# Kafka - No profile found error
The OPA displays a No profile found error when it can't locate the specified Kafka profile during execution. This issue often results from a configuration mismatch in the config.yml file.
File configuration mismatch
Check the following in your config.yml to resolve the error:
- The
kafka:block exists - The profile name matches exactly, including capitalization
- The profile is properly nested under
kafka:without indentation errors
For example:
kafka:
myKafkaProfile:
bootstrap.servers: "localhost:9092"
The OPA must recognize the profile exactly as defined. Any mismatch in structure or naming prevents the agent from loading the configuration.
Last updated: 5/29/2025, 10:25:55 PM
