Headless API troubleshooting
Use this page to resolve common Headless API failures.
401 auth_failed
Error: A runtime call returns 401 with:
{ "error_code": "auth_failed", "error_message": "Authentication failed.", "request_id": "<uuid>" }Cause and solution: The gateway rejected the credential before reaching the genie. Check the following items in order:
- Wrong token type: Runtime calls use a genie client API key or an OAuth access token rather than the
wrkaus-…Developer API token, which is only for provisioning. - Wrong data center: Credentials are data-center-scoped. Call the
genie-apihost for the same data center your workspace runs in. - Expired or rotated key: Regenerating an API key invalidates the previous API key. Regenerate and update your backend to use the updated API key.
- Malformed header: Send
Authorization: Bearer <token>exactly.
401 user_nonactive_or_missing
Error: An API-key call returns 401 with error_code: "user_nonactive_or_missing".
Cause: The X-IDP-User-Id doesn't resolve to an active, allow-listed user. The runtime returns the same code whether the user doesn't exist, isn't in a user group allow-listed on the genie, or isn't active yet. A user is inactive when they've been invited but haven't accepted the invitation and finished setting up their Workato Identity.
Solution: Confirm the user is active. An invited user must accept their email invitation and finish setting up their Workato Identity before you can assert them, so ask the user to check their email if they haven't completed setup. Then make sure the user belongs to a user group allow-listed on the genie, creating the user first if needed. Look the user up with GET /api/iam/users?query=<email> server-side before the runtime call. The response includes a status field (active or invited), which also lets you show a different message for an unknown user versus a non-allow-listed one.
Client creation or attachment fails
Error: Most Developer API calls succeed, but creating, regenerating, or attaching a genie client fails with a permission error.
Cause: The Developer API client's role is missing the Custom chat interface privilege under Genie building, which governs client management. This is the most commonly missed privilege for Headless setup.
Solution: Grant the role Custom chat interface access with privileges to at least Create. You don't need to rotate the token after adding a privilege.
Related: A genie can have multiple clients, but each client can be attached to only one genie. Detach the client from its current genie first.
Empty stream or repeated blank events
Error: The SSE stream stays open but appears idle, or the genie doesn't reply.
Cause and solution:
- Keep-alive events: During long-running or paused turns, the runtime emits periodic keep-alive events. For example:
system.pingroughly every 30 seconds. Ignore event types your handler doesn't recognize. - Genie not started: The genie must be active. Start it with
POST /api/agentic/genies/:id/start. - Waiting on you (skill confirmation): A
skill.confirmation_requiredevent pauses the turn until you post your decision with Approve or reject a skill. The same stream resumes after you post the resolution. You don't need to reconnect. Each skill that needs confirmation emits its ownskill.confirmation_requiredevent with a uniquecall_idwhen the genie runs multiple skills in parallel. Post a resolution for every pendingcall_id. - Waiting on the user (runtime connection): A
runtime_connection.auth_requiredevent pauses the turn while the user authenticates an upstream connection out-of-band. There's nothing for your client to post, and the original stream doesn't resume. It emits a keep alive, then asystem.stream_interrupted. Detect completion by polling Get a runtime connection link untilstatusisauthorized, then read the resumed reply from message history.
Turn hangs when multiple skills need confirmation
Problem: A turn stays paused after the genie runs several skills in parallel and more than one skill requires confirmation.
Cause: Earlier runtime versions could leave the turn paused in this scenario. This issue is fixed.
Solution: Make sure you posted a resolution for every call_id from each skill.confirmation_required event. Contact support and include the request_id if the turn still hangs after you resolve every call_id.
Duplicate events or event IDs
Problem: You receive the same event, with the same event_id, more than once.
Cause: Reconnecting to a stream and Get events replay events from the point you specify. The replayed events can overlap with events your client already processed, especially if you merge the live stream with recovered events.
Solution: Use event_id as the unique key and discard events you've already processed. Use seq_num to order events within a genie run. Don't repeat side effects for a duplicate, such as showing a second confirmation prompt or posting a second approval for the same call_id.
Reconnect to a dropped stream
Problem: The SSE stream closes before you receive processing.finished.
Solution: Reconnect to the genie run and resume from the last event you received. Use one of the following:
Last-Event-IDheader: Pass theevent_idof the last event you received.since_seq_numquery parameter: Pass theseq_numof the last event you received.
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/genie-runs/:genie_run_id?since_seq_num=<last_seq_num>Use last_seq_num and wait retry_after_ms before reconnecting if you receive a system.stream_interrupted event. Don't reconnect after a processing.finished event with the reason business_approval_pending. Refer to Processing finished reasons. Deduplicate replayed events by event_id. Refer to Duplicate events or event IDs for more information.
Event recovery returns nothing
Error: Get events returns no events after a disconnection.
Cause: This error happens when you use the wrong parameter or window. The parameter is since_created_at (an RFC3339 timestamp); pass next_since_created_at from the previous response to page. Events are retained for 24 hours.
File upload is rejected
Error: A call to the upload endpoint fails, or the genie doesn't receive the attachment.
Cause and solution:
- File too large: Each upload accepts a single file, with a maximum size of 20 MB. Reduce or split the file.
- Wrong request format: Send the file as
multipart/form-datawith a singlefilefield. Don't setContent-Typemanually. Your HTTP client sets the multipart boundary. - Attachment not referenced: Uploading a file doesn't attach it on its own. Pass the returned
file_idin thefile_idparameter of Send a message.
Conversation topic returns a number instead of text
Problem: GET /conversations/:conversation_id returns a numeric topic such as 5951 instead of a readable title.
Cause: The genie auto-generates the conversation topic from the user's first message, which takes a few moments. If you call GET /conversations/:conversation_id before generation completes, topic is still a numeric placeholder. The list conversations endpoint returns the generated topic once it's ready.
Solution: Use the list conversations endpoint for display, or fall back to the conversation's first user message when topic is a numeric value.
Rebuild a conversation timeline after a reload or dropped stream
Problem: After a page reload or a dropped SSE stream, you need the full turn, including skill.* and processing.* events, but you only have what arrived on the live stream.
Cause: Every conversation event is persisted, not only the live stream. All event types, including skill.* and processing.*, are retrievable from Get events for 24 hours after they occur.
Solution: Fetch the persisted events with GET /conversations/events?conversation_id=<conversation_id>&since_created_at=<RFC3339> and replay them in order to reconstruct the full timeline. Don't treat skill.* and processing.* events as available only during the live stream.
One exception: a turn resumed after a runtime_connection.auth_required pause isn't captured in Get events — persisted events stop at the pause. Recover that reply from message history and merge it in, de-duplicating by message_id.
Get help
Every runtime response includes a request_id and an x-request-id header. Include these values when you contact Workato support so the request can be traced through the gateway.
