Developer API - Recipe Lifecycle Management ​
  • Manifest: A container of different assets, including recipes, lookup tables, connections, and more.
  • Package: The build of a manifest. Contains the source code of each asset within a manifest. It includes the latest version of the asset available when the package was created.
Rate limits ​
Recipe lifecycle management resources have the following rate limits:
TypeResourceQuota
POSTImport a package into a folder:
/api/packages/import/:folder_id
500 requests per hour per user ID. If this quota is exceeded, the system denies additional requests until the following hour when the request allowance resets.
AllAll other Recipe lifecycle management endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/export_manifests/folder_assetsView assets in a folder.
POSTapi/export_manifestsCreate an export manifest.
PUTapi/export_manifests/:idUpdate an export manifest.
GETapi/export_manifests/:idView an export manifest.
DELETE/api/export_manifests/:idDelete an export manifest.
POST/api/packages/export/:manifest_idExport package based on a manifest.
POST/api/packages/import/:folder_idImport package into a folder.
GET/api/packages/:idGet package by ID.
GET/api/packages/:id/downloadDownload a package.
View assets in a folder ​
View assets in a folder. You can use this endpoint to help you create or update an export manifest.
GET https://YOUR_DATA_CENTER/api/export_manifests/folder_assets
URL parameters ​
NameTypeDescription
folder_idinteger
optional
The ID of the folder containing the asset. Defaults to the root folder.
include_test_casesboolean
optional
This parameter is currently not supported. Test cases are not included in the response. Defaults to false.
include_databoolean
optional
Includes data from the list of assets. Defaults to false.
Sample request ​
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/export_manifests/folder_assets?folder_id=:folder_id_value' \
Response ​
json
  "result": {
    "assets": [
        "id": 12,
        "name": "Copy of Recipeops",
        "type": "recipe",
        "version": 1,
        "folder": "",
        "absolute_path": "All projects",
        "root_folder": false,
        "unreachable": false,
        "zip_name": "copy_of_recipeops.recipe.json",
        "checked": true,
        "status": "added"
        "id": 13,
        "name": "My Salesforce account",
        "type": "connection",
        "version": 2,
        "folder": "Salesforce Integration Project",
        "absolute_path": "Salesforce Integration Project",
        "zip_name": "salesforce_account_v2.connection.json",
        "checked": true,
        "status": "updated"
        "id": 14,
        "name": "Submit request in New workflow app",
        "type": "page",
        "version": 1,
        "folder": "Workflow Automation Project",
        "absolute_path": "Workflow Automation Project",
        "zip_name": "submit_request_workflow_app.page.json",
        "checked": true,
        "status": "no change"
Create an export manifest ​
POST https://YOUR_DATA_CENTER/api/export_manifests
Payload ​
NameTypeDescription
namestring
required
Name of the new manifest.
assetsobject
required
Dependent assets. Workato recommends reviewing the View assets in a folder endpoint's response before using this endpoint. The View assets in a folder endpoint returns an assets object containing all assets in a specific folder. This can help you identify and format the assets you plan to include in your manifest.
idinteger
required
ID of the dependency.
typestring
required
Type of dependent asset. Refer to Asset types to see all supported type values.
checkedboolean
optional
Determines if the asset is included in the manifest. Defaults to true.
versioninteger
optional
The version of the asset. Defaults to the latest version.
folderstring
optional
The folder that contains the asset. Defaults to "".
absolute_pathstring
required
The absolute path of the asset. Defaults to root folder.
root_folderboolean
optional
Name root folder. Defaults to false.
unreachableboolean
optional
Whether the asset is unreachable. Defaults to false.
zip_namestring
optional
Name in the exported zip file. By default, Workato auto-generates a name with this structure: asset_#{index}.#{type}.json.
folder_idinteger
optional
auto_generate_assetsboolean
optional
Auto-generates assets from a folder. Defaults to false.
optional
Whether the manifest includes test cases from automatic asset generation. Defaults to false.
include_databoolean
optional
This parameter includes data from automatic asset generation. Defaults to false.
include_tagsboolean
optional
Specifies whether to include tags assigned to assets in the export manifest. Tags are excluded from the manifest when set to false. Set to false by default.
Asset types ​
Supported asset type values include:
  • recipe
  • connection
  • lookup_table
  • workato_db_table
  • account_property
  • project_property
  • workato_schema
  • workato_template
  • lcap_app
  • lcap_page
  • custom_adapter
  • topic
  • connection
  • recipe
  • api_group
  • api_endpoint
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/export_manifests' \
      -d '{
            "export_manifest": {
              "name": ":name",
              "assets": [
                      "id": :asset_id,
                      "name": ":asset_name",
                      "type": ":type",
                      "version": :version,
                      "folder": ":folder",
                      "absolute_path": ":absolute_path",
                      "root_folder": :true_or_false,
                      "unreachable": :true_or_false,
                      "zip_name": ":zip_name",
                      "checked": :true_or_false
              "folder_id": :folder_id_value,
              "include_tags": :true_or_false
Response ​
json
  "result": {
    "id": 12,
    "name": "Test Manifest",
    "last_exported_at": null,
    "created_at": "2023-02-27T02:44:59.447-08:00",
    "updated_at": "2023-02-27T02:44:59.447-08:00",
    "deleted_at": null,
    "project_path": "Folder 1",
    "status": "working"
Create a manifest with multiple assets
You can pass multiple assets into the assets parameter to include them in the manifest.
Sample request ​
shell
      -d '{
              "name": ":name",
              "assets": [
                   "id": :asset_id_1,
                   "name": ":asset_name_1",
                   "type": ":asset_type_1",
                   "version": :asset_version_1,
                   "folder": ":asset_folder_1",
                   "absolute_path": ":asset_absolute_path_1",
                   "provider": ":asset_provider_1",
                   "zip_name": ":asset_zip_name_1",
                   "deps": [],
                    "id": :asset_id_2,
                    "name": ":asset_name_2",
                    "type": ":asset_type_2",
                    "version": :asset_version_2,
                    "folder": ":asset_folder_2",
                    "absolute_path": ":asset_absolute_path_2",
                    "include_test_cases": :true_or_false,
                    "zip_name": ":asset_zip_name_2",
                    "deps": [],
Response ​
json
    "result": {
        "id": 267546,
        "name": "Test Manifest with two assets",
        "created_at": "2025-03-21T07:50:29.488-07:00",
        "updated_at": "2025-03-21T07:50:29.488-07:00",
        "deleted_at": null,
        "project_path": "Home assets",
        "status": "working",
        "include_tags": true
Auto-generate assets ​
If you plan for Workato to auto-generate your assets, you can pass the parameter auto_generate_assets into the payload of the request. You must specify the folder_id you plan to have auto-generated. You can also choose to include test cases and data by adding the include_test_cases and include_data parameters. Note that test cases and data are excluded by default. Additionally, you can include auto_run in the payload to generate the package automatically.
Sample request ​
shell
      -d '{
              "name": ":name",
              "auto_generate_assets": :true_or_false,
              "include_data": :true_or_false,
              "auto_run": :true_or_false
Response ​
json
  "result": {
    "id": 12,
    "deleted_at": null,
    "status": "working"
Possible statuses ​
StatusDefinition
workingActive.
archivedDeleted.
Update an export manifest ​
PUT https://YOUR_DATA_CENTER/api/export_manifests/:id
URL parameters ​
NameTypeDescription
idinteger
string
The ID of the dependency.
Payload ​
Update the properties contained in assets[] to replace the assets previously defined.
NameTypeDescription
namestring
optional
Name of the manifest. Update this value to change the manifest name. Defaults to previous name.
assetsobject
required
Dependent assets. Workato recommends reviewing the View assets in a folder endpoint's response before using this endpoint. The View assets in a folder endpoint returns an assets object containing all assets in a specific folder. This can help you identify and format the assets you plan to update in your manifest.
idinteger
required
typestring
required
checkedboolean
optional
versioninteger
optional
folderstring
optional
absolute_pathstring
optional
root_folderboolean
optional
unreachableboolean
optional
zip_namestring
optional
folder_idinteger
optional
optional
optional
include_databoolean
optional
Asset types ​
  • recipe
  • connection
  • lookup_table
  • workato_db_table
  • account_property
  • project_property
  • workato_schema
  • workato_template
  • lcap_app
  • lcap_page
  • custom_adapter
  • topic
  • connection
  • recipe
  • api_group
  • api_endpoint
Sample request ​
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
      -d '{
              "name": ":name",
              "assets": [
                  "id": :asset_id,
                  "type": ":type",
Response ​
json
  "result": {
    "id": 12,
    "deleted_at": null,
    "status": "working"
Update a manifest with multiple assets
You can pass multiple assets into the assets parameter to update them in the manifest.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
      -d '{
              "name": ":name",
              "assets": [
                   "id": :asset_id_1,
                   "deps": [],
                    "id": :asset_id_2,
                    "deps": [],
Response ​
json
    "result": {
        "id": 171350,
        "created_at": "2025-03-19T07:45:50.915-07:00",
        "updated_at": "2025-03-21T09:26:46.348-07:00",
        "deleted_at": null,
        "include_tags": true,
        "assets": [
                "checked": true,
                "name": "Outreach",
                "zip_name": "API tests/outreach.connection.json",
                "id": 65008167,
                "version": null,
                "folder": "API tests",
                "absolute_path": "All projects/API tests",
                "deps": []
                "checked": true,
                "name": "Test recipe",
                "zip_name": "API tests/test_recipe.recipe.json",
                "id": 86330482,
                "type": "recipe",
                "version": 4,
                "include_test_cases": false,
                "deps": []
        "diff_included": false
Sample request ​
shell
      -d '{
              "name": ":name",
Response ​
json
  "result": {
    "id": 12,
    "deleted_at": null,
    "status": "working"
View an export manifest ​
GET https://YOUR_DATA_CENTER/api/export_manifests/:id
URL parameters ​
NameTypeDescription
idinteger
string
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
Response ​
json
  "result": {
    "id": 12,
    "deleted_at": null,
    "status": "working"
Delete an export manifest ​
DELETE https://YOUR_DATA_CENTER/api/export_manifests/:id
URL parameters ​
NameTypeDescription
idstring
required
Export manifest ID.
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/export_manifests/:id' \
Response ​
json
    "result": {
        "success": true,
        "status": "destroyed"
Export a package based on a manifest ​
Export a package based on a manifest.
ENDPOINT PRIVILEGES ALSO PROVIDE ACCESS TO ASSETS
When you provide an API client with privileges to this endpoint, the API client is also granted the ability to view other assets like recipes, lookup tables, Event topics, and message templates by examining the resulting zip file.
POST https://YOUR_DATA_CENTER/api/packages/export/:id
This is an asynchronous request. Use GET package by ID endpoint to get details of the exported package.
INCLUDE TAGS WHEN CREATING THE EXPORT MANIFEST
To include tags in the exported package, set the include_tags attribute to true when calling the Create an export manifest endpoint.
URL parameters ​
NameTypeDescription
idstring
required
Export manifest ID.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/packages/export/:manifest_id' \
Response ​
json
  "id": 242,
  "operation_type": "export",
  "status": "in_progress",
  "export_manifest_id": 3,
  "download_url": null
RETRIEVE THE DOWNLOAD URL
Use the Get package by ID endpoint to monitor the export status. The download URL is available in the response after the process completes.
Import a package into a folder ​
Import a package in zip file format into a folder. This endpoint allows an API client to create or update assets, such as recipes, lookup tables, event topics, and message templates, through package imports.
EVENT STREAM FOLDER PLACEMENT
Event streams imported without folder information during the transition period are placed into the default Event Streams Topics project, which Workato creates the first time it's needed. You must specify a folder to import event stream packages after the transition period.
POST https://YOUR_DATA_CENTER/api/packages/import/:id
This is an asynchronous request. Use GET package by ID endpoint to get details of the imported the package.
The input (zip file) is a application/octet-stream payload containing package content. URL parameter restart_recipes must be true if the running recipes need to be restarted upon import.
URL parameters ​
NameTypeDescription
idstring
required
Folder ID.
Query parameters ​
NameTypeDescription
restart_recipesboolean
optional
Value must be true to allow the restarting of running recipes during import.
Packages cannot be imported if there are running recipes and this parameter equals false or is not provided.
include_tagsboolean
optional
Specifies whether to preserve tags assigned to assets when the package is imported into the folder. Tags are excluded from the import when set to false. Set to false by default.
folder_id_for_home_assetsstring
conditionally required
The ID of a folder to store assets in instead of the root folder. The folder specified must be accessible to the API client and cannot be the root folder. Defaults to "".
FOLDER_ID_FOR_HOME_ASSETS IS CONDITIONALLY REQUIRED
The folder_id_for_home_assets parameter is required if:
  • You are importing a package that contains root folder assets.
  • Your workspace Home assets folder has been converted to a Home assets project.
Refer to the Home assets project section for more information.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/packages/import/:folder_id?restart_recipes=:true_or_false&include_tags=:true_or_false' \
      -H 'Content-Type: application/octet-stream' \
      --data-binary @'path/to/local/file.zip'
Response ​
json
   "id":251,
   "operation_type":"import",
   "status":"completed",
   "download_url":"https://www.workato-staging-assets.com/packages/zip_files/000/000/242/original/exportdemo.zip"
Get package by ID ​
Get details of an imported or exported package.
GET https://YOUR_DATA_CENTER/api/packages/:id
URL parameters ​
NameTypeDescription
idstring
required
Package ID.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/packages/:id' \
Responses ​
Successful export ​
This response shows the result of retrieving a completed export manifest.
json
   "id":242,
   "operation_type":"export",
   "export_manifest_id":3,
Failed export ​
This response shows the result of retrieving a failed export manifest.
json
   "id":242,
   "status":"failed",
   "error":"error_message",
   "export_manifest_id":4,
   "download_url":null
Successful import ​
This response shows the result of retrieving a completed import package. The API response now includes recipe_status.id values immediately after the first import operation. Previously, the response contained only the IDs of updated recipes. Now, it includes the IDs of all recipes, including newly imported recipes. This response specifically returns only recipe IDs, not IDs of other assets within the package.
INFO
For any completed import, it is important to also check each recipe's import_result. Learn more about the possible import_result values.
json
   "id": 242,
   "operation_type": "import",
   "status": "completed",
   "download_url": "https://www.workato-staging-assets.com/packages/zip_files/000/000/242/original/importdemo.zip",
   "recipe_status": [
            "id": 12345,
            "import_result": "no_update_or_updated_without_restart"
            "id": 12346,
            "import_result": "restarted"
            "id": 12347,
            "import_result": "stopped"
Failed import ​
This response shows the result of retrieving a failed import package.
INFO
A failed import may return only a partial list in recipe_status if some recipes weren't updated before the failure occurred. Learn more about the possible import_result values..
json
   "id": 242,
   "status": "failed",
   "recipe_status": [
            "id": 12345,
            "import_result": "restart_failed"
            "id": 12346,
            "id": 12347,
Recipe import_result values ​
There are a total of six possible results:
  • no_update_or_updated_without_restart
  • Indicates no restart was needed for the recipe. Either recipe could be updated without it or no update was made. Successful import
  • not_found
  • Unexpected error when recipe cannot be found. Should not often be seen. Import has failed with no update to recipe.
  • stop_failed
  • For recipes that need to be restarted, we attempt to stop the recipe. This state indicates we could not stop the recipe. Import has failed with no update to recipe.
  • stopped
  • Workato stopped the recipe but recipe was not restarted due to errors in the recipe. Import has failed with recipe updated but not restarted
  • restart_failed
  • Workato attempted to restart recipe but failed to do so. Import has failed with recipe updated but not restarted
  • restarted
  • Workato successfully restarted recipe after update. Successful import
Download package ​
Downloads a package.
GET https://YOUR_DATA_CENTER/api/packages/:id/download
URL parameters ​
NameTypeDescription
idstring
required
Package ID.
Sample request ​
shell
curl  -L -X GET 'https://YOUR_DATA_CENTER/api/packages/:id/download' \
Follow redirects in cURL
Use the -L flag to follow redirect paths.
Response ​
If successful, you will be redirected to the package content. Returns 404 if package not found or doesn't have content.
