Environment roles
Use the following endpoints to manage your environment roles.
Environment roles can have the following values:
| Value | Definition |
| system | Default roles provided by Workato. |
| custom | Roles created manually within a workspace. |
| inheritable | Custom roles from an AHQ admin or Embedded partner workspace that are inheritable by child workspaces. |
| inherited | Roles inherited by a child workspace from its AHQ or Embedded parent workspace. |
LEGACY ROLE COMPATIBILITY
The following endpoints are only compatible with new roles where the role_type is environment.
Use the /api/roles endpoints instead to manage legacy roles where the role_type is privilege_group.
Rate limits
The environment roles resource has the following rate limit:
| Type | Resource | Quota |
| All | All Environment roles endpoints | 60 requests per minute |
Quick reference
| GET | /api/environment_roles | List environment roles. |
| GET | /api/environment_roles/:id | Get environment role details. |
| POST | /api/environment_roles | Create an environment role. |
| PUT | /api/environment_roles/:id | Update an environment role. |
| DELETE | /api/environment_roles/:id | Delete an environment role. |
Retrieves a list of environment roles from your workspace.
GET https://YOUR_DATA_CENTER/api/environment_rolesQuery parameters
| Name | Type | Description |
| name | string optional | Filter environment roles by their name. |
| page[number] | integer optional | The page number to retrieve. The default value is 1. |
| page[size] | integer optional | The number of items per page to retrieve. The default and maximum value is 100. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/environment_roles?name=:name_value&page[number]=:page_number_value&page[size]=:page_size_value' \
-H 'Authorization: Bearer <api_token>'Response
"data": [
"id": 1,
"name" : "Developer",
"members_count": 2,
"type": "custom",
"created_at": "2024-08-02T13:35:11.691-07:00",
"updated_at": "2024-08-02T13:35:11.691-07:00"
"total": 1,
"page": {
"number": 1,
"size": 100
}Get environment role details
Retrieves an environment role by its ID.
GET https://YOUR_DATA_CENTER/api/environment_roles/:idPath parameters
| id | string required | The ID of the environment role to retrieve. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/environment_roles/:id' \
"data": {
"id": 1,
"config": { "team": { "privileges": "all" } },
"members_count": 2,
"type": "custom",
}Create an environment role
Creates a new environment role.
POST https://YOUR_DATA_CENTER/api/environment_rolesRequest body
| environment_role | object required | Defines the environment role to create. |
| environment_role[name] | string required | The name of the environment role to create. The maximum length is 200 characters. |
| environment_role[config] | object required | Defines the privileges assigned to the role. |
| environment_role[inheritable] | boolean optional | Child workspaces inherit the role when set to true. The default value is false. This value can only be set to true in Admin AHQ or Embedded partner workspaces. |
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/environment_roles' \
-d '{
"environment_role": {
"name": ":name",
"config": :config,
"inheritable": :true_or_false
}'Response
"data": {
"id": 1,
"members_count": 0,
"type": "custom",
}Update an environment role
Updates an existing environment role by its ID.
PUT https://YOUR_DATA_CENTER/api/environment_roles/:idPath parameters
| id | string required | The ID of the environment role to update. |
Request body
| environment_role | object required | Defines the updated environment role. |
| environment_role[name] | string required | The updated name of the environment role. The maximum length is 200 characters. |
| environment_role[config] | object required | Defines the privileges assigned to the environment role. |
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/environment_roles/:id' \
-d '{
"name": ":name",
"config": :config,
}'Response
"data": {
"id": 1,
"name" : "Builder",
"members_count": 0,
"type": "custom",
}Delete an environment role
Deletes an environment role by its ID.
DELETE https://YOUR_DATA_CENTER/api/environment_roles/:idPath parameters
| id | string required | The ID of the environment role to delete. |
Sample request
curl -X DELETE 'https://YOUR_DATA_CENTER/api/environment_roles/:id' \
A successful request returns a 204 No Content status code. The API deletes the environment role and returns an empty response body.
400 BAD REQUEST
A 400 Bad Request error indicates that the server couldn't process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
In the following example, the request fails because the role is still assigned to some collaborators:
"errors": [
"code": "bad_request",
"title": "You can’t delete a role when collaborators are assigned to the role."
}Last updated:
