# Google Vision
Google Vision (opens new window) uses machine learning to get insight from your images. It quickly classifies images into thousands of categories, detects individual objects and faces in images, and reads printed words contained in images. You can build metadata on your image catalog, moderate offensive content, or enable new marketing scenarios by using image sentiment analysis.
Workato's Google Vision connector allows you to build powerful automations and connect with other applications.
# API version
The Google Vision connector uses Google Cloud Vision API v1 (opens new window).
# How to connect to Google Vision on Workato
Google Vision uses OAuth 2.0 for authentication.
Complete the following steps to establish a connection to Google Vision in Workato:
Search for and select Google Vision
as your connection on the New connection page.
Google vision connection setup
Select the project or folder where you plan to store the connection from the Location drop-down menu.
Click Sign in with Google.
Click Allow when prompted to authorize Workato to access your Google account.
