Environment properties
Use the endpoints below to manage environment properties programmatically.
Rate limits
Environment property resources have the following rate limits:
TypeResourceLimit
AllAll Environment properties endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/propertiesLists environment properties that matches a prefix.
POST/api/propertiesUpserts environment properties.
List properties by prefix
Returns a list of environment properties belonging to a customer that matches a prefix. For example, if the prefix provided is salesforce_sync., any environment property with a name beginning with 'salesforce_sync.' will be returned.
GET /api/properties
Parameters
NameTypeDescription
prefixstring
required
Return properties with the given prefix. E.g: salesforce_sync..
Sample request
shell
curl  -X GET 'https://www.workato.com/api/properties?prefix=salesforce_sync.' \
Response
json
  "salesforce_sync.object_name": "Account",
  "salesforce_sync.object_field": "Id"
Upsert property
Upserts environment properties. Matches by the names of the properties provided in the request.
POST /api/properties
PROPERTY LIMITS
Environment properties have the following limits:
DescriptionLimit
Maximum number of environment properties per environment1,000
Maximum length of an environment property name100 characters
Maximum length of an environment property value1,024 characters
Payload
NameTypeDescription
propertiesHash
required
Contains the names and values of the properties to upsert.
Sample request
shell
curl  -X POST https://www.workato.com/api/properties \
      -d '{ "properties": { "zendesk.object": "Ticket", "zendesk.key": "ticket_id" }}'
Response
json
  "success": true
