# Test cases overview
Test cases are available at the recipe level. To view the list of test cases, choose a recipe and navigate to the Test cases interface. This interface displays a table containing all test cases created for this recipe.
# What is a test case?
A test case is a set of mock data and checks for specific steps of a particular recipe.
You can create multiple test cases for any recipe you plan to test.
A test case defines:
- What steps should use mock (simulated) data and the mock data that should be used.
 - What step output data must be checked and the expected result of the check.
For each test case, you can add a unique name and provide a description of the purpose of the test case.
List of test cases
Each test case contains the following data columns:
Name
The name of the test case. We recommend using a descriptive name that helps you identify the test.
Modified on
The date the test case was most recently modified.
Last run
The status of the most recent run.
Passed/Failed
The result of the most recent run.
Never active
The test case was never run.
Last run recipe version
The version of the recipe that was used to run the test case.
Last run date
The date of the most recent run.
Case summary
The number of checks and mocked steps.
Description
The description of the test.
Additionally, click the ... (ellipsis) to access the action menu. From here, you can perform the following actions:
- Delete a test case
 - Clone (duplicate) a test case
