MCP Servers
Use this resource to manage MCP (Model Context Protocol) servers programmatically.
TOKEN AND HASHED TOKEN AUTHENTICATION
hashed_token is the default authentication type for token-based MCP servers. The token authentication type is considered legacy. Existing servers using token continue to work, but new servers use hashed_token. Refer to Create a hashed token for more information on how to manage tokens on hashed_token servers.
Quick reference
List MCP servers
Returns a list of MCP servers in the workspace.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_serversQuery parameters
| Name | Type | Description |
| project_id | number optional | Filter by project ID. |
| folder_id | number optional | Filter by folder ID. |
| authentication_method | string optional | Filter by authentication method. Accepted values: hashed_token, token (legacy), workato_idp. |
| page | number optional | Page number. Defaults to 1. |
| per_page | number optional | Number of items per page. Maximum is 50. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers?folder_id=:folder_id_value' \
-H 'Authorization: Bearer <api_token>'Sample response
"data": [
"id": 1001,
"name": "Sales Tools MCP Server",
"description": "Provides CRM and deal management tools for AI clients",
"folder_id": 27180380,
"project_id": 13595198,
"authentication_method": "hashed_token",
"tools_count": 5
"id": 1002,
"name": "HR Automation Server",
"description": "HR onboarding and employee management tools",
"authentication_method": "workato_idp",
"tools_count": 3
"count": 2,
"page": 1,
"per_page": 50
}Create an MCP server
Creates a new MCP server in the workspace.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_serversPayload
| name | string required | Server name. |
| folder_id | number required | Folder ID for the MCP server. |
| description | string optional | Server description. |
| asset_id | number optional | API collection ID. Omit to create a project asset server. |
| tools | array of objects optional | Tools to assign to the server at creation. Each object requires trigger_application (string) and id (string). id is a number when used with workato_recipe_function and workato_api_platform tools. id is a string handle when used with workato_genie tools. |
HASHED TOKEN AS DEFAULT AUTH TYPE
MCP servers use hashed_token as the default auth_type unless you specify a different authentication type. Use the MCP hashed tokens endpoints to manage tokens on a hashed_token server.
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers \
-d '{
"name": ":name",
"description": ":description",
"folder_id": :folder_id_value,
"tools": [
"trigger_application": ":trigger_application",
"id": ":tool_id"
}'Sample response
"data": {
"id": 1001,
"asset_type": "api_collection",
"logo_url": "https://www.workato.com/images/mcp-server-logo.png",
"tools_count": 1,
"mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=abc123xyz",
"auth_type": "hashed_token",
"idp_user_group_ids": [],
"api_collection": null,
"created_at": "2025-10-15T13:41:05.207-07:00",
"updated_at": "2025-10-15T13:41:05.207-07:00"
}Get MCP server details
Retrieves details for a specific MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handleURL parameters
| handle | string required | MCP server handle. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
"data": {
"id": 1001,
"tools_count": 5,
"updated_at": "2025-10-16T09:22:11.100-07:00"
}Update an MCP server
Updates an existing MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handleURL parameters
Payload
| name | string optional | Server name. |
| auth_type | string optional | Authentication type. Accepted values: hashed_token (default), token (legacy), workato_idp. |
| idp_user_group_ids | array of strings optional | Identity provider user group IDs that have access to the server. Only applicable when auth_type is workato_idp. |
| folder_id | number optional | Target folder ID to move the server. |
LEGACY AUTH TYPE
Workato retains the token auth_type for backward compatibility. New servers should use hashed_token. Create token profiles with the MCP hashed tokens endpoints to switch an existing server's auth_type to hashed_token. hashed_token servers use individually named, revocable token profiles instead of a single server-level token.
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
-d '{
"name": ":name",
"auth_type": ":auth_type"
}'Sample response
"data": {
"id": 1001,
"name": "Sales & CRM Tools MCP Server",
"description": "Provides CRM, deal management, and pipeline tools for AI clients",
"tools_count": 5,
"updated_at": "2025-10-17T11:05:33.812-07:00"
}Delete an MCP server
Deletes an MCP server.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handleURL parameters
Sample request
curl -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
Returns 204 No Content on success.
Renew MCP server authentication token
Generates a new authentication token for an MCP server and invalidates the previous token. Use this endpoint to rotate credentials after a security event or as part of a regular credential rotation policy.
LEGACY ENDPOINT
This endpoint applies to servers using the legacy token auth type, which carry a single server-level token. Use Refresh a hashed token for hashed_token servers, which operates on an individual, named token profile.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renewURL parameters
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renew' \
Returns the updated MCP server object with the new mcp_url containing the refreshed token.
"data": {
"id": 1001,
"tools_count": 5,
"mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=newtoken789",
"auth_type": "token",
"updated_at": "2025-10-18T08:00:00.000-07:00"
}MCP hashed tokens
MCP hashed token endpoints manage individual, named token profiles for MCP servers with hashed_token as the auth_type. This is an update from the the legacy token auth type in which a single server-level token is managed through token renewal. hashed_token supports up to 50 named, independently revocable token profiles per server.
Creates a token profile for a server with hashed_token as the auth_type.
MCP servers support a maximum of 50 active hashed tokens.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokensURL parameters
| mcp_server_handle | string required | MCP server handle. |
Payload
| name | string required | Token profile name. Must be non-blank, no longer than 100 characters, and case-insensitively unique among the server's active tokens. |
Additional constraints
This endpoint is only available for
hashed_tokenservers. Calling this endpoint on atokenorworkato_idpserver returns an error.
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens' \
-d '{
"name": ":name"
}'Sample response
Returns 201 Created with the token profile at the response root rather than nested under data.
"id": 731,
"name": "Production token",
"created_at": "2026-07-10T10:00:00.000Z",
"created_by": {
"id": 42,
"full_name": "Example User"
"token_first_symbols": "abc",
"token_last_symbols": "wxyz",
"plain_token": "<plain_token>"
}PLAIN TOKEN IS SHOWN ONCE
plain_token is returned only at creation and can't be retrieved later. Store the token securely. You can use the refresh the token endpoint to generate a new token if needed.
Delete a hashed token
Deleting a hashed token doesn't remove it from the database. The hashed token profile is marked as inactive. The token immediately stops working and can no longer authenticate MCP requests.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:idURL parameters
| id | number required | Token profile ID. |
Sample request
curl -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id' \
Returns 200 OK with an empty response body.
This endpoint is available only for hashed_token servers. Deleted profiles no longer appear in the server's mcp_profiles array.
Invalidates the current token value for a profile and returns a fresh plain token.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refreshURL parameters
| id | number required | Active token profile ID. |
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refresh' \
Returns 200 OK. The response has the same root-level shape as token creation and contains the plain_token, token_first_symbols, and token_last_symbols.
"id": 731,
"created_by": {
"id": 42,
"token_first_symbols": "def",
"token_last_symbols": "uvwx",
"plain_token": "<new_plain_token>"
}This endpoint is available only for hashed_token servers. The returned plain_token is exposed only in this response. Store the token securely as you can't retrieve it later.
Assign tools to an MCP server
Assigns one or more tools to an MCP server. Tools already assigned to the server aren't duplicated.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_toolsURL parameters
Payload
| tools | array of objects required | Tools to assign. Each object requires trigger_application (string) and id (string). |
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_tools' \
-d '{
"tools": [
"trigger_application": ":trigger_application_1",
"id": ":tool_id_1"
"trigger_application": ":trigger_application_2",
"id": ":tool_id_2"
}'Sample response
Returns the updated MCP server object.
"data": {
"id": 1001,
"tools_count": 7,
"updated_at": "2025-10-18T09:15:22.000-07:00"
}Assign user groups to an MCP server
Assigns identity provider user groups to an MCP server. Only applicable when the server's auth_type is workato_idp.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groupsURL parameters
Payload
| idp_user_group_ids | array of strings required | IDs of the user groups to add. |
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groups' \
-d '{
"idp_user_group_ids": [":user_group_id_1", ":user_group_id_2"]
}'Sample response
Returns the updated MCP server object with the assigned user group IDs reflected in idp_user_group_ids.
"data": {
"id": 1002,
"asset_type": "project_asset",
"tools_count": 3,
"mcp_url": "https://www.workato.com/mcp/servers/hr-automation-server?token=hrtoken456",
"auth_type": "workato_idp",
"idp_user_group_ids": ["group-abc123", "group-def456"],
"created_at": "2025-10-15T10:00:00.000-07:00",
"updated_at": "2025-10-18T10:30:00.000-07:00"
}Remove user groups from an MCP server
Removes identity provider user groups from an MCP server.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groupsURL parameters
Payload
| idp_user_group_ids | array of strings required | IDs of the user groups to remove. |
Sample request
curl -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groups' \
-d '{
"idp_user_group_ids": [":user_group_id"]
}'Sample response
Returns the updated MCP server object with the specified groups removed from idp_user_group_ids.
"data": {
"id": 1002,
"tools_count": 3,
"idp_user_group_ids": ["group-def456"],
"updated_at": "2025-10-18T11:00:00.000-07:00"
}Move MCP server to a different folder
Moves an MCP server to a specified folder.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folderURL parameters
Payload
| folder_id | number required | Target folder ID. |
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folder' \
-d '{
}'Sample response
Returns the updated MCP server object with the new folder_id reflected in created_at and updated_at timestamps.
"data": {
"id": 1002,
"tools_count": 3,
"updated_at": "2025-10-18T12:00:00.000-07:00"
}Get server policy configuration
Retrieves the security policy configuration for an MCP server, including rate limits, usage limits, Classless Inter-Domain Routing (CIDR), and IP addresses.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policiesURL parameters
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
"id": 501,
"mcp_server_id": 1001,
"rate_limits": {
"per_minute": 60
"quota_limits": {
"per_day": 10000
"ip_allow_list": ["203.0.113.0/24"],
"ip_deny_list": [],
}Update server policy configuration
Updates the security policy configuration, including IP for an MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policiesURL parameters
Payload
| mcp_server_policy | object required | Policy configuration object. |
| mcp_server_policy[rate_limits] | object optional | Rate limit configurations. |
| mcp_server_policy[quota_limits] | object optional | Quota limits configurations. |
| mcp_server_policy[ip_allow_list] | array of strings optional | IP addresses or CIDR ranges to allow. |
| mcp_server_policy[ip_deny_list] | array of strings optional | IP addresses or CIDR ranges to deny. |
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
-d '{
"mcp_server_policy": {
"rate_limits": { "per_minute": :per_minute_value },
"quota_limits": { "per_day": :per_day_value },
"ip_allow_list": [":ip_allow_1", ":ip_allow_2"],
"ip_deny_list": []
}'Sample response
"id": 501,
"rate_limits": {
"per_minute": 30
"quota_limits": {
"per_day": 5000
"ip_allow_list": ["203.0.113.0/24", "198.51.100.42"],
"ip_deny_list": [],
"updated_at": "2025-10-18T14:00:00.000-07:00"
}List tools for an MCP server
Returns a paginated list of tools assigned to an MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/toolsURL parameters
Query parameters
| vua_required | boolean optional | Filter by whether Verified User Access (VUA) is required. |
| search | string optional | Search term to filter tools by name. |
| per_page | number optional | Number of items per page. Defaults to 100. Maximum is 100. |
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools' \
"data": [
"id": 3001,
"name": "Create Salesforce Lead",
"description": "Creates a new lead record in Salesforce CRM",
"trigger_application": "workato_api_platform",
"action_applications": ["salesforce"],
"flow_id": 66870001,
"vua_required": false
"id": 3002,
"name": "Send Deal Notification",
"description": "Sends a Slack notification when a deal stage changes",
"trigger_application": "workato_recipe_function",
"action_applications": ["slack"],
"flow_id": 66870002,
"vua_required": true
"count": 2,
"page": 1,
"per_page": 100
}Update tool description
Updates the description of a tool within an MCP server. This modifies the description shown to AI clients without affecting the underlying recipe or API endpoint.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:idURL parameters
| id | number required | Tool ID. |
Payload
| description | string optional | New description for the tool. |
Sample request
curl -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
-d '{
}'Sample response
"id": 3001,
"description": "Creates a new lead record in Salesforce CRM with name, email, and company details",
}Delete a tool
Removes a tool from an MCP server.
API ENDPOINTS CAN'T BE DELETED
Only tools backed by recipe functions or genies can be deleted. Attempting to delete an API endpoint tool returns a 400 Bad Request error.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:idURL parameters
Sample request
curl -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
List identity provider user groups
Returns a paginated list of identity provider user groups available in the workspace. Use the group IDs from this response when assigning access to MCP servers that use workato_idp authentication.
GET https://YOUR_DATA_CENTER/api/mcp/user_groupsQuery parameters
Sample request
curl -X GET 'https://YOUR_DATA_CENTER/api/mcp/user_groups' \
"data": [
"id": "group-abc123",
"name": "Sales Team",
"users_count": 24,
"created_at": "2025-01-10T08:00:00.000Z",
"updated_at": "2025-09-15T12:30:00.000Z"
"id": "group-def456",
"name": "HR Admins",
"users_count": 6,
"updated_at": "2025-08-20T10:00:00.000Z"
"count": 2,
"page": 1,
"per_page": 100
}Last updated:
