Developer API - MCP servers ​
Use this resource to manage MCP (Model Context Protocol) servers programmatically.
TOKEN AND HASHED TOKEN AUTHENTICATION
hashed_token is the default authentication type for token-based MCP servers. The token authentication type is considered legacy. Existing servers using token continue to work, but new servers use hashed_token. Refer to Create a hashed token for more information on how to manage tokens on hashed_token servers.
Quick reference ​
TypeResourceDescription
GET/api/mcp/mcp_serversList MCP servers.
POST/api/mcp/mcp_serversCreate an MCP server.
GET/api/mcp/mcp_servers/:handleRetrieve MCP server details.
PUT/api/mcp/mcp_servers/:handleUpdate an MCP server.
DELETE/api/mcp/mcp_servers/:handleDelete an MCP server.
POST/api/mcp/mcp_servers/:handle/token_renewRenew MCP server authentication token.
POST/api/mcp/mcp_servers/:mcp_server_handle/tokensCreate a hashed token.
DELETE/api/mcp/mcp_servers/:mcp_server_handle/tokens/:idDelete a hashed token.
POST/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refreshRefresh a hashed token.
POST/api/mcp/mcp_servers/:handle/assign_toolsAssign tools to an MCP server.
POST/api/mcp/mcp_servers/:handle/assign_user_groupsAssign user groups to an MCP server.
POST/api/mcp/mcp_servers/:handle/remove_user_groupsRemove user groups from an MCP server.
PUT/api/mcp/mcp_servers/:handle/update_folderMove an MCP server to a different folder.
GET/api/mcp/mcp_servers/:mcp_server_handle/server_policiesRetrieve the server policy configuration.
PUT/api/mcp/mcp_servers/:mcp_server_handle/server_policiesUpdate the server policy configuration.
GET/api/mcp/mcp_servers/:mcp_server_handle/toolsList tools for an MCP server.
PUT/api/mcp/mcp_servers/:mcp_server_handle/tools/:idUpdate the tool description for an MCP.
DELETE/api/mcp/mcp_servers/:mcp_server_handle/tools/:idDelete a tool.
GET/api/mcp/user_groupsList identity provider user groups.
GET/api/mcp/mcp_servers/:mcp_server_handle/access_assignmentsList MCP access assignments.
POST/api/mcp/mcp_servers/:mcp_server_handle/access_assignmentsCreate an MCP access assignment.
GET/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:idRetrieve an MCP access assignment.
PUT/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:idUpdate an MCP access assignment.
DELETE/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:idDelete an MCP access assignment.
List MCP servers ​
Returns a list of MCP servers in the workspace.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers
Query parameters ​
NameTypeDescription
project_idnumber
optional
Filter by project ID.
folder_idnumber
optional
Filter by folder ID.
authentication_methodstring
optional
Filter by authentication method. Accepted values: hashed_token, token (legacy), workato_idp.
pagenumber
optional
Page number. Defaults to 1.
per_pagenumber
optional
Number of items per page. Maximum is 50.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers?folder_id=:folder_id_value' \
Sample response ​
json
    "data": [
            "id": 1001,
            "name": "Sales Tools MCP Server",
            "description": "Provides CRM and deal management tools for AI clients",
            "folder_id": 27180380,
            "project_id": 13595198,
            "authentication_method": "hashed_token",
            "tools_count": 5
            "id": 1002,
            "name": "HR Automation Server",
            "description": "HR onboarding and employee management tools",
            "authentication_method": "workato_idp",
            "tools_count": 3
    "count": 2,
    "page": 1,
    "per_page": 50
Create an MCP server ​
Creates a new MCP server in the workspace.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers
Payload ​
NameTypeDescription
namestring
required
Server name.
folder_idnumber
required
Folder ID for the MCP server.
descriptionstring
optional
Server description.
asset_idnumber
optional
API collection ID. Omit to create a project asset server.
toolsarray of objects
optional
Tools to assign to the server at creation. Each object requires trigger_application (string) and id (string). id is a number when used with workato_recipe_function and workato_api_platform tools. id is a string handle when used with workato_genie tools.
HASHED TOKEN AS DEFAULT AUTH TYPE
MCP servers use hashed_token as the default auth_type unless you specify a different authentication type. Use the MCP hashed tokens endpoints to manage tokens on a hashed_token server.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers \
      -d '{
            "name": ":name",
            "description": ":description",
            "folder_id": :folder_id_value,
            "tools": [
                "trigger_application": ":trigger_application",
                "id": ":tool_id"
Sample response ​
json
    "data": {
        "id": 1001,
        "asset_type": "api_collection",
        "logo_url": "https://www.workato.com/images/mcp-server-logo.png",
        "tools_count": 1,
        "mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=abc123xyz",
        "auth_type": "hashed_token",
        "idp_user_group_ids": [],
        "api_collection": null,
        "created_at": "2025-10-15T13:41:05.207-07:00",
        "updated_at": "2025-10-15T13:41:05.207-07:00"
Get MCP server details ​
Retrieves details for a specific MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
URL parameters ​
NameTypeDescription
handlestring
required
MCP server handle. You can find the mcp_server_handle​ in the URL when you go to AI Hub > Enterprise MCP and select the MCP server you plan to use. For example, your MCP server handle is mcps-AxbxNxNz-wsB-SM​ if the URL is https://app.workato.com/mcp/mcps-AxbxNxNz-wsB-SM/overview​.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
Sample response ​
json
    "data": {
        "id": 1001,
        "tools_count": 5,
        "updated_at": "2025-10-16T09:22:11.100-07:00"
Update an MCP server ​
Updates an existing MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
URL parameters ​
NameTypeDescription
handlestring
required
Payload ​
NameTypeDescription
namestring
optional
Server name.
descriptionstring
optional
Server description.
auth_typestring
optional
Authentication type. Accepted values: hashed_token (default), token (legacy), workato_idp.
idp_user_group_idsarray of strings
optional
Identity provider user group IDs that have access to the server. Only applicable when auth_type is workato_idp.
folder_idnumber
optional
Target folder ID to move the server.
LEGACY AUTH TYPE
Workato retains the token auth_type for backward compatibility. New servers should use hashed_token. Create token profiles with the MCP hashed tokens endpoints to switch an existing server's auth_type to hashed_token. hashed_token servers use individually named, revocable token profiles instead of a single server-level token.
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
      -d '{
            "name": ":name",
            "auth_type": ":auth_type"
Sample response ​
json
    "data": {
        "id": 1001,
        "name": "Sales & CRM Tools MCP Server",
        "description": "Provides CRM, deal management, and pipeline tools for AI clients",
        "tools_count": 5,
        "updated_at": "2025-10-17T11:05:33.812-07:00"
Delete an MCP server ​
Deletes an MCP server.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
URL parameters ​
NameTypeDescription
handlestring
required
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
Sample response ​
Returns 204 No Content on success.
Renew MCP server authentication token ​
Generates a new authentication token for an MCP server and invalidates the previous token. Use this endpoint to rotate credentials after a security event or as part of a regular credential rotation policy.
LEGACY ENDPOINT
This endpoint applies to servers using the legacy token auth type, which carry a single server-level token. Use Refresh a hashed token for hashed_token servers, which operates on an individual, named token profile.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renew
URL parameters ​
NameTypeDescription
handlestring
required
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renew' \
Sample response ​
Returns the updated MCP server object with the new mcp_url containing the refreshed token.
json
    "data": {
        "id": 1001,
        "tools_count": 5,
        "mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=newtoken789",
        "auth_type": "token",
        "updated_at": "2025-10-18T08:00:00.000-07:00"
MCP hashed tokens ​
MCP hashed token endpoints manage individual, named token profiles for MCP servers with hashed_token as the auth_type. This is an update from the the legacy token auth type in which a single server-level token is managed through token renewal. hashed_token supports up to 50 named, independently revocable token profiles per server.
Create a hashed token ​
Creates a token profile for a server with hashed_token as the auth_type.
MCP servers support a maximum of 50 active hashed tokens.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens
URL parameters ​
NameTypeDescription
mcp_server_handlestring
required
Payload ​
NameTypeDescription
namestring
required
Token profile name. Must be non-blank, no longer than 100 characters, and case-insensitively unique among the server's active tokens.
Additional constraints ​
This endpoint is only available for hashed_token servers. Calling this endpoint on a token or workato_idp server returns an error.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens' \
      -d '{
            "name": ":name"
Sample response ​
Returns 201 Created with the token profile at the response root rather than nested under data.
json
    "id": 731,
    "name": "Production token",
    "created_at": "2026-07-10T10:00:00.000Z",
    "created_by": {
        "id": 42,
        "full_name": "Example User"
    "token_first_symbols": "abc",
    "token_last_symbols": "wxyz",
    "plain_token": "<plain_token>"
PLAIN TOKEN IS SHOWN ONCE
plain_token is returned only at creation and can't be retrieved later. Store the token securely. You can use the refresh the token endpoint to generate a new token if needed.
Delete a hashed token ​
Deleting a hashed token doesn't remove it from the database. The hashed token profile is marked as inactive. The token immediately stops working and can no longer authenticate MCP requests.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id
URL parameters ​
NameTypeDescription
required
idnumber
required
Token profile ID.
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id' \
Sample response ​
Returns 200 OK with an empty response body.
This endpoint is available only for hashed_token servers. Deleted profiles no longer appear in the server's mcp_profiles array.
Refresh a hashed token ​
Invalidates the current token value for a profile and returns a fresh plain token.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refresh
URL parameters ​
NameTypeDescription
required
idnumber
required
Active token profile ID.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refresh' \
Sample response ​
Returns 200 OK. The response has the same root-level shape as token creation and contains the plain_token, token_first_symbols, and token_last_symbols.
json
    "id": 731,
    "created_by": {
        "id": 42,
    "token_first_symbols": "def",
    "token_last_symbols": "uvwx",
    "plain_token": "<new_plain_token>"
This endpoint is available only for hashed_token servers. The returned plain_token is exposed only in this response. Store the token securely as you can't retrieve it later.
Assign tools to an MCP server ​
Assigns one or more tools to an MCP server. Tools already assigned to the server aren't duplicated.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_tools
URL parameters ​
NameTypeDescription
handlestring
required
Payload ​
NameTypeDescription
required
Tools to assign. Each object requires trigger_application (string) and id (string).
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_tools' \
      -d '{
            "tools": [
                "trigger_application": ":trigger_application_1",
                "id": ":tool_id_1"
                "trigger_application": ":trigger_application_2",
                "id": ":tool_id_2"
Sample response ​
Returns the updated MCP server object.
json
    "data": {
        "id": 1001,
        "tools_count": 7,
        "updated_at": "2025-10-18T09:15:22.000-07:00"
Assign user groups to an MCP server ​
Assigns identity provider user groups to an MCP server. Only applicable when the server's auth_type is workato_idp.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groups
URL parameters ​
NameTypeDescription
handlestring
required
Payload ​
NameTypeDescription
required
IDs of the user groups to add.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groups' \
      -d '{
            "idp_user_group_ids": [":user_group_id_1", ":user_group_id_2"]
Sample response ​
Returns the updated MCP server object with the assigned user group IDs reflected in idp_user_group_ids.
json
    "data": {
        "id": 1002,
        "asset_type": "project_asset",
        "tools_count": 3,
        "mcp_url": "https://www.workato.com/mcp/servers/hr-automation-server?token=hrtoken456",
        "auth_type": "workato_idp",
        "idp_user_group_ids": ["group-abc123", "group-def456"],
        "created_at": "2025-10-15T10:00:00.000-07:00",
        "updated_at": "2025-10-18T10:30:00.000-07:00"
Remove user groups from an MCP server ​
Removes identity provider user groups from an MCP server.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groups
URL parameters ​
NameTypeDescription
handlestring
required
Payload ​
NameTypeDescription
required
IDs of the user groups to remove.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groups' \
      -d '{
            "idp_user_group_ids": [":user_group_id"]
Sample response ​
Returns the updated MCP server object with the specified groups removed from idp_user_group_ids.
json
    "data": {
        "id": 1002,
        "tools_count": 3,
        "idp_user_group_ids": ["group-def456"],
        "updated_at": "2025-10-18T11:00:00.000-07:00"
Move MCP server to a different folder ​
Moves an MCP server to a specified folder.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folder
URL parameters ​
NameTypeDescription
handlestring
required
Payload ​
NameTypeDescription
folder_idnumber
required
Target folder ID.
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folder' \
      -d '{
Sample response ​
Returns the updated MCP server object with the new folder_id reflected in created_at and updated_at timestamps.
json
    "data": {
        "id": 1002,
        "tools_count": 3,
        "updated_at": "2025-10-18T12:00:00.000-07:00"
Get server policy configuration ​
Retrieves the security policy configuration for an MCP server, including rate limits, usage limits, Classless Inter-Domain Routing (CIDR), and IP addresses.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies
URL parameters ​
NameTypeDescription
required
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
Sample response ​
json
    "id": 501,
    "mcp_server_id": 1001,
    "rate_limits": {
        "per_minute": 60
    "quota_limits": {
        "per_day": 10000
    "ip_allow_list": ["203.0.113.0/24"],
    "ip_deny_list": [],
Update server policy configuration ​
Updates the security policy configuration, including IP for an MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies
URL parameters ​
NameTypeDescription
required
Payload ​
NameTypeDescription
mcp_server_policyobject
required
Policy configuration object.
mcp_server_policy[rate_limits]object
optional
Rate limit configurations.
mcp_server_policy[quota_limits]object
optional
Quota limits configurations.
mcp_server_policy[ip_allow_list]array of strings
optional
IP addresses or CIDR ranges to allow.
mcp_server_policy[ip_deny_list]array of strings
optional
IP addresses or CIDR ranges to deny.
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
      -d '{
            "mcp_server_policy": {
              "rate_limits": { "per_minute": :per_minute_value },
              "quota_limits": { "per_day": :per_day_value },
              "ip_allow_list": [":ip_allow_1", ":ip_allow_2"],
              "ip_deny_list": []
Sample response ​
json
    "id": 501,
    "rate_limits": {
        "per_minute": 30
    "quota_limits": {
        "per_day": 5000
    "ip_allow_list": ["203.0.113.0/24", "198.51.100.42"],
    "ip_deny_list": [],
    "updated_at": "2025-10-18T14:00:00.000-07:00"
List tools for an MCP server ​
Returns a paginated list of tools assigned to an MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools
URL parameters ​
NameTypeDescription
required
Query parameters ​
NameTypeDescription
vua_requiredboolean
optional
Filter by whether Verified User Access (VUA) is required.
searchstring
optional
Search term to filter tools by name.
pagenumber
optional
per_pagenumber
optional
Number of items per page. Defaults to 100. Maximum is 100.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools' \
Sample response ​
json
    "data": [
            "id": 3001,
            "name": "Create Salesforce Lead",
            "description": "Creates a new lead record in Salesforce CRM",
            "trigger_application": "workato_api_platform",
            "action_applications": ["salesforce"],
            "flow_id": 66870001,
            "vua_required": false
            "id": 3002,
            "name": "Send Deal Notification",
            "description": "Sends a Slack notification when a deal stage changes",
            "trigger_application": "workato_recipe_function",
            "action_applications": ["slack"],
            "flow_id": 66870002,
            "vua_required": true
    "count": 2,
    "page": 1,
    "per_page": 100
Update tool description ​
Updates the description of a tool within an MCP server. This modifies the description shown to AI clients without affecting the underlying recipe or API endpoint.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id
URL parameters ​
NameTypeDescription
required
idnumber
required
Tool ID.
Payload ​
NameTypeDescription
descriptionstring
optional
New description for the tool.
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
      -d '{
Sample response ​
json
    "id": 3001,
    "description": "Creates a new lead record in Salesforce CRM with name, email, and company details",
Delete a tool ​
Removes a tool from an MCP server.
API ENDPOINTS CAN'T BE DELETED
Only tools backed by recipe functions or genies can be deleted. Attempting to delete an API endpoint tool returns a 400 Bad Request error.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id
URL parameters ​
NameTypeDescription
required
idnumber
required
Tool ID.
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
Sample response ​
List identity provider user groups ​
Returns a paginated list of identity provider user groups available in the workspace. Use the group IDs from this response when assigning access to MCP servers that use workato_idp authentication.
GET https://YOUR_DATA_CENTER/api/mcp/user_groups
Query parameters ​
NameTypeDescription
pagenumber
optional
per_pagenumber
optional
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/user_groups' \
Sample response ​
json
    "data": [
            "id": "group-abc123",
            "name": "Sales Team",
            "users_count": 24,
            "created_at": "2025-01-10T08:00:00.000Z",
            "updated_at": "2025-09-15T12:30:00.000Z"
            "id": "group-def456",
            "name": "HR Admins",
            "users_count": 6,
            "updated_at": "2025-08-20T10:00:00.000Z"
    "count": 2,
    "page": 1,
    "per_page": 100
MCP access assignments ​
MCP access assignments control tool-level role-based access control (RBAC) for an MCP server. Each assignment grants a single identity provider user or user group access to either all tools on the MCP server or a specific set of tools.
REQUIREMENTS AND LIMITATIONS
  • Access assignments work only with MCP servers that use workato_idp as the auth_type.
  • Access assignments don't work with api_collection-based MCP servers.
  • An identity can have only one access assignment per server.
List MCP access assignments ​
Returns a paginated list of MCP server access assignments for users or user groups.
Required privilege: mcp_access_assignments.index.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments
URL parameters ​
NameTypeDescription
required
Query parameters ​
NameTypeDescription
identity_typestring
required
Identity type. Accepted values: user, user_group.
searchstring
optional
Search identity names.
orderstring
optional
Sort by identity name. Accepted values: asc, desc. Defaults to asc.
pageinteger
optional
Positive page number. Defaults to 1.
per_pageinteger
optional
Number of items per page, from 1 to 100. Defaults to 100.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments?identity_type=user_group&page=1&per_page=100' \
Sample response ​
Returns 200 OK.
json
    "data": [
            "id": "mcpsaa-7Hk9pQ2s-aB3cD4-1a",
            "idp_user_id": null,
            "idp_user_group_id": "group-abc123",
            "all_tools": false,
            "tool_ids": [3001, 3002],
            "created_at": "2026-10-09T10:00:00.000Z",
            "updated_at": "2026-10-09T10:00:00.000Z"
            "id": "mcpsaa-7Hk9pQ2u-jK7mN8-1a",
            "idp_user_group_id": "group-def456",
            "all_tools": true,
            "tool_ids": [],
    "count": 2,
    "page": 1,
    "per_page": 100
The example lists group assignments. Set identity_type to user to include an idp_user_id string and a null idp_user_group_id for the assignment. Both identity fields are included by default.
Create an MCP access assignment ​
Creates one access assignment for a user or user group on an MCP server.
Required privilege: mcp_access_assignments.create.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments
URL parameters ​
NameTypeDescription
required
Payload ​
NameTypeDescription
idp_user_idstring
conditional
Non-empty identity provider user ID. Supply exactly one of idp_user_id or idp_user_group_id.
idp_user_group_idstring
conditional
Non-empty identity provider user group ID. Supply exactly one of idp_user_id or idp_user_group_id.
all_toolsboolean
optional
Grant access to all tools on the server. Defaults to false.
tool_idsarray of integers
conditional
Required and non-empty when all_tools is false or omitted. When all_tools is true, omit this field or send an empty array. Every ID must belong to this server. Use the List tools endpoint to retrieve tool IDs.
  • The identity must be available in the target environment.
  • An identity can have only one assignment per server.
  • Tool IDs refer to the server's MCP tool records, not recipe IDs or API endpoint IDs.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments' \
      -d '{
            "all_tools": false,
Use the following request body to grant a user access to all tools:
json
    "idp_user_id": "user-abc123",
    "all_tools": true
Sample response ​
Returns 201 Created.
json
    "data": {
        "all_tools": false,
The server generates the assignment ID. Tool IDs are deduplicated and sorted.
Get an MCP access assignment ​
Retrieves an access assignment belonging to an MCP server.
Required privilege: mcp_access_assignments.show.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
URL parameters ​
NameTypeDescription
required
idstring
required
Access assignment ID belonging to this server.
This endpoint doesn't accept query or body parameters.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
Sample response ​
Returns 200 OK.
json
    "data": {
        "all_tools": false,
User assignments have both the idp_user_id field with the user ID and the idp_user_group_id field with a null value by default. Assignments that grant all tools have all_tools: true and tool_ids: [].
Update an MCP access assignment ​
Replaces the tool access scope of an existing MCP server access assignment.
Required privilege: mcp_access_assignments.update.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
This path also accepts PATCH with the same replacement behavior.
URL parameters ​
NameTypeDescription
required
idstring
required
Payload ​
NameTypeDescription
all_toolsboolean
optional
Grant access to all tools on the server. Defaults to false when omitted.
conditional
UPDATES REPLACE THE ENTIRE TOOL SCOPE
Provide at least one of all_tools or tool_ids. Omitted fields aren't retained. An omitted all_tools defaults to false, and an omitted tool_ids defaults to an empty array. You can't change the identity on an existing assignment.
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
      -d '{
            "all_tools": false,
            "tool_ids": [3001]
To grant all tools, send {"all_tools": true}. The response then contains all_tools: true and tool_ids: [].
Sample response ​
Returns 200 OK.
json
    "data": {
        "all_tools": false,
        "tool_ids": [3001],
        "updated_at": "2026-10-09T11:00:00.000Z"
The assignment identity and creation timestamp don't change.
Delete an MCP access assignment ​
Deletes a user's or user group's access assignment from an MCP server.
Required privilege: mcp_access_assignments.destroy.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
URL parameters ​
NameTypeDescription
required
idstring
required
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
Sample response ​
Returns 204 No Content on success, with an empty response body.
