# UndefinedColumn - Column does not exist
You may encounter the following SQL error when you run queries:
This error indicates that the database can't find the specified column. It often occurs when the underlying table has changed column names.
Example of Column does not exist Example of Column does not exist
# Why it happens
This error can occur for the following reasons:
  • A column name in the SQL statement doesn't match any column in the table.
  • The query includes unintended column names in Order by or Where conditions.
  • The recipe uses outdated schema information from a previous step.
# How to troubleshoot
Complete the following steps to resolve the issue:
Verify the column names in your query. Ensure that each column exists in the table schema.
Check the input fields for unintended column names. Columns in Order by or Where clauses can also cause this error.
Confirm with your database administrator that the required columns exist in the table.
Refresh the recipe to update the schema from your connections if your recipe uses a datapill from a previous step.
Last updated: 9/23/2025, 7:11:15 PM
