Lookup tables
Use the following endpoints to manage lookup tables programmatically.
Rate limits
Lookup table resources have the following rate limits:
TypeResourceQuota
POSTDelete lookup tables in batch:
/api/lookup_tables/batch_delete
1 request per second
AllAll other Lookup tables endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/lookup_tablesList tables.
GET/api/lookup_tables/:lookup_table_id/rowsList rows.
GET/api/lookup_tables/:lookup_table_id/lookupLook up a row.
GET/api/lookup_tables/:lookup_table_id/rows/:row_idGet a row.
POST/api/lookup_tables/:lookup_table_id/rowsAdd a row.
POST/api/lookup_tablesCreate a new lookup table.
POST/api/lookup_tables/batch_deleteDelete lookup tables in batch.
PUT/api/lookup_tables/:lookup_table_id/rows/:row_idUpdate a row.
DELETE/api/lookup_tables/:lookup_table_id/rows/:row_idDelete a row.
List lookup tables
Returns a list of lookup tables belonging to a customer. Workato includes the project_id of the project to which the lookup table belongs in the response.
GET https://YOUR_DATA_CENTER/api/lookup_tables
Parameters
NameTypeDescription
pageintegerPage number. Defaults to 1.
per_pageintegerPage size. Defaults to 100 (maximum is 100).
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/lookup_tables' \
Response
json
    "id": 1315,
    "name": "lookup_table4",
    "schema":
    "[{\"control_type\":\"text\",\"label\":\"code\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"col3\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col4\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col5\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":false}]",
    "created_at": "2022-05-20T11:54:26.934-07:00",
    "updated_at": "2022-05-20T11:54:26.934-07:00",
    "project_id": "523144"
List rows
Returns a lists of rows from the lookup table. Supports filtering and pagination.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows
URL parameters
NameTypeDescription
lookup_table_idinteger
required
Lookup table id
Query parameters
NameTypeDescription
per_pageintegerPage size. Defaults to 500 (maximum is 1000).
by[<col name>]string
Filter criteria. The column name should be provided as follows: by[<col name>]. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details. When not supplied, all rows are returned.
Sample request
Request 1: list rows
shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
Request 2: filter and list rows
shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows?by[code]=:by_code_value \
Response
Response 1: list rows
json
        "id": 941,
        "data": {
          "code": "IND",
          "name": "India",
          "col3": null,
          "col4": null,
          "col5": null
        "created_at": "2022-06-15T11:50:32.986-07:00",
        "updated_at": "2022-06-15T11:50:40.986-07:00"
        "id": 942,
        "data": {
          "code": "US",
          "name": "United States",
          "col3": null,
          "col4": null,
          "col5": null
        "created_at": "2022-05-20T11:50:32.986-07:00",
        "updated_at": "2022-05-20T11:50:40.986-07:00"
Response 2: filter and list rows
json
        "id": 942,
        "data": {
          "code": "US",
          "col3": null,
          "col4": null,
          "col5": null
Lookup a row
Finds the first row matching the given criteria in the lookup table. Returns a 404 when the lookup fails.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/lookup
URL parameters
NameTypeDescription
required
Lookup table id
Query parameters
NameTypeDescription
required
Lookup criteria. The column name should be provided as follows: by[<col name>]. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details.
Sample request
shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id?by[code]=:by_code_value \
Response
json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
Get a row
Get a row from the lookup table.
URL parameters
NameTypeDescription
required
Lookup table id
row_idinteger
required
Row id
Sample request
shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
Response
json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
Add a row
Adds a row to the lookup table.
POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows
URL parameters
NameTypeDescription
required
Lookup table id
Payload
NameTypeDescription
dataHash
required
The hash contains the data for the new row.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
      -d '{ "data": { ":column_name_1": ":column_value_1", ":column_name_2": ":column_value_2" }}'
Response
json
  "id": 942,
  "data": {
    "code": "USA",
    "col3": null,
    "col4": null,
    "col5": null
  "updated_at": "2022-05-20T11:50:32.986-07:00"
Create a new lookup table. Depending on your requirements, you can choose to make the lookup table available for general access across your workspace or limit its scope to a specific project.
Payload
NameTypeDescription
namestring
required
Provide a name for your new lookup table.
project_idinteger
optional
Specify a project_id to scope the lookup table to a specific project. If you do not provide a project_id, the lookup table's scope is global.
Use the list projects API to obtain a list of projects in your workspace.
schemahash
required
Determine the structure of your lookup table by supplying a schema and specifying the name of each of the columns in your table, for example: [{ "label": "Name" }].
Lookup tables support a maximum of ten columns.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables \
      -d '{
            "lookup_table": {
              "name": ":name",
              "project_id": :project_id_value,
              "schema": [{ "label": ":label_1" }, { "label": ":label_2" }]
Response
json
    "id": 2372,
    "name": "Contacts",
    "schema": "[{\"control_type\":\"text\",\"label\":\"ID\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"CSM\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Email\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Phone number\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Priority\",\"name\":\"col6\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Tier\",\"name\":\"col7\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Notes\",\"name\":\"col8\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Created at\",\"name\":\"col9\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"Updated at\",\"name\":\"col10\",\"type\":\"string\",\"sticky\":false}]",
    "project_id": 4321,
    "created_at": "2023-09-11T11:31:35.335-07:00",
    "updated_at": "2023-09-11T11:31:35.335-07:00"
Use this endpoint to delete lookup tables in batch.
POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_delete
Payload
NameTypeDescription
idshash
required
Include the ID(s) of the lookup table(s) you plan to delete.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_delete \
      -d '{ "ids": [:id_1, :id_2] }'
Response
json
    "data": {"deleted": [1234, 1235, 1236] },
    "errors": []
Update a row
Updates a row in the lookup table.
PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id
URL parameters
NameTypeDescription
required
Lookup table id
row_idinteger
required
Row id
Payload
NameTypeDescription
dataHash
required
The hash containing the data for the updated row. Only the columns provided are updated.
Sample request
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
      -d '{ "data": { ":column_name": ":column_value" }}'
Response
json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
Delete a row
Delete a row from the lookup table
DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id
URL parameters
NameTypeDescription
required
Lookup table id
row_idinteger
required
Row id
Sample request
shell
curl  -X DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
Response
json
  "success": true
