# IBM Db2
IBM Db2 is a Relational Database Management System (RDBMS). IBM designed Db2 to store, analyze, and retrieve data efficiently, and first launched in 1982. The modern version of Db2 supports object-oriented features, and non-relational structures with XML.
# Supported features
The IBM Db2 Connector supports the following features:
  • IBM Db2 Instances connected through OPA
  • Client-side SSL/TLS connections; it supports both self-signed, and CA certificates
# Actions
# Connecting to Workato
Explore the IBM Db2 Connection setup guide for instructions on connecting Workato to your IBM Db2 database.
Last updated: 1/16/2026, 4:23:47 PM
