# Minimum permissions to run actions and triggers
The following permissions are required to run actions and triggers.
# New IDoc trigger
Authorization Object Activity (ACTVT) Extension (EDI_CIM) Basic type (EDI_DOC) Transaction Code (EDI_TCD)
S_IDOCDEFT 03 [extension of IDOC if any] [Basic type of IDoc - e.g. DEBMAS07] WE30
Receive IDoc permissions
# Send IDoc action
Additionally, sending an IDoc requires the following authorization:
Authorization Object Message Type (EDI_MES)
B_ALE_RECV [Message type of IDoc - e.g. DEBMAS]
Send IDoc permissions
# Run RFC action
Unfortunately, the authorizations depend largely on the RFC chosen and its parameters as well. To this end, we would suggest using ST01 to find the absolute minimum permissions required. You can use t-code ST01 to set up a trace. Select Authorization check and provide the user name of the Workato user in General filters.
SAP connection
Turn your trace on by selecting Trace On in the top bar. After this, get your OPA live and begin to attempt to run the triggers and actions. With only the minimum permissions set out to create the integration user, you should hit errors. You can observe the authorization errors by selecting Analysis in the top navigation bar.
Select display and you should see where your permissions have failed. Add these permissions to the Authorization role you created for Workato in Step ... of the setup guide. The following example demonstrates how to read the Trace display. This enables you to determine additional required authorizations.
SAP connection
TURN OFF TRACE
When complete, ensure that you turn trace off. Turn off trace by selecting Trace Off in t-code ST01.
Last updated: 2/26/2025, 9:17:11 PM
