# Get user data action (batch)
Get user data from the Workflow apps portal.
| Email address | Provide the user email to retrieve the user data. |
| User groups | Select user groups from the list to retrieve user data for all users in each group. |
| Sort by | Specify how to sort the results. Available options include Name, Email, and Status. |
| Sort direction | Determine whether to sort the results in Ascending or Descending order. |
| Entries per page | Limit the number of users returned in this action. The default value is 500 and the maximum value is 500. |
| Next page token | Get users starting with the given offset. |
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
| Users | An object containing information about the user. |
| User ID (Users) | The ID of the user. |
| User name (Users) | The user's name. |
| User email (Users) | The user's email address. |
| Status (Users) | The user's status. |
| Groups (Users) | An object nested within the Users object. |
| Group ID (Groups) | The ID of the group this task is assigned to. |
| Group name (Groups) | The name of the group this task is assigned to. |
| List size (Groups) | The size of the list. |
| List index (Groups) | The list index. |
| Continuation token | The token used to paginate through entries. |
| Entries per page | The number of entries per page. |
Last updated: 8/18/2025, 11:58:41 PM
