Action on drop-down value change ​
The Run recipe action enables you to retrieve or modify data in a third-party application and return it to your Workflow app dynamically when a drop-down value changes in your app. This allows you to sync data between external system and your Workflow app in real-time.
Configure a Run recipe action on drop-down value change ​
Configuring a Run recipe action on drop-down value change involves the following steps:
  1. Enable action on drop-down value change
  2. Configure a recipe to retrieve or modify data in an external app
  3. Connect the recipe to page components
Enable action on drop-down value change ​
Complete the following steps to enable a Recipe run action on drop-down value change:
Create a new Workflow app or select an existing one.
Select a drop-down component and go to the Action panel. The action's Trigger event is pre-selected as Value changed.
Use the Action drop-down menu to select Run recipe.
Use the Recipe drop-down menu to click Create recipe. This opens the Set up your recipe page in a new tab.
Action setupAction on drop-down value change setup
Configure a recipe to retrieve or modify data in an external app ​
Enter a unique Name for this recipe.
Use the Location drop-down menu to ensure the recipe is in the same folder as your app page.
Click Start building.
Workato generates a recipe pre-configured with the New component event (real-time) trigger and the Return data to component action:
Recipe outlineRecipe outline
Modify the New component event trigger
Complete the following steps to modify the trigger:
Select the New component event trigger.
Go to the Setup tab.
The setup tab displays recipe input and output parameters which can be used to receive data from and return data to your page.
Go to Input parameters and click Add input parameters.
Define the page data to use in your recipe. You must provide the Name, Data type, and Optional status for each input parameter. Label and Hint are optional.
Configure input parametersConfigure input parameters
Go to Output schema and click Add field.
Define the recipe output you plan to return to your page. You must provide the Name, Data type, and Optional status for each output parameter. Label and Hint are optional.
Configure output schemaConfigure the output schema
Configure an action in an app
Complete the following steps to configure one or more action in an app steps to retrieve or modify data from an external system:
Click Select an app and action step in the recipe.
Search for and select the app you plan to use. A list of available actions for the app displays.
Select the action you plan to use.
Select the connection type you plan to use for the component event recipe.
Connection typeChoose a connection type
  • End user's connection: Workflow apps recipes perform actions based on the identity and permissions of the user who connects to the application. End users authenticate with their own credentials to retrieve or modify data in an external app.
  • This recipe's connection: This option uses the connection established by the recipe builder and follows the same principles as normal app connections.
Only app connections that use OAuth 2.0 authorization code grant are available for end user's connection. Refer to Verified user access for more information.
Select an existing connection or click + New connection to create a new connection.
Configure the action based on your requirements.
Map in input parameters to the action as necessary. For example, you can user input, such as an Account name to search for accounts in an external system and return relevant data to your page.
Add additional steps as required.
Modify the Return data to component action
Complete the following steps to return recipe data to your app:
Select the Return data to component action.
Use the Consider this action as successful? drop-down to define whether the action completed successfully.
Go to the output section and map in recipe data to the provided output fields. This output matches the output fields defined in the New component event trigger.
Return data to componentReturn data to component
Click Save and Exit.
Connect the recipe to page components ​
Complete the following steps to map page data into the recipe and surface recipe output back to page components:
Return to the page editor and select a drop-down component.
Create and map a variable into a page component
Go to the Design panel and select + Add variable.
Enter the variable Name, Data type, and Default value as required. Variable data types must match the data type specified in the trigger output parameters. Refer to Create a variable for more information.
Add variableAdd a variable
Create additional variables as required.
Select a component where you plan to display the variable, such as a text block, and go to the Content panel.
Use the Page data modal to map in a variable.
Map a variableMap a variable
Define recipe input parameters
Select a drop-down component.
Go to the Action panel.
Go to Recipe input parameters.
Use the Page data modal to map in page component data. For example, you can map in user input, such as an Account name to use it to search for account data in an external system.
Recipe input parametersDefine recipe input parameters
Use recipe output to set variable values
Go to Recipe output to set value and click + Add item.
Use the Recipe output drop-down menu to select recipe output.
Use the Set value for drop-down menu to select a page component or variable to set the value for. Refer to Populate a variable using recipe output to for more information.
Recipe outputPopulate variable values with recipe output
Click Save.
