Component actions ​
Component actions in Workflow apps provide a dynamic and interactive user experience by enabling real-time responses to UI events such as button clicks, page loads, drop-down value changes, and table row selections. This enables users to complete a range of tasks, including:
  • Run recipe: Allow users to complete tasks that involve external systems directly within the app interface
  • Reset/reload components: Clear component values or reload a component after an action is taken
  • Open a webpage: Direct app-users to a specific URL
  • Complete a task: Review, approve, and complete requests within the Workflow apps portal
  • Save data to table: Save request and approval data in a data table
  • Set value: Configure a value for a variable or page component
Compatible components ​
Specific page components have the Action property which enables you to define the action to take within the page editor. The following table describes available actions and compatible components:
ActionTrigger eventsCompatible components
Run recipe
  • Button click
  • Drop-down value change
  • File value change
  • Page load
  • Table row selection
  • Button
  • Single-select drop-down
  • Multi-select drop-down
  • File
  • Page (on page load)
  • Table
  • Button click
  • File value change
  • Button
  • File
  • Table
Open a webpageButton clickButton
Complete taskButton clickButton
Save data to tableButton clickButton
Set value
  • Button click
  • File value change
  • Page load
  • Button
  • File
  • Table
The Compatible components column lists the components you configure to perform the action. Set value actions set the value of a different component. Refer to Set value compatible components for the components whose values a Set value action can target.
Default actions ​
Button components must have a defined action. All other component actions have a default state of Do nothing. This means that you must configure components to respond to user actions.
Follow-up actions ​
You can configure one of the following follow-up actions to run after a primary action, such as a Run recipe action, completes:
The default is Do nothing if you don’t configure a follow-up action.
