Developer API - Test Automation ​
The following endpoints enable you to use the Test Automation feature programmatically.
Rate limits ​
Test Automation resources have the following rate limits:
TypeResourceQuota
AllAll Test Automation endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
POST/api/test_cases/run_requestsRun test cases.
GET/api/test_cases/run_requests/:idGet the current state of a test case run request.
GET/api/recipes/:recipe_id/test_casesGet test cases.
Run test cases ​
Use this endpoint to run test cases. You can specify the test cases to run in the following ways:
  • All test cases of all recipes in a manifest
  • All test cases of all recipes in a project
  • All test cases of all recipes in a folder
  • All test cases belonging to a particular recipe
  • Test cases you specify
This endpoint is asynchronous. You can use the run request id to poll the current state of the request using the /api/test_cases/run_requests/:id endpoint.
POST https://YOUR_DATA_CENTER/api/test_cases/run_requests
Request body ​
NameTypeDescription
manifest_idinteger optionalRun test cases for all recipes in the export manifest you specify.
project_idinteger optionalRun test cases for all recipes in the project you specify. Use the list projects endpoint to retrieve the IDs of all projects in your workspace.
folder_idinteger optionalRun test cases for all recipes in the folder you specify.
recipe_idinteger optionalRun all test cases for the recipe you specify.
test_case_idsarray of strings optionalRun specific test cases by ID.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/test_cases/run_requests \
      -d '{
            "manifest_id": ":manifest_id"
Sample response ​
json
  "data": {
    "id": "cirr-AHNFkza6-dwMArc",
    "status": "running",
    "user": {
      "id": 0
    "created_at": "2023-06-01T01:40:00.000-07:00",
    "updated_at": "2023-06-01T01:40:00.000-07:00",
    "results": [
        "recipe": {
          "id": 0,
          "name": "string"
        "test_case": {
          "id": "citc-AG48N4xo-g6ccgP",
          "name": "string"
        "job": {
          "id": "j-AHNFpnRa-sMWLYJ"
        "status": "pending"
Get the current state of a test case run request ​
Get the current state of a test case run request. For completed requests, Workato also returns the test coverage data along with the results.
GET https://YOUR_DATA_CENTER/api/test_cases/run_requests/:id
URL parameters ​
NameTypeDescription
idstring requiredThe run request's ID.
Sample request ​
shell
curl  -X GET https://YOUR_DATA_CENTER/api/test_cases/run_requests/:id \
Sample response ​
json
  "data": {
    "status": "completed",
    "user": {
      "id": 0
    "coverage": {
      "value": 87.5,
      "total_actions_count": 8,
      "total_visited_actions_count": 7,
      "recipes": [
          "id": 0,
          "version_no": 0,
          "coverage": {
            "value": 87.5,
            "not_visited_actions": [
                "step_number": 4
    "results": [
        "recipe": {
          "id": 0,
          "name": "string"
        "test_case": {
          "name": "string"
        "job": {
        "status": "succeeded"
Get test cases ​
Returns a collection of test cases belonging to the recipe you specify.
GET  https://YOUR_DATA_CENTER/api/recipes/:recipe_id/test_cases
URL Parameters ​
NameTypeDescription
recipe_idinteger requiredThe ID of the recipe you plan to retrieve test case details from.
Sample request ​
shell
curl  -X GET https://YOUR_DATA_CENTER/api/recipes/:recipe_id/test_cases \
Sample response ​
json
  "data": [
      "description": "string",
      "name": "string"
