Sync PlanGrid safety reports to Microsoft SharePoint recipe
This use case guides you through connecting PlanGrid and Microsoft SharePoint to create a powerful automation.
What does this recipe do?
This recipe synchronizes new and updated safety inspection field reports from PlanGrid to Microsoft SharePoint.
Create your recipe
Complete the following steps to create a recipe that synchronizes new and updated safety inspection field reports from PlanGrid to Microsoft SharePoint:
Sign in to Workato.
Create connections for PlanGrid and Microsoft SharePoint:
Create a PlanGrid connection.
This step creates a connection between Workato and your PlanGrid account.
Search for and select PlanGrid on the New connection page.
PlanGrid connection setupPlanGrid connection setup
Click Connect. A PlanGrid OAuth dialog appears.
Click Give Permission to authorize Workato to establish the connection.
Create a Microsoft SharePoint connection.
This step creates a connection between Workato and your Microsoft SharePoint account.
You must have an Azure account to connect Microsoft SharePoint to Workato. Workato supports the following authentication methods:
Authorization code grant connection
This method requires the following fields:
  • Subdomain
  • Client ID (optional)
  • Client Secret (optional)
Step 1: Register the Workato app in Microsoft SharePoint and generate a client ID and secret
Complete the following steps to register the Workato app and generate a client ID and secret for authorization code grant connections:
Sign in to your Azure Portal.
Go to Microsoft Entra ID > Manage > App registrations and click New registration.
Enter a name for the application in the Name field.
Specify who can use this application in the Supported account type field.
Use the Select a platform drop-down menu to select Web.
Enter https://www.workato.com/oauth/callback in the Redirect URI field.
Click Register.
Go to Manage > API permissions and click Add a permission.
Select SharePoint as your API.
Select the Delegated permissions option.
Expand AllSites within the Select permissions field and select the AllSites.Read (Delegated) checkbox.
12
Go to Manage > Certificates & secrets and click New client secret.
13
Enter a description for the client secret in the Description field.
14
Use the Expires drop-down menu to set the expiration date for the client secret.
15
Click Add to create the client secret.
16
Click Copy to clipboard next to the Value after you create the secret. This is your Client Secret. Save this value in a secrets vault.
17
Go to Overview and copy the Application (client) ID value. This is your Client ID.
You can now configure your Microsoft SharePoint connection in Workato using the API permissions you set up in the Azure Portal.
Step 2: Complete setup in Workato
Search for and select Microsoft Sharepoint on the New connection page.
Microsoft SharePoint connection setupMicrosoft SharePoint connection setup
Use the Authentication type drop-down menu to select Authorization code grant.
Enter your SharePoint subdomain as found in your SharePoint URL in the Subdomain field. For example, if your SharePoint URL is https://abc.sharepoint.com, the subdomain is abc.
Enter the client ID generated in SharePoint in the Client ID field.
Enter the client secret generated in SharePoint in the Client secret field.
Enter the name of the SharePoint site you plan to connect to in the Site name field. If left blank, Workato connects to your default home site. Use the site name as found in the URL of the site page. For example, if the URL is https://company-name.sharepoint.com/sites/product, the site name is product.
Click Sign in with Microsoft.
Enter your credentials to sign in.
Click Accept to authorize the app you created in your Azure Portal.
Client credentials grant connection
This method requires the following values:
  • Subdomain
  • Tenant ID
  • Client ID
  • Certificate
  • Private Key
Step 1: Register the Workato application in Microsoft SharePoint
Complete the following steps to register the Workato app and obtain a client ID, secret, and private key for client credentials grant connections.
Click Register.
Select the Application permissions option.
Expand Sites in the Select permissions section and select the Sites.Read.All (Application) checkbox. Ensure that admin consent is granted in the Status column.
12
Go to Manage > Certificates & secrets > Certificates and click Upload certificate.
13
Upload a certificate if you already have one. If not, you can generate the certificate locally using tools such as OpenSSL or PowerShell.
14
15
Copy the Directory (tenant) ID value. This is your Tenant ID.
You can now configure your Microsoft SharePoint connection in Workato using these required values.
Step 2: Configure your Microsoft SharePoint connection in Workato
Use the Authentication type drop-down menu to select Client credentials.
Provide the tenant ID generated in SharePoint in the Tenant ID field.
Provide the client ID generated in SharePoint in the Client ID field.
Provide the certificate generated in SharePoint in the Certificate field.
Provide the private key string generated in SharePoint in the Private key field.
Click Start building.
Set up your PlanGrid New or updated object trigger.
Set up PlanGrid New or updated object trigger
This trigger monitors your PlanGrid project for new or updated field reports that include the word Safety in the file name.
Search for PlanGrid and select it as your app.
Choose PlanGridChoose PlanGrid
Select the New or updated object in PlanGrid trigger.
Select the New or updated object in PlanGrid triggerSelect the New or updated object in PlanGrid trigger
Use the Object drop-down menu to select Field Report.
Use the Project drop-down menu to select your project.
Configure the triggerConfigure the trigger
Click the Set trigger condition toggle.
Set trigger conditionSet trigger condition
Map the PlanGrid StatusStep 1 datapill to the Trigger data field.
Use the Condition drop-down menu to select equals.
Type submitted in the Value field.
Click + (plus) and select AND to add a second condition.
Map the PlanGrid NameStep 1 datapill to the Trigger data field.
Use the Condition drop-down menu to select contains.
12
Type Safety in the Value field.
13
Click Save.
Click + Add step and select IF condition.
Add IF conditionClick Add step > IF condition
How do IF conditions work?
PlanGrid and Microsoft SharePoint IF condition example
An IF condition enables you to make decisions based on specific conditions. You can control your recipe workflow by executing different actions depending on whether a condition you specify is true or false.
12
Set up your PlanGrid IF condition.
Set up a PlanGrid IF condition
This step checks if a PDF URL is present in the trigger output.
Map the PlanGrid PDF URLStep 1 datapill to Data field.
Use the Condition drop-down menu to select is present.
Configure your IF conditionConfigure your IF condition
Click Save.
13
Add actionClick Add step > Add action in app
14
Set up your File tools by Workato Get file from URL action.
Set up File tools by Workato Get file from URL action
This step retrieves the file contents from the PDF URL.
Search for File tools by Workato and select it as your app.
Choose File tools by WorkatoChoose File tools by Workato
Select the Get file from URL action.
Select the Get file from URL actionSelect the Get file from URL action
Map the PlanGrid PDF URLStep 1 datapill to the URL field.
Map the PDF URL datapillMap the PDF URLStep 1 datapill
Click Save.
15
16
Set up your Microsoft SharePoint Upload file in library action.
Set up Microsoft SharePoint Upload file in library action
This step uploads the PlanGrid field report PDF file to a folder you specify in Microsoft SharePoint.
Search for Microsoft SharePoint and select it as your app.
Choose Microsoft SharePointChoose Microsoft SharePoint
Select the Upload file in library action.
Select the Upload file in library actionSelect the Upload file in library action
Enter the name of the Microsoft SharePoint site you plan to connect to in the Site name field. If left blank, Workato connects to the site name specified when you configured your connection.
Select the folder where you plan to upload the field report in the Folder field.
Enter a name in the File name field.
Complete the following steps to configure this field dynamically:
Configure the file nameConfigure the file name
Switch the File name field to formula mode.
Map the PlanGrid Report DateStep 1 datapill.
Append the .strftime formula to format the Report DateStep 1 datapill. Enter "%Y-%m-%d" as the value in the .strftime formula.
Append the .to_s formula to convert the Report DateStep 1 datapill into a string.
Type + "-" + to insert a hyphen between the date and document title.
Map the PlanGrid NameStep 1 datapill.
Append the .gsub formula to replace spaces with hyphens in the document name. Enter " ", "-" as the value in the .gsub formula.
Type + ".pdf" to complete the file name with the .pdf extension.
File name configurationFile name configuration
This configuration applies the following naming convention:
YYYY-MM-DD-YOUR-SAFETY-FIELD-REPORT-TITLE.pdf
For example:
2024-10-09-Daily-Safety-Inspection.pdf
Map the File tools by Workato File contentsStep 3 datapill to the File contents field.
Map the File contents datapillMap the File contentsStep 3 datapill
Click Save.
Your Sync PlanGrid safety reports to Microsoft SharePoint recipe is ready to test and implement.
Example recipe configuration.
PlanGrid and Microsoft SharePoint recipeSync PlanGrid safety reports to Microsoft SharePoint recipe
