API clients
The following endpoints allow you to manage your API clients via developer APIs. This allows you to programmatically create new API clients when onboarding new teams or rotate API tokens regularly for all your API clients.
Rate limits
API client resources have the following rate limits:
| Type | Resource | Limit |
| All | All API client endpoints | 60 requests per minute |
Quick reference
| GET | /api/developer_api_clients | List Developer API Clients. |
| POST | /api/developer_api_clients | Create Developer API Client. |
| GET | /api/developer_api_clients/:id | Get Developer API Client by ID. |
| PUT | /api/developer_api_clients/:id | Update Developer API Clients. |
| DELETE | /api/developer_api_clients/:id | Delete Developer API Client. |
| POST | /api/developer_api_clients/:id/regenerate | Regenerate Developer API Client token. |
| GET | /api/developer_api_client_roles | List Developer API Client roles. |
List Developer API clients
List all Developer API clients.
GET /api/developer_api_clientsQuery parameters
| Name | Type | Description |
| per_page | integer | Number of API clients to return in a single page. Defaults to 100. Max is 100. |
| page | integer | Page number of the API clients to fetch. Defaults to 1. |
Sample Request
shell
curl -X GET https://www.workato.com/api/developer_api_clients \
-H 'Authorization: Bearer <api_token>'Response
json
"result": {
"count": 3,
"items": [
"id": 40947,
"name": "Test",
"api_privilege_group_id": 26779,
"created_at": "2023-02-22T01:55:35.739-08:00",
"updated_at": "2023-02-28T01:23:18.046-08:00",
"all_folders": false,
"folder_ids": [
26138,
26136
"environment_name": "Development",
"environment_id": 3218,
"ip_allow_list": "192.0.2.10,198.51.100.5",
"token": {
"updated_at": "2023-02-22T09:55:36.427Z"
}Create a Developer API client
Create a Developer API client.
POST /api/developer_api_clientsPayload
| name | String | Name of the API client |
| api_privilege_group_id | integer | API client role ID |
| all_folders | boolean required | Flag indicating whether API client has access to all folders |
| folder_ids | array | Array of folder IDs. Required if all_folders is false. |
| environment_name | string | Name of the environment. Required if your workspace has environments enabled. |
| ip_allow_list | string optional | Array of IP addresses allowed to access the API client. Defaults to all IPs if not specified. |
Sample Request
shell
curl -X POST https://www.workato.com/api/developer_api_clients \
-d '{
"name": "Test Client",
"all_folders": true,
}'Response
json
"result": {
"id": 40948,
"created_at": "2023-02-28T02:09:07.255-08:00",
"updated_at": "2023-02-28T02:09:07.586-08:00",
"token": {
"updated_at": "2023-02-28T10:09:07.579Z",
"value": "wrkaus-eyJhbGciOiJSUz..."
}Get a Developer API client by ID
Get a Developer API client by ID.
GET /api/developer_api_clients/:idPath parameters
| id | integer required | ID of the API Client. |
Sample Request
shell
curl -X GET https://www.workato.com/api/developer_api_clients/123 \
json
"result": {
"id": 40948,
"token": {
"user": {
"id": 3218,
"name": "Workato Customer Success test"
}Update a Developer API client
Update a Developer API client.
PUT /api/developer_api_clients/:idPath parameters
Payload
Sample Request
shell
curl -X PUT https://www.workato.com/api/developer_api_clients/123 \
-d '{
}'Response
json
"result": {
"id": 40948,
"token": {
"user": {
"id": 3218,
}Delete a Developer API client
Delete a Developer API client.
DELETE /api/developer_api_clients/:idPath parameters
Sample Request
shell
curl -X DELETE https://www.workato.com/api/developer_api_clients/123 \
json
"result": "success"
}Regenerate a Developer API Client token
Regenerates the API token for an API client. This invalidates the previous API token.
POST /api/developer_api_clients/:id/regeneratePath parameters
Sample Request
shell
curl -X POST https://www.workato.com/api/developer_api_clients/123/regenerate \
json
"result": {
"id": 40890,
"name": "Test new API client",
"created_at": "2023-01-29T22:30:12.930-08:00",
"updated_at": "2023-02-28T02:19:16.542-08:00",
"token": {
"updated_at": "2023-02-28T10:19:16.530Z",
"value": "wrkaus-eyJhbGc..."
}List Developer API client roles
List all Developer API Client roles.
GET /api/developer_api_client_rolesQuery parameters
Sample Request
shell
curl -X GET https://www.workato.com/api/developer_api_client_roles \
json
"result": {
"items": [
"id": 26779,
"name": "Admin",
"created_at": "2023-01-18T04:31:03.302-08:00",
"updated_at": "2023-02-28T01:23:01.427-08:00"
"count": 3,
"page": 1,
"per_page": 100
}Last updated:
