Test Automation
The following endpoints enable you to use the Test Automation feature programmatically.
Rate limits
Test Automation resources have the following rate limits:
| Type | Resource | Limit |
| All | All Test Automation endpoints | 60 requests per minute |
Quick reference
| POST | /api/test_cases/run_requests | Run test cases. |
| GET | /api/test_cases/run_requests/{id} | Get the current state of a test case run request. |
| GET | /api/recipes/{recipe_id}/test_cases | Get test cases. |
Run test cases
Use this endpoint to run test cases. You can specify the test cases to run in the following ways:
- All test cases of all recipes in a manifest
- All test cases of all recipes in a project
- All test cases of all recipes in a folder
- All test cases belonging to a particular recipe
- Test cases you specify
This endpoint is asynchronous. You can use the run request id to poll the current state of the request using the /api/test_cases/run_requests/{id} endpoint.
POST /api/test_cases/run_requestsRequest body
| Name | Type | Description |
| manifest_id | integer optional | Run test cases for all recipes in the export manifest you specify. |
| project_id | integer optional | Run test cases for all recipes in the project you specify. Use the list projects endpoint to retrieve the IDs of all projects in your workspace. |
| folder_id | integer optional | Run test cases for all recipes in the folder you specify. |
| recipe_id | integer optional | Run all test cases for the recipe you specify. |
| test_case_ids | array of strings optional | Run specific test cases by ID. |
Sample request
shell
curl -X POST https://www.workato.com/api/test_cases/run_requests \
-d '{
"manifest_id": "0"
}'Sample response
json
"data": {
"id": "cirr-AHNFkza6-dwMArc",
"status": "running",
"user": {
"id": 0
"created_at": "2023-06-01T01:40:00.000-07:00",
"updated_at": "2023-06-01T01:40:00.000-07:00",
"results": [
"recipe": {
"id": 0,
"name": "string"
"test_case": {
"id": "citc-AG48N4xo-g6ccgP",
"name": "string"
"job": {
"id": "j-AHNFpnRa-sMWLYJ"
"status": "pending"
}Get the current state of a test case run request
Get the current state of a test case run request. For completed requests, Workato also returns the test coverage data along with the results.
GET /api/test_cases/run_requests/{id}URL parameters
| id | string required | The run request's ID. |
Sample request
shell
curl -X GET https://www.workato.com/api/test_cases/run_requests/{id} \
-H 'Authorization: Bearer <api_token>'Sample response
json
"data": {
"status": "completed",
"user": {
"id": 0
"coverage": {
"value": 87.5,
"total_actions_count": 8,
"total_visited_actions_count": 7,
"recipes": [
"id": 0,
"version_no": 0,
"coverage": {
"value": 87.5,
"not_visited_actions": [
"step_number": 4
"results": [
"recipe": {
"id": 0,
"name": "string"
"test_case": {
"name": "string"
"job": {
"status": "succeeded"
}Get test cases
Returns a collection of test cases belonging to the recipe you specify.
GET /api/recipes/{recipe_id}/test_casesURL Parameters
| recipe_id | integer required | The ID of the recipe you plan to retrieve test case details from. |
Sample request
shell
curl -X GET https://www.workato.com/api/recipes/{recipe_id}/test_cases \
json
"data": [
"description": "string",
"name": "string"
}Last updated:
