Lookup tables
Use the following endpoints to manage lookup tables programmatically.
Rate limits
Lookup table resources have the following rate limits:
| Type | Resource | Limit |
| POST | Delete lookup tables in batch: /api/lookup_tables/batch_delete | 1 request per second |
| All | All other Lookup tables endpoints | 60 requests per minute |
Quick reference
| GET | /api/lookup_tables | List tables. |
| GET | /api/lookup_tables/:lookup_table_id/rows | List rows. |
| GET | /api/lookup_tables/:lookup_table_id/lookup | Look up a row. |
| GET | /api/lookup_tables/:lookup_table_id/rows/:row_id | Get a row. |
| POST | /api/lookup_tables/:lookup_table_id/rows | Add a row. |
| POST | /api/lookup_tables | Create a new lookup table. |
| POST | /api/lookup_tables/batch_delete | Delete lookup tables in batch. |
| PUT | /api/lookup_tables/:lookup_table_id/rows/:row_id | Update a row. |
| DELETE | /api/lookup_tables/:lookup_table_id/rows/:row_id | Delete a row. |
List lookup tables
Returns a list of lookup tables belonging to a customer. Workato includes the project_id of the project to which the lookup table belongs in the response.
GET https://YOUR_DATA_CENTER/api/lookup_tablesParameters
| Name | Type | Description |
| page | integer | Page number. Defaults to 1. |
| per_page | integer | Page size. Defaults to 100 (maximum is 100). |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/lookup_tables' \
-H 'Content-Type: application/json' \Response
"id": 1315,
"name": "lookup_table4",
"schema":
"[{\"control_type\":\"text\",\"label\":\"code\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"col3\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col4\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col5\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":false}]",
"created_at": "2022-05-20T11:54:26.934-07:00",
"updated_at": "2022-05-20T11:54:26.934-07:00",
"project_id": "523144"
]List rows
Returns a lists of rows from the lookup table. Supports filtering and pagination.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rowsURL parameters
| lookup_table_id | integer required | Lookup table id |
Query parameters
| per_page | integer | Page size. Defaults to 500 (maximum is 1000). |
by[<col name>] | string | Filter criteria. The column name should be provided as follows: by[<col name>]. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details. When not supplied, all rows are returned. |
Sample request
Request 1: list rows
curl -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
-H 'Content-Type: application/json'Request 2: filter and list rows
curl -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows?by[code]=:by_code_value \
-H 'Content-Type: application/json'Response 1: list rows
"id": 941,
"data": {
"code": "IND",
"name": "India",
"col3": null,
"col4": null,
"col5": null
"created_at": "2022-06-15T11:50:32.986-07:00",
"updated_at": "2022-06-15T11:50:40.986-07:00"
"id": 942,
"data": {
"code": "US",
"name": "United States",
"col3": null,
"col4": null,
"col5": null
"created_at": "2022-05-20T11:50:32.986-07:00",
"updated_at": "2022-05-20T11:50:40.986-07:00"
]Response 2: filter and list rows
"id": 942,
"data": {
"code": "US",
"col3": null,
"col4": null,
"col5": null
]Lookup a row
Finds the first row matching the given criteria in the lookup table. Returns a 404 when the lookup fails.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/lookupURL parameters
Query parameters
by[<col name>] | string required | Lookup criteria. The column name should be provided as follows: by[<col name>]. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id?by[code]=:by_code_value \
"id": 942,
"data": {
"code": "US",
"col3": null,
"col4": null,
"col5": null
}Get a row
Get a row from the lookup table.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_idURL parameters
| row_id | integer required | Row id |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
"id": 942,
"data": {
"code": "US",
"col3": null,
"col4": null,
"col5": null
}Add a row
Adds a row to the lookup table.
POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rowsURL parameters
Payload
| data | Hash required | The hash contains the data for the new row. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
-d '{ "data": { ":column_name_1": ":column_value_1", ":column_name_2": ":column_value_2" }}'Response
"id": 942,
"data": {
"code": "USA",
"col3": null,
"col4": null,
"col5": null
"updated_at": "2022-05-20T11:50:32.986-07:00"
}Create a new lookup table
Create a new lookup table. Depending on your requirements, you can choose to make the lookup table available for general access across your workspace or limit its scope to a specific project.
POST https://YOUR_DATA_CENTER/api/lookup_tablesPayload
| name | string required | Provide a name for your new lookup table. |
| project_id | integer optional | Specify a project_id to scope the lookup table to a specific project. If you do not provide a project_id, the lookup table's scope is global. Use the list projects API to obtain a list of projects in your workspace. |
| schema | hash required | Determine the structure of your lookup table by supplying a schema and specifying the name of each of the columns in your table, for example: [{ "label": "Name" }]. Lookup tables support a maximum of ten columns. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/lookup_tables \
-d '{
"lookup_table": {
"name": ":name",
"project_id": :project_id_value,
"schema": [{ "label": ":label_1" }, { "label": ":label_2" }]
}'Response
"id": 2372,
"name": "Contacts",
"schema": "[{\"control_type\":\"text\",\"label\":\"ID\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"CSM\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Email\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Phone number\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Priority\",\"name\":\"col6\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Tier\",\"name\":\"col7\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Notes\",\"name\":\"col8\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Created at\",\"name\":\"col9\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"Updated at\",\"name\":\"col10\",\"type\":\"string\",\"sticky\":false}]",
"project_id": 4321,
"created_at": "2023-09-11T11:31:35.335-07:00",
"updated_at": "2023-09-11T11:31:35.335-07:00"
}Delete lookup tables in batch
Use this endpoint to delete lookup tables in batch.
POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_deletePayload
| ids | hash required | Include the ID(s) of the lookup table(s) you plan to delete. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_delete \
-d '{ "ids": [:id_1, :id_2] }'Response
"data": {"deleted": [1234, 1235, 1236] },
"errors": []
}Update a row
Updates a row in the lookup table.
PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_idURL parameters
Payload
| data | Hash required | The hash containing the data for the updated row. Only the columns provided are updated. |
Sample request
curl -X PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
-d '{ "data": { ":column_name": ":column_value" }}'Response
"id": 942,
"data": {
"code": "US",
"col3": null,
"col4": null,
"col5": null
}Delete a row
Delete a row from the lookup table
DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_idURL parameters
Sample request
curl -X DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
"success": true
}Last updated:
