Project roles
Use the following endpoints to manage your project roles.
Project roles can have the following values:
ValueDefinition
systemDefault roles provided by Workato.
customRoles created manually within a workspace.
inheritableCustom roles from an AHQ admin or Embedded partner workspace that are inheritable by child workspaces.
inheritedRoles inherited by a child workspace from its AHQ or Embedded parent workspace.
Rate limits
Project roles resource has the following rate limit:
TypeResourceLimit
All All Project roles endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/project_rolesList project roles.
GET/api/project_roles/:idGet project role details.
POST/api/project_rolesCreate a project role.
PUT/api/project_roles/:idUpdate a project role.
DELETE/api/project_roles/:idDelete a project role.
List project roles
Retrieves a list of project roles from a workspace.
GET https://YOUR_DATA_CENTER/api/project_roles
Query parameters
NameTypeDescription
namestring
optional
Filter project roles by their name.
page[number]integer
optional
The page number to retrieve. The default value is 1.
page[size]integer
optional
The number of items per page to retrieve. The default and maximum value is 100.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/project_roles?name=:name_value&page[number]=:page_number_value&page[size]=:page_size_value' \
Response
json
  "data": [
      "id": "prjrl-APmWpgTs-dwARGH",
      "name" : "Builder",
      "members_count": 1,
      "type": "custom",
      "created_at": "2024-08-02T13:35:11.691-07:00",
      "updated_at": "2024-08-02T13:35:11.691-07:00"
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
Retrieves a project role by its ID.
GET https://YOUR_DATA_CENTER/api/project_roles/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project role to retrieve.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/project_roles/:id' \
Response
json
  "data": {
    "name" : "Developer",
    "config": { "recipe": { "privileges": "all" } },
    "members_count": 1,
    "type": "custom",
Creates a new project role.
POST https://YOUR_DATA_CENTER/api/project_roles
Request body
NameTypeDescription
project_roleobject
required
Defines the project role to create.
project_role[name]string
required
The name of the project role to create. The maximum length is 200 characters.
project_role[config]object
required
Defines the privileges assigned to the role.
project_role[inheritable]boolean
optional
Child workspaces inherit the role when set to true. The default value is false. This value can only be set to true in Admin AHQ or Embedded partner workspaces.
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/project_roles' \
  -d '{
        "project_role": {
          "name": ":name",
          "config": :config,
          "inheritable": :true_or_false
Response
json
  "data": {
    "name" : "Builder",
    "members_count": 0,
    "type": "custom",
Updates an existing project role by its ID.
PUT https://YOUR_DATA_CENTER/api/project_roles/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project role to update.
Request body
NameTypeDescription
project_roleobject
required
Defines the updated project role.
required
The updated name of the project role. The maximum length is 200 characters.
required
optional
Sample request
shell
curl -X PUT 'https://YOUR_DATA_CENTER/api/project_roles/:id' \
  -d '{
        "project_role": {
          "name": ":name",
          "config": :config,
Response
json
  "data": {
    "name" : "Builder",
    "members_count": 1,
    "type": "custom",
Deletes a project role by its ID.
DELETE https://YOUR_DATA_CENTER/api/project_roles/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project role to delete.
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/project_roles/:id' \
Response
A successful request returns a 204 No Content status code. The API deletes the project role and returns an empty response body.
400 BAD REQUEST
A 400 Bad Request error indicates that the server couldn't process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
In the following example, the request fails because the role is still assigned to some collaborators:
json
  "errors": [
      "code": "bad_request",
      "title": "You can’t delete a role when collaborators are assigned to the role."
