Assign task to users action
The Assign task to users action creates and assigns a workflow task to a user or group. It pauses the recipe job until the task reaches completion or expires. This action enables workflows that require user intervention, such as reviews, approvals, and rejections. Workato creates the task using the configured Task name, Assignee, and Record ID.
When the recipe reaches this step, Workato creates the task and sends an email notification to the assignee(s) if the Send email notification to assignee parameter is enabled. App-users can access the task through the email link, the Workflow apps portal homepage, or the Go to task option on the application page. Assignees can complete the task in the portal or use the Complete workflow task programmatically action. Tasks not completed within the specified timeframe expire, and the recipe resumes with the task marked as Expired.
Input
Input fieldDescription
Workflow appChoose the workflow app where Workato assigns the task.
Record IDSpecify the request to create the user task for. Use a datapill or enter the exact ID.
Workflow stageChoose the workflow stage to switch to while the task is active. Select one of the stages defined in your application settings or leave this field blank to keep the current stage.
Task nameProvide a description for the task. This name appears in email subject lines and helps users identify the task. Use datapills to personalize it.
AssigneeAssign the task to a user or user group. Assignees can access the task and receive an email if the Send email notification to assignee parameter is enabled.
PageSelect or create a page for assignees to complete the task. The page must include a button configured with the Complete task component action.
Number of days to complete taskSpecify the timeframe for task completion by either selecting from the list or entering a custom value. The maximum allowed value is 365 days. Tasks expire automatically if not completed within this timeframe.
Send email notification to assigneeChoose whether to notify the assignee through email. This field defaults to Yes.
Allow assignee to reassign taskChoose whether assignees can reassign the task. Managers can still reassign tasks even if this option is disabled.
Allow user who completes the task to access the request after the task is completeUse the drop-down menu to select Yes or No. When yes, the user who completes the task has persistent access to the request, even after it's completed.
REQUIRED CONFIGURATION
The selected page must include a button configured with the Complete task component action. Without it, Workato can't register task completion and the recipe job stays paused until the task expires.
Output
The output from the Assign task to users action includes two main objects. The Task object provides consistent details about the task created by the action, such as its ID, name, status, custom status label, and timestamps. The Record object dynamically reflects data from the Workflow app’s corresponding data table. Attributes in the Record object vary depending on the Workflow app configuration and its data table.
Task object
Output fieldDescription
Task IDWorkato automatically generates a unique ID for each task in a Task object.
Task nameThe name of the task.
StatusThe task's status. Available values include: Approved, Rejected and Expired.
Custom status labelThe custom status label applied to the task.
Is approvedWhether the task was completed with Approved status.
Is rejectedWhether the task was completed with Rejected status.
Is expiredWhether the task was completed with Expired status.
Created atThe date the task was created.
Completed atThe date the task was completed.
Completed by (Task)A nested object within the Task object describing the user that completed the task. Empty if the task is expired.
User ID (Completed by)The user's ID.
Task name (Completed by)Name of the task.
Email (Completed by)The user's email address.
Record object
Record IDA unique identifier for the record.
Created by (Record)An object nested within the Record object containing details about the user who created the record.
User ID (Created by)The unique identifier for the user.
User name (Created by)The name of the user.
Email (Created by)The user's email address.
Status (Created by)The current status of the user.
Groups (Created by)A nested object containing the details about the groups the user is assigned to.
Guest user (Created by)Whether the user is an anonymous user.
StageA nested object containing details on the current stage or status in the workflow.
Stage ID (Stage)The unique identifier for the stage.
Stage name (Stage)The name of the stage.
Created atThe date and time when the record was created.
Updated atThe date and time when the record was last updated.
