# On-prem runtime and performance issues
This guide covers memory-related issues that can occur during the runtime of the on-prem agent (OPA). These include heap space errors, crashes caused by large API responses, logging errors, and long query errors.
# Java heap space errors
The following error log indicates the agent has reached its memory limit:
java.lang.OutOfMemoryError: Java heap space
This error indicates that OPA doesn't have enough memory to process large jobs or payloads. By default, the heap size is set to a fraction of available system memory.
Open the run.sh file and adjust the -Xmx flag to resolve the issue. For example, you can increase it to -Xmx10G to allocate 10 GB of heap memory.
# High memory usage from large responses
The agent may crash or slow down when it buffers large API responses in memory. By default, it loads entire responses during execution, which increases memory usage.
OPA version 2.7.1 and later allows you to disable response buffering in the configuration file by adding the following flag to your config.yml:
agent:
  disable_response_buffering: true
# Resolve gateway names on servers with OPA installed
You may encounter the following errors when resolving Workato gateway names on servers with OPA installed: - sg3.workato.com
  • sg4.workato.com
Complete the following troubleshooting steps to resolve gateway names:
Connect to the server where your OPA instance runs.
Open your server's console.
Run the following commands to verify if the gateway names can be resolved from your Windows, Linux, and MacOS server:
nslookup sg3.workato.com
Run the following command on Linux and MacOS servers to verify if the gateway names can be resolved:
dig sg3.workato.com
Your output is similar to the following:
sg3.workato.com	canonical name = public-v10-awsprod-opg3-nlb-d6da47859547995a.elb.us-east-1.amazonaws.com.
Address: 54.224.75.148
Address: 52.206.161.203
Address: 52.204.114.159
This successful output indicates that it is possible to resolve the domain name.
# Check gateway connectivity
You may encounter issues with establishing gateway connectivity on servers with OPA installed.
Complete the following troubleshooting steps to check gateway connectivity:
curl -k -vvv -GET --no-alpn --key conf/cert.key --cert conf/cert.pem https://sg3.workato.com/gateway/ping
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
(LINES SKIPPED)
< HTTP/1.1 200 OK
< Content-Type: application/json
< Date: Mon, 25 Jul 2022 21:33:42 GMT
< Content-Length: 81
{"gateway_version":"1.0.1","os_platform":"linux","os_release":"4.19.0-10-amd64"}
# Verify the server certificate chain
You may encounter issues verifying the server certificate chain on servers with OPA installed.
Complete the following troubleshooting steps to verify the server certificate chain:
Go to your OPA installation folder. Refer to the Accessing on-prem documentation for more information about installation.
Download the Workato root certificate and save it in your OPA installation folder. Refer to the HTTP SSL documentation for instructions.
Run the following command for Linux and MacOS:
curl -vvv -GET --no-alpn --cacert root_ca_cert.pem --key conf/cert.key --cert conf/cert.pem https://sg3.workato.com/gateway/ping
The expected output contains the following:
SSL certificate verify ok
This indicates that the server certificate chain was successfully verified.
# OPA stopped creating logs
You may encounter an issue where OPA stops generating logs when running on Linux. This issue occurs when there is either no free space remaining on the disk or when the logging level settings are incorrect. Complete the following troubleshooting procedure to resolve this issue:
Run the following command to determine if there is free space left on the disk:
df -h
cat /etc/fstab
parted -l
This determines if the issue is related to disk space.
Verify that the logging permissions are correct.
Run ls -lah /var/log/workato-agent to view log permissions.
Run the following command if a user or group does not have permissions set to workato:
chown -R workato:workato /var/log/workato-agent
Check that the logging level is set to debug in the config file. For example:
logger: debug
# Long query error
You may encounter the following error when using the On-prem files connector with a database connector, such as MySQL:
Long query error: java.lang.IllegalArgumentException: Missing files profile laws rds cx
This error occurs when the On-prem files connector and a database connector use different on-prem groups. Set both connections to use agents in the same on-prem group to resolve this error.
Last updated: 11/3/2025, 5:20:39 PM
