# Shopify - API version upgrade to 2022-07
# What is the update?
In April 2023, we will be upgrading the Shopify API version we are using to the latest stable 2022-07 version. Subsequently, we will be performing such upgrades on an annual basis.
Why are we doing this?
Shopify generally releases a new version every 3 months, and maintains each release version for a maximum of 12 months. That means that there will be 4 stable versions supported at any point in time.
Once a released version passed its one year mark, Shopify will no longer maintain that version, and any API calls requesting that version will be automatically routed to the oldest stable version currently supported.
For instance, if the current available stable versions are 2021-01, 2021-04, 2021-07, and 2021-10, then any API calls requesting for 2020-04 version will be automatically routed to the 2021-01 version by Shopify.
To balance your convenience against Shopify's mandated version upgrade, we decided to perform the upgrade annually. Should you require a specific API version, you may use custom action to override the default version in the path parameter.
You may visit Shopify's API versioning (opens new window) page for more information.
# How does this affect me?
# Important action item
Important Notice
It is imperative that the following change is implemented before 27 March 2023.
- Add scopes for fulfillment: if you are using the “Create fulfillment” order, please add the following scopes into your connection:
read_assigned_fulfillment_orderswrite_assigned_fulfillment_ordersread_merchant_managed_fulfillment_orderswrite_merchant_managed_fulfillment_ordersread_third_party_fulfillment_orderswrite_third_party_fulfillment_orders
Please take note that should you may need to reconnect to Shopify using one of the new authentication methods we released in Q3 2022.
# Recommended action items
In addition to the above, it is recommended that you perform the following changes for:
Create fulfillment: Shopify is removing the endpoint for this action in favor of
fulfillmentOrder-based architecture. Unfortunately, the confirmation of the deprecation only came in January 2023. We have released a new “Create fulfillment” action that aligns with Shopify’s new fulfillment order based architecture. Please migrate any running recipes using the old “Create fulfillment” action to the new one at the soonest. More details can be found in this Shopify Community post (opens new window).Create transaction: we will be adding 2 optional fields:
authorizationandparent ID. While these are optional, it is recommended to provide at least one of the above parameters as omitting them may result in errors if you also use an order editing app.
New fields supported
# Other things to take note of
- Custom action: while immediate action is not required, we want to take this time to inform you that Shopify will be removing XML response format starting from version
2022-07. This means that regardless of the API version you specify in thepathparameter, requests that expects an XML response will result in a 404 error, while requests that send an XML payload will result in a 415 error.
