Recipe Lifecycle Management
Manifest: A container of different assets, including recipes, lookup tables, connections, and more.
Package: The build of a manifest. Contains the source code of each asset within a manifest. It includes the latest version of the asset available when the package was created.
Rate limits
Recipe lifecycle management resources have the following rate limits:
| Type | Resource | Limit |
| POST | Import a package into a folder: /api/packages/import/:folder_id | 500 requests per hour per user ID. If this limit is exceeded, the system denies additional requests until the following hour when the request allowance resets. |
| All | All other Recipe lifecycle management endpoints | 60 requests per minute |
Quick reference
| GET | /api/export_manifests/folder_assets | View assets in a folder. |
| POST | api/export_manifests | Create an export manifest. |
| PUT | api/export_manifests/:id | Update an export manifest. |
| GET | api/export_manifests/:id | View an export manifest. |
| DELETE | /api/export_manifests/:id | Delete an export manifest. |
| POST | /api/packages/export/:manifest_id | Export package based on a manifest. |
| POST | /api/packages/import/:folder_id | Import package into a folder. |
| GET | /api/packages/:id | Get package by ID. |
| GET | /api/packages/:id/download | Download a package. |
View assets in a folder. You can use this endpoint to help you create or update an export manifest.
GET https://YOUR_DATA_CENTER/api/export_manifests/folder_assetsURL parameters
| Name | Type | Description |
| folder_id | integer optional | The ID of the folder containing the asset. Defaults to the root folder. |
| include_test_cases | boolean optional | This parameter is currently not supported. Test cases are not included in the response. Defaults to false. |
| include_data | boolean optional | Includes data from the list of assets. Defaults to false. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/export_manifests/folder_assets?folder_id=:folder_id_value' \
-H 'Authorization: Bearer <api_token>'Response
"result": {
"assets": [
"id": 12,
"name": "Copy of Recipeops",
"type": "recipe",
"version": 1,
"folder": "",
"absolute_path": "All projects",
"root_folder": false,
"unreachable": false,
"zip_name": "copy_of_recipeops.recipe.json",
"checked": true,
"status": "added"
"id": 13,
"name": "My Salesforce account",
"type": "connection",
"version": 2,
"folder": "Salesforce Integration Project",
"absolute_path": "Salesforce Integration Project",
"zip_name": "salesforce_account_v2.connection.json",
"checked": true,
"status": "updated"
"id": 14,
"name": "Submit request in New workflow app",
"type": "page",
"version": 1,
"folder": "Workflow Automation Project",
"absolute_path": "Workflow Automation Project",
"zip_name": "submit_request_workflow_app.page.json",
"checked": true,
"status": "no change"
}Create an export manifest
POST https://YOUR_DATA_CENTER/api/export_manifestsPayload
| name | string required | Name of the new manifest. |
| assets | object required | Dependent assets. Workato recommends reviewing the View assets in a folder endpoint's response before using this endpoint. The View assets in a folder endpoint returns an assets object containing all assets in a specific folder. This can help you identify and format the assets you plan to include in your manifest. |
| id | integer required | ID of the dependency. |
| type | string required | Type of dependent asset. Refer to Asset types to see all supported type values. |
| checked | boolean optional | Determines if the asset is included in the manifest. Defaults to true. |
| version | integer optional | The version of the asset. Defaults to the latest version. |
| folder | string optional | The folder that contains the asset. Defaults to "". |
| absolute_path | string required | The absolute path of the asset. Defaults to root folder. |
| root_folder | boolean optional | Name root folder. Defaults to false. |
| unreachable | boolean optional | Whether the asset is unreachable. Defaults to false. |
| zip_name | string optional | Name in the exported zip file. By default, Workato auto-generates a name with this structure: asset_#{index}.#{type}.json. |
| include_test_cases | boolean optional | Whether the manifest includes test cases or not. Defaults to false. |
| auto_generate_assets | boolean optional | Auto-generates assets from a folder. Defaults to false. |
| include_test_cases | boolean optional | This parameter includes test cases from automatic asset generation. Defaults to false. |
| include_data | boolean optional | This parameter includes data from automatic asset generation. Defaults to false. |
| include_tags | boolean optional | Specifies whether to include tags assigned to assets in the export manifest. Tags are excluded from the manifest when set to false. Set to false by default. |
Asset types
Supported asset type values include:
recipeconnectionlookup_tableworkato_db_tableaccount_propertyproject_propertyworkato_schemaworkato_templatelcap_applcap_pagecustom_adaptertopicconnectionrecipeapi_groupapi_endpoint
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/export_manifests' \
-d '{
"export_manifest": {
"name": ":name",
"assets": [
"id": :asset_id,
"name": ":asset_name",
"type": ":type",
"version": :version,
"folder": ":folder",
"absolute_path": ":absolute_path",
"root_folder": :true_or_false,
"unreachable": :true_or_false,
"zip_name": ":zip_name",
"checked": :true_or_false
"folder_id": :folder_id_value,
"include_tags": :true_or_false
}'Response
"result": {
"id": 12,
"name": "Test Manifest",
"last_exported_at": null,
"created_at": "2023-02-27T02:44:59.447-08:00",
"updated_at": "2023-02-27T02:44:59.447-08:00",
"deleted_at": null,
"project_path": "Folder 1",
"status": "working"
}Create a manifest with multiple assets
You can pass multiple assets into the assets parameter to include them in the manifest.
Sample request
-d '{
"name": ":name",
"assets": [
"id": :asset_id_1,
"name": ":asset_name_1",
"type": ":asset_type_1",
"version": :asset_version_1,
"folder": ":asset_folder_1",
"absolute_path": ":asset_absolute_path_1",
"provider": ":asset_provider_1",
"zip_name": ":asset_zip_name_1",
"deps": [],
"id": :asset_id_2,
"name": ":asset_name_2",
"type": ":asset_type_2",
"version": :asset_version_2,
"folder": ":asset_folder_2",
"absolute_path": ":asset_absolute_path_2",
"include_test_cases": :true_or_false,
"zip_name": ":asset_zip_name_2",
"deps": [],
}'Response
"result": {
"id": 267546,
"name": "Test Manifest with two assets",
"created_at": "2025-03-21T07:50:29.488-07:00",
"updated_at": "2025-03-21T07:50:29.488-07:00",
"deleted_at": null,
"project_path": "Home assets",
"status": "working",
"include_tags": true
}Auto-generate assets
If you plan for Workato to auto-generate your assets, you can pass the parameter auto_generate_assets into the payload of the request. You must specify the folder_id you plan to have auto-generated. You can also choose to include test cases and data by adding the include_test_cases and include_data parameters. Note that test cases and data are excluded by default. Additionally, you can include auto_run in the payload to generate the package automatically.
Sample request
-d '{
"name": ":name",
"auto_generate_assets": :true_or_false,
"include_data": :true_or_false,
"auto_run": :true_or_false
'Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
}Possible statuses
| Status | Definition |
working | Active. |
archived | Deleted. |
PUT https://YOUR_DATA_CENTER/api/export_manifests/:idURL parameters
| id | integer string | The ID of the dependency. |
Payload
Update the properties contained in assets[] to replace the assets previously defined.
| name | string optional | Name of the manifest. Update this value to change the manifest name. Defaults to previous name. |
| assets | object required | Dependent assets. Workato recommends reviewing the View assets in a folder endpoint's response before using this endpoint. The View assets in a folder endpoint returns an assets object containing all assets in a specific folder. This can help you identify and format the assets you plan to update in your manifest. |
| absolute_path | string optional | The absolute path of the asset. Defaults to root folder. |
Asset types
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
-d '{
"name": ":name",
"assets": [
"id": :asset_id,
"type": ":type",
'Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
}Update a manifest with multiple assets
You can pass multiple assets into the assets parameter to update them in the manifest.
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
-d '{
"name": ":name",
"assets": [
"id": :asset_id_1,
"deps": [],
"id": :asset_id_2,
"deps": [],
}'Response
"result": {
"id": 171350,
"created_at": "2025-03-19T07:45:50.915-07:00",
"updated_at": "2025-03-21T09:26:46.348-07:00",
"deleted_at": null,
"include_tags": true,
"assets": [
"checked": true,
"name": "Outreach",
"zip_name": "API tests/outreach.connection.json",
"id": 65008167,
"version": null,
"folder": "API tests",
"absolute_path": "All projects/API tests",
"deps": []
"checked": true,
"name": "Test recipe",
"zip_name": "API tests/test_recipe.recipe.json",
"id": 86330482,
"type": "recipe",
"version": 4,
"include_test_cases": false,
"deps": []
"diff_included": false
Sample request
-d '{
"name": ":name",
'Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
}View an export manifest
GET https://YOUR_DATA_CENTER/api/export_manifests/:idURL parameters
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
}Delete an export manifest
DELETE https://YOUR_DATA_CENTER/api/export_manifests/:idURL parameters
| id | string required | Export manifest ID. |
Sample request
curl -X DELETE 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
"result": {
"success": true,
"status": "destroyed"
}Export a package based on a manifest
Export a package based on a manifest.
ENDPOINT PRIVILEGES ALSO PROVIDE ACCESS TO ASSETS
When you provide an API client with privileges to this endpoint, the API client is also granted the ability to view other assets like recipes, lookup tables, Event topics, and message templates by examining the resulting zip file.
POST https://YOUR_DATA_CENTER/api/packages/export/:idThis is an asynchronous request. Use GET package by ID endpoint to get details of the exported package.
INCLUDE TAGS WHEN CREATING THE EXPORT MANIFEST
To include tags in the exported package, set the include_tags attribute to true when calling the Create an export manifest endpoint.
URL parameters
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/packages/export/:manifest_id' \
"id": 242,
"operation_type": "export",
"status": "in_progress",
"export_manifest_id": 3,
"download_url": null
}RETRIEVE THE DOWNLOAD URL
Use the Get package by ID endpoint to monitor the export status. The download URL is available in the response after the process completes.
Import a package in zip file format into a folder. This endpoint allows an API client to create or update assets, such as recipes, lookup tables, event topics, and message templates, through package imports.
POST https://YOUR_DATA_CENTER/api/packages/import/:idThis is an asynchronous request. Use GET package by ID endpoint to get details of the imported the package.
The input (zip file) is a application/octet-stream payload containing package content. URL parameter restart_recipes must be true if the running recipes need to be restarted upon import.
URL parameters
| id | string required | Folder ID. |
Query parameters
| restart_recipes | boolean optional | Value must be true to allow the restarting of running recipes during import. Packages cannot be imported if there are running recipes and this parameter equals false or is not provided. |
| include_tags | boolean optional | Specifies whether to preserve tags assigned to assets when the package is imported into the folder. Tags are excluded from the import when set to false. Set to false by default. |
| folder_id_for_home_assets | string conditionally required | The ID of a folder to store assets in instead of the root folder. The folder specified must be accessible to the API client and cannot be the root folder. Defaults to "". |
FOLDER_ID_FOR_HOME_ASSETS IS CONDITIONALLY REQUIRED
The folder_id_for_home_assets parameter is required if:
- You are importing a package that contains root folder assets.
- Your workspace Home assets folder has been converted to a Home assets project.
Refer to the Home assets project section for more information.
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/packages/import/:folder_id?restart_recipes=:true_or_false&include_tags=:true_or_false' \
-H 'Content-Type: application/octet-stream' \
--data-binary @'path/to/local/file.zip'Response
"id":251,
"operation_type":"import",
"status":"completed",
"download_url":"https://www.workato-staging-assets.com/packages/zip_files/000/000/242/original/exportdemo.zip"
}Get package by ID
Get details of an imported or exported package.
GET https://YOUR_DATA_CENTER/api/packages/:idURL parameters
| id | string required | Package ID. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/packages/:id' \
-H 'Authorization: Bearer <api_token>'Responses
Successful export
This response shows the result of retrieving a completed export manifest.
"id":242,
"operation_type":"export",
"export_manifest_id":3,
}Failed export
This response shows the result of retrieving a failed export manifest.
"id":242,
"status":"failed",
"error":"error_message",
"export_manifest_id":4,
"download_url":null
}Successful import
This response shows the result of retrieving a completed import package. The API response now includes recipe_status.id values immediately after the first import operation. Previously, the response contained only the IDs of updated recipes. Now, it includes the IDs of all recipes, including newly imported recipes. This response specifically returns only recipe IDs, not IDs of other assets within the package.
INFO
For any completed import, it is important to also check each recipe's import_result. Learn more about the possible import_result values.
"id": 242,
"operation_type": "import",
"status": "completed",
"download_url": "https://www.workato-staging-assets.com/packages/zip_files/000/000/242/original/importdemo.zip",
"recipe_status": [
"id": 12345,
"import_result": "no_update_or_updated_without_restart"
"id": 12346,
"import_result": "restarted"
"id": 12347,
"import_result": "stopped"
}Failed import
This response shows the result of retrieving a failed import package.
INFO
A failed import may return only a partial list in recipe_status if some recipes weren't updated before the failure occurred. Learn more about the possible import_result values..
"id": 242,
"status": "failed",
"recipe_status": [
"id": 12345,
"import_result": "restart_failed"
"id": 12346,
"id": 12347,
}Recipe import_result values
There are a total of six possible results:
no_update_or_updated_without_restartIndicates no restart was needed for the recipe. Either recipe could be updated without it or no update was made. Successful import
not_foundUnexpected error when recipe cannot be found. Should not often be seen. Import has failed with no update to recipe.
stop_failedFor recipes that need to be restarted, we attempt to stop the recipe. This state indicates we could not stop the recipe. Import has failed with no update to recipe.
stoppedWorkato stopped the recipe but recipe was not restarted due to errors in the recipe. Import has failed with recipe updated but not restarted
restart_failedWorkato attempted to restart recipe but failed to do so. Import has failed with recipe updated but not restarted
restartedWorkato successfully restarted recipe after update. Successful import
Download package
Downloads a package.
GET https://YOUR_DATA_CENTER/api/packages/:id/downloadURL parameters
Sample request
curl -L -X GET 'https://YOUR_DATA_CENTER/api/packages/:id/download' \
-H 'Authorization: Bearer <api_token>'Follow redirects in cURL
Use the -L flag to follow redirect paths.
Response
If successful, you will be redirected to the package content. Returns 404 if package not found or doesn't have content.
