On-premise API
Workato API allows you to work with on-prem groups and on-prem agents through the API.
Rate limits
On-prem resources have the following rate limits:
TypeResourceQuota
AllAll On-prem endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/on_prem_groupsList on-prem groups.
POST/api/on_prem_groupsCreate on-prem group.
GET/api/on_prem_groups/:idGet on-prem group details.
PUT/api/on_prem_groups/:idUpdate on-prem group.
DELETE/api/on_prem_groups/:idDelete an on-prem group.
GET/api/on_prem_groups/:id/statusGet on-prem group status.
GET/api/on_prem_agentsList on-prem agents.
POST/api/on_prem_agentsCreate on-prem agent.
GET/api/on_prem_agents/:idGet on-prem agent details.
PUT/api/on_prem_agents/:idUpdate on-prem agent.
DELETE/api/on_prem_agents/:idDelete on-prem agents.
GET/api/on_prem_agents/:id/statusGet on-prem agent status.
GET/api/on_prem_agents/searchSearch for on-prem agent.
GET/api/on_prem_agents/:id/activation_codeGet on-prem agent activation code.
List on-prem groups
List all on-prem groups in your workspace.
GET https://YOUR_DATA_CENTER/api/on_prem_groups
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups' \
Response
json
    "id": 16803,
    "name": "CRM server",
    "created_at": "2017-09-21T01:51:45.954-07:00",
    "in_use": true,
    "use_managed_connection": true,
    "config_version": 9,
    "logs_enabled": false,
    "whitelisted_ips": [
      "198.51.100.10",
      "192.0.2.0/24"
Create an on-prem group.
POST https://YOUR_DATA_CENTER/api/on_prem_groups
Payload
NameTypeDescription
namestring
required
The on-prem group's name.
use_managed_connectionboolean
optional
Set to true to configure the on-prem group using a cloud profile or false to configure each agent manually using a config.yml file. Defaults to false if not specified.
settings_attributes[whitelisted_ips]array of strings
optional
Defines IPs to whitelist for the on-prem group.
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/on_prem_groups' \
     -d '{
          "name": ":name",
          "use_managed_connection": :true_or_false,
          "settings_attributes": {
              ":whitelisted_ip_1",
              ":whitelisted_ip_2"
Response
json
  "id": 16803,
  "in_use": false,
  "config_version": null,
    "198.51.100.10",
    "192.0.2.0/24"
Get details about an on-prem group.
GET https://YOUR_DATA_CENTER/api/on_prem_groups/:id
URL parameters
NameTypeDescription
idinteger
required
The ID of the on-prem group to retrieve.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
Response
json
  "id": 16803,
  "in_use": false,
  "use_managed_connection": false,
      "198.51.100.10",
      "192.0.2.0/24"
Update an on-prem group.
PUT https://YOUR_DATA_CENTER/api/on_prem_groups/:id
URL parameters
NameTypeDescription
idinteger
required
The on-prem group's ID.
Payload
NameTypeDescription
namestring
optional
optional
Sample request
shell
curl -X PUT 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
     -d '{
          "name": ":name",
              ":whitelisted_ip_2"
Response
json
  "id": 16803,
  "in_use": false,
    "198.51.100.10",
    "192.0.2.0/24"
Delete on-prem group
Delete an on-prem group and the on-prem agents it contains.
DELETE https://YOUR_DATA_CENTER/api/on_prem_groups/:id
URL parameters
NameTypeDescription
idinteger
required
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
Response
json
  "success": true
Get the status of an on-prem group.
GET https://YOUR_DATA_CENTER/api/on_prem_groups/:id/status
URL parameters
NameTypeDescription
idinteger
required
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id/status' \
Response
json
  "agent_count": 4,
  "active_agent_count": 3,
  "profiles": [
      "name": "CRM-Oracle",
      "provider": "oracle",
      "type": "Database",
      "connections": [
          "id": 440724,
          "name": "Oracle CRM DB"
List on-prem agents
List all on-prem agents in your workspace.
GET https://YOUR_DATA_CENTER/api/on_prem_agents
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents' \
Response
json
    "id": 12233,
    "on_prem_group_id": 16803,
    "name": "primary agent",
    "cn": "134fd7acd89cf5b8b96deea4870d413d:12233",
    "os": "windows",
    "installation_method": null,
    "awaiting_setup": false,
    "enabled": true,
    "last_seen_version": "25.0",
    "created_at": "2024-12-10T13:20:03.330-08:00",
    "updated_at": "2025-05-12T13:03:23.754-07:00",
    "state": "connected",
    "activated": true
Create an on-prem agent.
POST https://YOUR_DATA_CENTER/api/on_prem_agents
Payload
NameTypeDescription
namestring
required
The on-prem agent's name.
on_prem_group_idinteger
required
The on-prem group's ID. You can retrieve group IDs from the List on-prem groups endpoint's response.
osstring
optional
The server's operating system.
awaiting_setupboolean
optional
Set to true to create the agent in the awaiting_setup state. Set to false to skip agent setup and get its status right away. Defaults to true if not specified.
enabledboolean
optional
Set to true to enable the agent or false to disable it.
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/on_prem_agents' \
     -d '{
          "name": ":name",
          "on_prem_group_id": :on_prem_group_id_value,
          "os": ":os",
          "awaiting_setup": :true_or_false
Response
json
  "id": 12233,
  "on_prem_group_id": 50,
  "name": "US-west-1",
  "os": "windows",
  "enabled": true,
  "last_seen_version": null,
  "created_at": "2025-06-24T12:37:49.824-07:00",
  "updated_at": "2025-06-24T12:37:49.886-07:00",
  "activated": false
Get the details of an on-prem agent.
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:id
URL parameters
NameTypeDescription
idinteger
required
The on-prem agent's ID.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
Response
json
  "id": 12233,
  "os": "windows",
  "awaiting_setup": true,
  "enabled": true,
  "state": "awaiting_setup",
  "activated": false
Update an on-prem agent.
PUT https://YOUR_DATA_CENTER/api/on_prem_agents/:id
URL parameters
NameTypeDescription
idinteger
required
Payload
NameTypeDescription
namestring
optional
osstring
optional
optional
enabledboolean
optional
Sample request
shell
curl -X PUT 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
     -d '{
           "name": ":name"
Response
json
  "id": 49026,
  "on_prem_group_id": 32109,
  "cn": "1ee944db3b24d7c19dfe4685c49b77a4:49026",
  "os": "windows",
  "enabled": true,
  "last_seen_version": "27.0",
  "created_at": "2025-03-27T08:18:49.641-07:00",
  "updated_at": "2025-05-12T13:26:36.731-07:00",
  "activated": true
Delete an on-prem agent.
DELETE https://YOUR_DATA_CENTER/api/on_prem_agents/:id
URL parameters
NameTypeDescription
idinteger
required
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
Response
json
  "success": true
Get the status of an on-prem agent.
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:id/status
URL parameters
NameTypeDescription
idinteger
required
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id/status' \
Response
json
  "active": true
Search for on-prem agent by common name
Search on-prem agents by their common name.
GET https://YOUR_DATA_CENTER/api/on_prem_agents/search
URL parameters
NameTypeDescription
cnstring
optional
The common name of the on-prem agent to retrieve. Omit this parameter to return all agents.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/search' \
     -d  '{
Response
json
    "id": 12233,
    "os": "windows",
    "enabled": true
Get an activation code for an on-prem agent.
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:id/activation_code
URL parameters
NameTypeDescription
idinteger
required
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id/activation_code' \
Response
json
    "code": "eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJzdWIiOiJiMjY3MTA4NTU5NDBmMGFjYTVmNDYyMTFhNWYxMmJiNzo2MDg3MCIsImlhdCI6MTc0ODcyNTU5OSwiZXhwIjoxNzQ4NzI5MTk5LCJhZ2VudCI6NjA4NzAsImd3Ijoic2czLndvcmthdG8uY29tfHNnNC53b3JrYXRvLmNvbSJ9.JCcQ0NCetvIjP9xJJ1BIUAxmE9ImuNvtUJLNIazICiQg61RlSz2YJHywhbSXvakjjB77L7ZPydo43Rs_iiWiWRr5atk8iHvZlnfAKL_338-nFxmSkN-Ms7sL-fguNdQaO-DgkkZubAJ-qP8a34VKJ6QYA3c3SaixoNfnukKan0mUySTz7wQsVxU4C0Ff0R42AGO9CjKxYRobeBr_QgLJm6PtSUN5J6JkWGpyg9jTHJEpsFPDLBzJ0u7O7HkDP_onF4wdrraJ7_5BSn04ZllXw6oIwTbMWq1ncqhYHs0ZXNnv3efXF4L0tzgSkekdz-YasqojNSo0wzfpV0W_3vq_Mg"
