# Undefined method for nil:NILClass
Troubleshoot undefined method error under 3 min
You may encounter the following error when you use a formula on a datapill that doesn't contain a value:
Undefined method for nil:NilClass
This error indicates that the datapill didn't contain a value at runtime.
 Example of Undefined method for nil:NILClass
# Why it happens
This error occurs when the value of the datapill is null at runtime. The following scenarios can cause this error:
- A Get action returns records with missing fields.
 - A Search action returns no results.
 - A SQL query returns 0 rows.
For example, your datapill doesn't contain any value when step 2 has missing fields, which means that step 3 (Update lead in Marketo) applies a formula to an empty datapill.
Since the capitalize formula doesn't apply to a datapill with no value, the job fails with the following error:
Error calculating input for field 'company':
Formula received a nil value:
undefined method `capitalize' for nil:NilClass
# How to troubleshoot
Use the & safe navigation operator in your formula to prevent errors when the datapill is null. For example:
[Datapill]&.capitalize
The operator checks if the datapill has a valid value:
- The operator applies the formula if the datapill contains a value.
 - The operator skips the formula and returns
nullif the datapill is null.
This ensures the recipe continues without failure.
 Example of using the safe navigation operator with the .capitalize formula
 Last updated: 9/23/2025, 8:10:28 PM
