Example use case: File upload
The following example demonstrates how to configure a Workflow app that lets users upload a profile picture, store it in an external system, and preview it before the user submits the page.
Enable action on file upload
Complete the following steps to enable a Recipe run action on file upload:
Create a new Workflow app or select an existing one.
Select a file component and go to the Action panel. The action's Trigger event is pre-selected as Value changed.
Use the Action drop-down menu to select Run recipe.
Use the Recipe drop-down menu to click Create recipe. This opens the Set up your recipe page in a new tab.
Action on file upload setup
Configure a recipe to process a file uploaded to your app
Enter a unique Name for this recipe.
Use the Location drop-down menu to ensure the recipe is in the same folder as your app page.
Click Start building.
Workato generates a recipe pre-configured with the New component event (real-time) trigger and the Return data to component action:
Recipe outline
Modify the New component event trigger
Select the New component event trigger.
Go to the Setup tab.
The setup tab displays the recipe's input and output parameters. Use them to receive data, such as files, from your page and return data back to it.
Go to Input parameters and click Add input parameters.
Define the page data, in this case a file to use in your recipe. You must provide the Name, Data type, and Optional status for each input parameter. You can also provide an optional Label and Hint.
Select File as the Data type to pass a file uploaded to your app to the recipe.
Configure input parameters
Configure an action in an app
Complete the following steps to configure one or more Action in an app steps to process the uploaded file. For example, you can save the uploaded profile picture to your organization's HR management software.
Click Select an app and action step in the recipe.
Search for and select the app you plan to use. A list of available actions for the app displays.
Select the action you plan to use, such as a file upload, download, or attachment action in a document storage or content management system.
Select the connection type you plan to use for the component event recipe.
Choose a connection type
- End user's connection: Workflow apps recipes perform actions based on the identity and permissions of the user who connects to the application. End users authenticate with their own credentials to retrieve or modify data in an external app.
- This recipe's connection: This option uses the connection established by the recipe builder and follows the same principles as normal app connections.
Only app connections that use OAuth 2.0 authorization code grant are available for end user's connection. Refer to Verified user access for more information.
Select an existing connection or click + New connection to create a new connection.
Configure the action based on your requirements.
Map the File nameStep 1 or File contentsStep 1 datapills into the action's input fields as necessary to save the file.
Add additional steps as required.
Modify the Return data to component action
Complete the following steps to return recipe data to your app:
Select the Return data to component action.
Use the Consider this action as successful? drop-down to define whether the action completed successfully.
Click Save and Exit.
Configure your app to preview the profile picture
You can configure your app to preview the uploaded profile picture by mapping the file component into an image component.
INFO
Image components only support image file types, such as .png, .jpg, and .jpeg.
Return to the page editor and add a new Image component to your page.
Go to the Source section of the properties panel and select Page data.
Select Page data as the image source
Use the Image data drop-down menu to select the file component input to display.
Enter Alt text for your image.
Use the Visible toggle to make the image visible in all conditions or only under specific conditions. For example, you can make this component's visibility Conditional so that it only displays after a file has been uploaded.
Optional. Modify the Image fitting setting to make the image Resize to fit or Expand to fill its container.
Optional. Modify the Horizontal alignment.
Optional. Modify the Vertical alignment.
Preview an uploaded image
