SOAP API recipe walkthrough
This walkthrough shows you how to build a SOAP endpoint manually in Workato. The endpoint accepts raw XML, and the recipe parses and validates the SOAP envelope before passing the request to a target API hosted on a private server. This lets external business partners and internal stakeholders access the API's data without connecting to the target API directly.
This walkthrough builds the Workato-side endpoint in front of the target API, not the target API itself. You can build and test much of the endpoint before the target API is available, but the recipe can return data from the target API only after that API is reachable.
What you'll build
In this walkthrough, you'll build the following components:
  • A SOAP API recipe that accepts XML requests, identifies the requested operation, checks whether the operation is approved, and forwards approved requests to the target API.
  • A separate API recipe that returns the WSDL that describes the SOAP API.
  • An API recipe collection that exposes both recipes as endpoints.
The SOAP API recipe uses three response paths:
  • success when the target API request succeeds.
  • not_found when the requested operation isn't on the approved list.
  • error when the request to the target API fails.
Prerequisites
Ensure the following before you create the SOAP API recipe:
  • Access to the API platform. The API platform is available to customers on specific pricing plans. Refer to your pricing plan and contract for more information.
  • Create privileges for API collections and endpoints and recipes.
  • A lookup table that contains the SOAP operations the endpoint should allow.
  • An HTTP connection for the target API. Configure the connection to use an on-prem group to reach an API hosted on a private server.
  • The request details required to call the target API, such as its URL, method, headers, and payload format.
  • A WSDL that describes the SOAP API if you plan to expose the WSDL endpoint in this walkthrough. This walkthrough shows how to return the WSDL, not how to author one.
Create the SOAP API recipe
Complete the following steps to create the SOAP API recipe:
Create a new recipe and give it a name.
Select a folder for the recipe.
Click Build an API endpoint as the starting point.
Click Start building.
The Build an API endpoint starting point automatically creates a recipe with a New API request trigger and a Respond to API request action.
Define the recipe's trigger
The New API request trigger defines the request and response structures for the endpoint.
  1. Define the request structure
  2. Define the response structure
Complete the following steps to define the request structure:
Click the trigger to open its Setup tab.
Expand the Request section if it isn't open already.
Select Text/XML in the Content type field. This allows the trigger to accept the raw XML body of the SOAP request instead of parsing the request as JSON. Refer to Supported data types for the full list of content type options.
Define request headers in the Request header section if callers must provide them.
The response structure defines the outputs the SOAP API recipe can return. This recipe uses three responses: success, not_found for an operation that isn't on the approved list, and error if the target API request fails.
Complete the following steps to define the response structure:
Expand the Response section if it isn't open already.
Define response headers in the Response headers field if the endpoint must return them.
Select Add response from the Responses field.
Enter success in the Name field.
Use the HTTP status code field to specify whether the response code is standard or custom.
  • If you select Standard response, choose an HTTP status code from the picklist. For example, 200 - OK for the success response.
  • If you select Custom response, enter a custom HTTP status code. You can specify response codes from 2xx to 5xx.
Repeat the previous two steps to add a not_found response (404 - Not Found) and an error response (500 - Internal Server Error).
Process the SOAP request
Add steps to the recipe to parse the SOAP envelope, validate the requested operation, and call the target API:
  1. Parse and inspect the XML payload
  2. Check whether the operation is approved
  3. Call the target service and handle errors
A SOAP request arrives as a SOAP envelope in the request body. For example:
xml
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <OperationName>
      <Parameter>value</Parameter>
    </OperationName>
  </soap:Body>
</soap:Envelope>
Complete the following steps to parse and inspect the XML payload:
Add the Parse XML document action from XML Tools by Workato. Enter a representative SOAP envelope as the Sample document so the action generates datapills for the values you need from the SOAP body.
Use the datapill that identifies the requested operation in the next step. Your sample document should match the structure of the SOAP requests your endpoint receives.
Add the Search entries action from Lookup tables by Workato. Search the lookup table that contains your approved operations using the operation value parsed from the SOAP body.
Check if the operation is approved
Branch the recipe based on whether the lookup table contains the requested operation.
Add an IF condition that checks whether the lookup table search returned a match: the entry ID from the previous step is present.
Add an ELSE block to reject the requested operation when the lookup table search doesn't return a match.
Inside the ELSE block, select the return action (Action in an app > API platform by Workato > Respond to API request) and choose the not_found response.
Inside the IF block, wrap the call to the target API in a Handle errors control statement. This lets the endpoint return a defined API response if the target API request fails.
Complete the following steps:
Inside the IF block, click + Add step and select Handle errors. Workato creates a Monitor actions for error block and an Error found? block.
Inside the Monitor actions for error block, add Action in an app > HTTP > Send request. Select the HTTP connection for the target API. For a target API hosted on a private server, use a connection that forwards requests through an on-prem group.
Configure the request using the URL, method, headers, and payload expected by the target API.
Immediately after the Send request action, still inside the Monitor actions for error block, add Action in an app > API platform by Workato > Respond to API request. Choose the success response and map the payload returned by the target API to the response body.
Configure the Error found? block. Choose whether to retry the target API request and how many times.
Inside the Error found? block, add Action in an app > API platform by Workato > Respond to API request and choose the error response. This response runs if the target API request still fails after any configured retries.
Create a recipe to return the WSDL
Create a separate API recipe that returns the WSDL describing the SOAP API. Create this recipe in the same folder as the SOAP API recipe, so you can add both recipes to the same API recipe collection.
The WSDL can be stored in Workato FileStorage. Configure the recipe to retrieve the WSDL and return its contents as the response body.
WSDL API recipeWSDL API recipe
Test the recipe logic
Save and test the SOAP API recipe as you build it. Building recipes in small steps makes it easier to isolate problems before you test the complete endpoint.
Test request parsing and operation validation
The target API doesn't need to be reachable to test the trigger, XML parsing, and lookup table logic.
Skip the Send request action and send sample SOAP requests to verify that:
  • The recipe parses the value used to identify the requested operation.
  • An approved operation follows the IF branch.
  • An operation that isn't in the lookup table follows the ELSE branch and returns the not_found response.
Test the error path
You can also test the error response before the target API is available. Leave the Send request action enabled and send a request that reaches that step while the target API is unavailable or otherwise causes the HTTP request to fail.
The failed request enters the Error found? block and returns the error response after any configured retries.
Test the success path with a public API
You can temporarily point the Send request action at a reachable public test API, such as https://jsonplaceholder.typicode.com/todos, to test the recipe's success path before your target API is available.
When you use JSONPlaceholder for this test:
  • Configure the Send request action for the public test endpoint rather than the private target API.
  • Match the Request content type field to the payload you're sending.
  • Set the Response content type field to Text to pass the response through without parsing it as XML or JSON.
  • After you validate the recipe flow, restore the Send request action to the real target API configuration.
Group the recipes into a collection
Group the SOAP API recipe and WSDL recipe into an API recipe collection. Select Use existing recipes and choose the folder that contains both recipes.
This creates two endpoints: one that processes SOAP requests and one that returns the WSDL.
NEW ENDPOINTS INACTIVE BY DEFAULT
New endpoints are inactive by default. You must activate both endpoints before other recipes or apps can call them. Refer to Activating or deactivating an endpoint for more information.
Test the endpoint end-to-end
You can test the SOAP endpoint with the real target API after you activate the endpoints and the API is reachable.
Send an approved operation and verify the complete flow:
  1. The endpoint accepts the SOAP request as raw XML.
  2. The recipe parses the SOAP body and identifies the requested operation.
  3. The lookup table confirms that the operation is approved.
  4. The HTTP action sends the request to the target API.
  5. The recipe returns the target API payload through the success response.
You can send the request with curl or another HTTP client. The Try it out tester doesn't expose a field for a raw request body, so use a client that lets you send the SOAP envelope directly:
shell
curl -X POST 'ENDPOINT_URL' \
  -H 'api-token: API_KEY' \
  -H 'Content-Type: text/xml' \
  --data-binary '<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><OperationName><Parameter>APPROVED_OPERATION</Parameter></OperationName></soap:Body></soap:Envelope>'
Refer to Test a recipe endpoint for how to create the API client and key required by the curl request.
The SOAP API recipe is now ready to implement with your target API.
