App Events vs Agent orchestration
Use this documentation to determine whether App Events or the Assign task to genie action is the right tool for your use case.
Ask yourself: Does a user need to receive a message and potentially take action?
- Yes: Use App Events
- No: Use the Assign task to genie action
App Events require a user. The genie reaches out to a specific, identified user through the chat interface. The user receives the message, responds, and the conversation continues.
Assign task to genie doesn't require a user. The genie processes a task in the background by reasoning, calling skills, and returning a structured result to the recipe. No conversation thread is created.
When to use App Events
Use App Events when:
- A user needs to be informed and may need to take action. For example, a ticket they created was updated, or a renewal opportunity is approaching.
- User judgment is required mid-process. The genie presents context and options and the user decides.
- The downstream skill requires Verified User Access. Verified user access requires an active user session.
- The flow involves Business Approvals. Approval notifications surface in the user's chat interface and require user interaction.
- The genie needs to initiate a conversation proactively. For example, scheduled reminders or event-triggered alerts.
App Events can't return a structured value to a recipe. The recipe continues immediately after sending the event without waiting for the genie to finish.
When to use Assign task to genie
Use the Assign task to genie action when:
- Processing is automated and the result feeds back into the recipe. For example, classifying a ticket, summarizing a document, or extracting invoice data.
- No user is present or needed. For example, background jobs or system-to-system integrations.
- The genie's output is structured data, not a message to a user.
- Multiple genies need to collaborate in a pipeline. An orchestrating recipe can assign tasks to specialist genies in sequence, collecting structured outputs from each.
The Assign task to genie action can't be used with:
- Verified User Access because there's no user context in a headless invocation.
- Business Approvals because approval notifications are delivered through the user's chat interface.
- Permission-aware knowledge bases because knowledge bases ingested with user-scoped permissions don't enforce those permissions without a user context.
These are platform constraints, not configuration choices.
App Events and Assign task to genie comparison
Use the following comparison to determine which feature to use:
| App Events | Assign task to genie | |
| User required | Yes ✅ | No ❌ |
| Recipe pauses and waits | No ❌ | Yes ✅ |
| Structured output to recipe | No ❌ | Yes ✅ |
| Verified user access supported | Yes ✅ | No ❌ |
| Business Approvals | Yes ✅ | No ❌ |
| Conversational follow-up | Yes ✅ | No ❌ |
Combine both features
The most powerful architectures combine both features in sequence.
A recipe uses Assign task to genie for automated reasoning, such as classifying a ticket or evaluating escalation criteria. The structured result allows the recipe to use App Events to notify the relevant user and start a conversation. The reasoning is automated while the decision is determined by a user.
Common mistakes
Using App Events where Assign task to genie should be used: A builder needs to classify incoming support tickets automatically. The builder uses App Events to send each ticket to an agent and wait for a classification response. This creates a conversation thread for every ticket and fills agents' chat interfaces with genie messages. The Assign task to genie action, which doesn't require user involvement, should be used in this case.
Using Assign task to genie where App Events should be used: A builder needs to notify sales reps when a renewal opportunity approaches. The builder uses the Assign task to genie action to process the renewal event and return a summary as a datapill. The sales rep doesn't receive the notification because the Assign task to genie action doesn't start a conversation in the chat interface the way App Events do.
Use case recommendations
Refer to the following use case recommendations to help you choose the correct feature for your workflow:
| Use case | Feature | Reason |
| Categorize tickets from an email webhook | Assign task to genie | Automated output with no user interaction required |
| Notify a sales rep of a renewal 30 days out | App Events | Rep needs to receive the message and may act |
| Summarize a contract and extract key clauses | Assign task to genie | Automated output feeds downstream recipe |
| Alert an IT engineer about a P1 incident | App Events | Engineer decides whether to escalate |
| Evaluate whether a ticket meets escalation criteria | Assign task to genie | Automated reasoning with output that feeds conditional logic |
| Notify a user their ticket was updated | App Events | Specific user needs to receive a message |
| Generate a weekly pipeline summary per rep | App Events | Each rep receives a personalized message in the chat interface |
| Extract structured data from an invoice PDF | Assign task to genie | Automated extraction with structured output to recipe |
