoint before this date to ensure uninterrupted service.
The response returned depends on the authorization type of the access profile (Auth token or OAuth 2.0).
  • Auth token authorization will return a new auth token in the secret response
  • OAuth 2.0 authorization will return a new client ID and secret in oauth_client_id and oauth_client secret
bash
PUT https://YOUR_DATA_CENTER/api/api_access_profiles/:access_profile_id/refresh_secret
Path parameters
NameTypeDescription
required
json
    "id": 26962,
    "name": "Sales team",
        1391
    "active": true,
    "jwt_method": null,
    "jwt_secret": null,
    "secret": "xxxxxxxxxxx",
    "created_at": "2020-07-31T09:10:03.310-07:00",
    "updated_at": "2020-08-05T06:08:46.290-07:00"
bash
PUT https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/refresh_secret
Path parameters
NameTypeDescription
api_client_idstring
required
api_key_idstring
required
ID of the API key to refresh.
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id/refresh_secret' \
Response
json
    "data": {
        "id": 37326,
        "active": true,
        "active_since": "2025-02-12T08:44:37+05:30",
        "auth_token": "572d581d91860a7c6372e9390699e26ac5917ac2520e1a917fba43b56d11edbe"
Delete API key
Delete an API key for an API client.
bash
DELETE https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id
Path parameters
NameTypeDescription
api_client_idstring
required
api_key_idstring
required
ID of the API key to delete.
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/v2/api_clients/:api_client_id/api_keys/:api_key_id' \
Response
json
    "success": true
List API portals
bash
GET https://YOUR_DATA_CENTER/api/v2/api_portals
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/v2/api_portals' \
Response
json
    "data": [
            "id": 37,
            "user_id": 14487,
            "name": "IDEA Lifestyle",
            "subdomain": "idea",
            "brand_color": "#371093",
                6882
            "created_at": "2024-12-13T08:46:37.125+05:30",
            "updated_at": "2025-02-10T14:10:21.440+05:30",
            "logo": "https://workato-staging-assets.s3.amazonaws.com/api_portal/models/portals/logos/000/000/037/small/007.png?1734059797",
            "logo_2x": "https://workato-staging-assets.s3.amazonaws.com/api_portal/models/portals/logos/000/000/037/medium/007.png?1734059797"
    "count": 1,
    "page": 1,
    "per_page": 100
List certificate bundles
bash
GET https://YOUR_DATA_CENTER/api/cert_bundles
Sample request
shell
curl -X GET https://YOUR_DATA_CENTER/api/cert_bundles \
Sample response
json
  "data": [
      "id": 1,
      "name": "cert1",
      "cert_count": 3,
      "leaf_ca_cn": "intermediate_ca_two",
      "expires_at": "2025-04-10T18:49:20.000-07:00",
      "updated_at": "2025-03-27T02:03:56.045-07:00",
      "client_count": 1
  "count": 1,
  "page": 1,
  "per_page": 20
Create a certificate bundle
Upload a new certificate bundle.
bash
POST https://YOUR_DATA_CENTER/api/cert_bundles
Payload
NameTypeDescription
cert_bundle_pemfile
required
PEM-formatted certificate file.
namestring
optional
Name of the bundle. Defaults to uploaded filename.
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/cert_bundles \
     -F "cert_bundle_pem=@:cert_bundle_pem_path" \
     -F "name=:name"
Update a certificate bundle by ID.
bash
PUT https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id
Path parameters
NameTypeDescription
certificate_bundle_idstring
required
ID of the certificate bundle to update.
Payload
NameTypeDescription
cert_bundle_pemfile
optional
namestring
optional
New name for the bundle.
Sample request
shell
curl -X PUT https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id \
     -F "name=:name"
Delete a certificate bundle by ID.
bash
DELETE https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id
Path parameters
NameTypeDescription
required
ID of the certificate bundle to delete.
Sample request
shell
curl -X DELETE https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id \
Sample response
json
  "success": true
Download a certificate bundle
Download a certificate bundle by ID.
bash
GET https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id/download
Path parameters
NameTypeDescription
required
ID of the certificate bundle to download.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/cert_bundles/:certificate_bundle_id/download' \
     -o cert_bundle.pem
